Page 3 of 3 FirstFirst 123
Results 51 to 68 of 68
Thread: Lemförder Made in China
  1. #51
    IL
    2000 740i sport
    Im sure the corteco and lemforders are fine. You can tap the studs out of the original ones and tap them into the new mount. The originals probably are an old production that has been sitting on a shelf at the dealer...
    Sent from my SM-N960U using Tapatalk
  2. #52
    Mar 2016
    Frankfurt, Deutschland
    Le Mans Blue e39 M5
    I'm thinking the same, most likely they have been sitting on a shelf, I can't imagine that they are selling them that often.
    Although I'm pretty sure the studs on Corteco mounts will snap during the install, it's not just that, if they skimped on something small like that who knows what kind of quality is the rubber compound. Once I pick up the original ones after Christmas, I'll compare them better and weigh both mounts.
  3. #53
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    Tie rod center link and ends Made in Turkey.
  4. #54
    Feb 2018
    Evansville Wyoming
    2000 540i, 99 Boxster
    Even worse, the Bosch plugs for my Porsche say: Made in Russia.
    Ditto on the Lemforder suspension links sourced from Turkey.
  5. #55
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Welcome to world sourcing. This has been going on for 30 years. 1st run is very expensive, engineering, die designs tested, metallurgy testing, ISO 9001 and DIN/SAE approval standards confirmed. After that run it goes down hill fast. By the 15 year mark most are excited that they can find a part that even fits!
    Note to those who have never been exposed to this. This process occurs by the part number not the entire line.
    See the product manager for drivers of the process. Some pressure is profit, some is a source that will build low qty runs. Most OE suppliers will make one to three runs of production. After that there is no business case for recreating a line for a small run of parts, as the cost would be a non starter as most owners want a "cheap part" to keep a tired car on the road.
    I know now that all sounds abnormal to enthusiasts who spend more on parts than what the car in question is worth. In Europe there are more Eastern Euro sources than what we see here in the US due to marketing/shipping costs. Hell I have seen parts hand formed in India if there is enough demand. No quality controls, metal testing, or fit and finish but it fits the car with a little on the spot "tweaking".
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  6. #56
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Part of the reason why its not always best to change out good old parts "just because your in there" anymore. It used to make sense to just get the whole kit and change everything at once, but that is likely not such a safe bet anymore. I'm approaching 180K and still have many original suspension arms, tie rods, and center link, etc. My thrust arms are original but with Meyle HD X5 bushings that work very good for me. I have a couple rubber boots dry rotting on some ball ends on some of the arms, so I know i need to replace them soon (likely a downgrade from what I have). There is no play in them now.
    If you have the ability to properly diagnose play in the ball ends and they pass the test, I would not change them.
  7. #57
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    All of my suspension is original too (158K) except for the springs (H&R) and the Koni struts/shocks.
    I've replaced a few of the rubber boots on the rear arms in the past as the ball joints were fine.
  8. #58
    Mar 2012
    Lansdale, Pa
    Hey Jim, where do you get the boots?
  9. #59
    Dec 2010
    Westport, CT
    2003 M5, E93 335i/6
    Those were the VW boots, right? I remember a thread that you had created years back but could not find it again.
    -Chris
  10. #60
    JimLev's Avatar
    Sundance Mesa, NM
    Yes, they were VW boots. I had to trim the small end to make the hole a bit bigger for the ball socket shaft to fit thru.
    I'll look it up, sure I have the info on some computer here.
  11. #61
    JimLev's Avatar
    Sundance Mesa, NM
    I'm still looking for the p/n. I remember buying them from a VW replacement parts place in CA. I'm sure I can find that company too.
    Here are some pics.
  12. #62
    Mar 2012
    Lansdale, Pa
    Looks crafty Jim. My kind of cheapness too. If you find source, let me know. I have a few that need replacement due to cracking.
  13. #63
    JimLev's Avatar
    Sundance Mesa, NM
    Here ya go. 99.9% this is the ones I bought.
    There is no bottom retaining ring on them so you can either use your existing ring (PITA) or use a few turns of safety wire with the ends twisted together, which is what I did. You can see it in the pic above.
    I put a thin coat of black RTV on the end I cut to help seal it to the metal 'hat' it fits under.
    You know that if BMW was selling this it would be $15 or more.
    https://socalautoparts.com/shop/fron...pper-or-lower/
  14. #64
    Mar 2012
    Lansdale, Pa
    Looks good Jim. Thanks for info lookup!
  15. #65
    Dec 2004
    CT, USA
    e28, e34, e39
    I bought some nice quality replacement boots for my e28 and e34 from Malcolm at https://www.balljointboots.co.uk/. I haven't had the pleasure of replacing any e39 boots yet but I still have a bunch from the variety pack I bought from him.
    cheers
    demet
  16. #66
    Mar 2012
    Lansdale, Pa
    ^thanks. Lots of sizes!
  17. #67
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    As all suspension parts are wear items that loose their tolerances one micron at a time, most owners do not even feel the slop until they jump from one car to the next. When in doubt take a road test in a refreshed suspension vehicle and then jump into your 150K++ example. You will be amassed at the "tight/loose" feeling from coming from your hands and butt. I was when I did mine at 100K.
    As always, it is your car and your choices.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  18. #68
    Mar 2012
    Lansdale, Pa
    Yup. Any with play get replaced. PRoper checking is needed.
