Hi,
I picked up a 1990 750i more than a year ago. Have done a lot of work on the car already and hope to post it all here. Now she got 260k on the clock but still have some rust issue on the body. I started with dropping rear subframe, drive shaft and exhaust. I cleaned the chassis and looked for any rust. I found rust in all four jack points and both sides on front foot wells but also on spare wheel floor.
The plan:
- already cut all rust away
- almost every sheet metal repair parts done or purchased
- repair rear trailing arm bushes
- repair leaking heating core pipes
- repair ihka servomotor fasteners
- and do a lot of other repairs
I will start off with some pics that i took in last summer.
What colour is your car? Wheels look sharp on it!
The kids:
Alpinas: 91 E34 B10 Biturbo; 91 E32 B12 5.0; 91 E34 B10 3.0 Allrad (mom's car); '91 B10 3.5
Bimmers: 91 E31 850; 93 E34 525i w/ aftermarket turbo; '01 X5 4.4; 93 E31 850i Dinan TT; 89 E32 750il Dinan TT; 92 750il w/ S70 engine and transmission
Mercedes: 92 600sel; 93 S600 Lorinser
VW: 04 Jetta GLS TDI
Very Nice, good luck with the rust removal!
Current
2005 E55 AMG
1998 Silverado K1500
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
2001 Stratus 740i Msport
1990 750iL
1995 540i/6
1996 MGM
Nice looking one
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
ULTIMA Evolution
Contacts
http://alpina.123.is/pictures/
What are the wheel sizes and the brand?
Exhaust is not standard? It has round end pipes not the square ones normally on a 750.
Can you post the last 7 numbers of the VIN, then I will check the details how the car was ordered, optional extra etc.
dc02434
Some pictures from last december..
right front jack point
left front jack point
right rear jack point
left rear jack point
left rear side panel
right rear side panel
towing hinge
trunk floor
repaired drive shaft with new center bearing
worn rear trailing arm bush
Great looking car! The wheels look fantastic. Looking forward to seeing more of this build.
I'd be curious to hear an M70 with a fairly open exhaust.
Daten für die Fahrgestellnummer: WBAGB81020DC02434
Modellbezeichnung: 750i
Ausführung: Europa
Typschlüssel: GB81
E-Code: E32
Karosserie: Limousine
Lenkung: links
Türen: 4
Motor: M70B50 - 5,00l (220kW)
Antrieb: Heckantrieb
Getriebe: automatisch
Außenfarbe: Delphin Metallic (184)
Innenraum: (0226)
Produktionsdatum: 17.11.1989
Werk: Dingolfing
S209A Sperrdifferenzial Differential lock 25%
S240A Lenkrad Leder Airbag Leather steering wheel
S320A Entfall Modellschriftzug Deleted, model lettering
S339A Shadow-Line Shadow-Line
S401A Schiebehebedach elektrisch Lift-up-and-slide-back sunroof, electric
S417A Sonnenschutzrollo Tür hinten Roller sun vizor, rear door
S423A Fussmatten Velours Floor mats, velours
S428A Warndreieck und Verbandstasche Warning triangle and first aid kit
S459A Sitzverstellung elektrisch mit Memory Seat adjuster, electric, with memory
S488A Lordosenstütze Fahrer u. Beifahrer Lumbar support, driver and passenger
S489A Lordosenstütze Beifahrer elektr. Lumbar support, passenger, electr.
S494A Sitzheizung Fahrer/Beifahrer Seat heating driver/passenger
S528A Automatische-Umluft-Control AUTOMATIC AIR FLOW CONTROL
S655A Satellitentuner Satellite tuner
S676A HiFi Lautsprechersystem HiFi speaker system
L801A Länderausführung Deutschland National Version Germany
Here's few pics when i replaced cylinder number 7 and 8 hydraulic valve lifters.. Before that engine start to ticking very annoyingly on idle.
At the same time i cleaned and restored both cylinder head covers. I replaced also fuel hoses to new ones because those hoses were baldy hardened. I had to replace also cracked rubber adapters on both covers which holds crankcase volume control valves in place. And one o-ring on the steel pipe which is located between cylinder banks. They look like brand new now.
Here is few pics of repairing the right front jack point.
All rust cut out and one repair sheet metal part already welded on place..
Some progress
Test fit the surface sheet metal and it is almost ready to welded in place.
View from the inside of right jack point.
Here is pics when i dismantled dashboard to fix broken servo fasteners and to replace leaking water hose.
Dashboard
Leaking waterhose
Broken Ihka servo fasteners
Dashboard removed
Sir, you have one very large bag of balls, i like your work!
Passenger side rear wheel housing. There was rust only in few spots and here you see what i had to cut.
I had to cut the rear panel of the upper side of the bumper also because it was rusted from the inside out.
Here's all passenger side repair parts what i had to made.
repaired spare wheel housing.
Little progress
this looks really nice, i wish i had the guts to do so, taking apart one of these cars looks really tough
1966 Porsche 911
1966 FORD GT40 MK2
1967 Alfa Sprint GT
1968 Ford Mustang Coupe
1968 Chevy C10
1970 Alfa 1300 GT Junior
1972 Alfa 2000 GTV
1974 Alfa 2000 GTV
1978 Porsche 911 SC Targa
1980 Mazda 626 Rotary Turbo
1981 Mercedes 300GD
1986 Mercedes 190E 2.3 16
1987 Mercedes 190E 2.3 16
1988 BMW 735i 5 Speed
1989 BMW M3 BRG
1989 BMW 325IX
1991 BMW 850i
1991 Range Rover 2 Door VM Diesel.
1993 BMW M5
1995 Porsche 911 C2
1996 BMW M3
2001 BMW M5
2002 Porsche 911 Carrera 4S
2002 Ford F150 5 Speed 4x4 Reg Cab Shorty
2002 Honda Insight 5 speed
2005 BMW M3
2008 BMW M5
2012 BMW X5 Diesel
2017 Ford F150 Platinum Supercrew
Great job on the repairs! Do they use salt on the roads in Finland? Others should make note and check the corresponding areas on their vehicles as well.
I have only found the one spot http://www.bimmerforums.com/forum/sh...enger%92s-side. Once you find a spot that is rusting out from inside you can't just fix it without finding the cause, and fixing that as well. Otherwise it'll need doing again, as with my floor.
Very nice work.. did you hand form all of your patch panels, or cut some from donor vehicles?
Derek k. Yes here is used for road salt in the winter. The car is imported to finland in 2006 and has not been never driven in the winter in finland.
Kansei. i did all the patch panels by my self.
Great metalworking skills!
Rust removal progressing.
I used the acid self-etching primer to surfaces what were bare metal and on top i used the polyurethane paint.
Next thing is to put seam sealer on joints and then spray the correct body paint on top.
I found that Duplicolor Bed Armor is great for the last coat. "Do-It-Yourself Truck Bed Liner is a water-based, rubberized polyurethane coating. It is ideal for protecting truck beds, and all other metal, aluminum, fiberglass, and wood surfaces. Bed Armor is the only do-it-yourself truck bed liner formulated with DuPont™ Kevlar®"
http://www.duplicolor.com/products/bedArmor/
I used this on the inner wheel wells, inside the fenders and on the exterior of the floors and trunk on one of my cars and bullets bounce off. It's great for undercoating. But prep the parts right or you'll be peeling it off in a few years.
That is certainly useful stuff, but I think that I use the factory system for the protection..
here is few new pictures
