Results 1 to 2 of 2
Thread: Fs: 4.10lsd e30/e24/e23/e28/z3/318ti
    Dec 2014
    Pheonix
    1983 635csi, 1987 635csi
    BMW E30 *4.10* Clutch type Limited Slip Differential LSD 188mm Stock 25% Lock-Up
    Up for sale is a good working condition 1990 e30 325i limited slip differential removed from a car that was totaled. The car had 163K on it. The car had an automatic and m20 suggesting their was little stress put on the differential. The input shaft bearing feels great and the diff is in good shape, with no leaks. I have cleaned this unit to look as it does in the photos. The rear cover was removed to inspect the ring and pinion gear and inner workings for abnormal wear. There is no gunk or residues on the internals suggesting this is a well cared for diff. Be assured, this diff is in great shape and will not whine!
    This differential will fit many different BMW models listed below with a simple change of the rear differential cover and output flanges.
    Fits the following models:
    BMW e23: 733i, 735i, 735il
    BMW e24: 633csi, 635csi, m6, m635csi
    BMW e28: 528e, 528i, 533i, 535i, 535is, m535i, m5
    BMW e30: 323i, 325i, 325is, 325ic, m3
    SOLD. If you have any questions feel free to send me a question!
    Oct 2007
    Vancouver, BC, Canada
    320is 1982
    Hello,,
    Do you know if an E28 LSD's internals will fit inan E12 530i case, with the side entry layout ? It's really difficult to source side entry case LSD's...so maybe swapping the internals is possible??
    Thanks,
    Mike
