BMW E30 *4.10* Clutch type Limited Slip Differential LSD 188mm Stock 25% Lock-Up
Up for sale is a good working condition 1990 e30 325i limited slip differential removed from a car that was totaled. The car had 163K on it. The car had an automatic and m20 suggesting their was little stress put on the differential. The input shaft bearing feels great and the diff is in good shape, with no leaks. I have cleaned this unit to look as it does in the photos. The rear cover was removed to inspect the ring and pinion gear and inner workings for abnormal wear. There is no gunk or residues on the internals suggesting this is a well cared for diff. Be assured, this diff is in great shape and will not whine!
This differential will fit many different BMW models listed below with a simple change of the rear differential cover and output flanges.
Fits the following models:
BMW e23: 733i, 735i, 735il
BMW e24: 633csi, 635csi, m6, m635csi
BMW e28: 528e, 528i, 533i, 535i, 535is, m535i, m5
BMW e30: 323i, 325i, 325is, 325ic, m3
SOLD. If you have any questions feel free to send me a question!
