Results 1 to 21 of 21
Thread: Radiator / Intercooler Paint?
    Nov 2008
    nnj
    Vipers, e46m
    The paint on my black TRM intercooler is starting to flake off . What brands have you guys used that have worked well? Any recommendations?
    Aug 2014
    Seattle Wa
    95 M3 04 M3 99 swift
    It's really not the brand of paint but how you prep the surface.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    You should look into getting it anodized, call local shops its not expensive.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by E36 HateR View Post
    Yep. Best for heat management too. I had a powder coated IC once. Def increased the soak. Anodization shouldnt affect the heat transfer like that.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Manchester, N.H.
    96 332IS 6466 turbo
    Grill paint, or it will be costly.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Chicopee, MA usa
    1998 M3 TURBO
    I would think if you just sprayed the paint on an angle to not get it in between the fins it shouldn't effect it much? no?
    ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
    Vancouver, B.C., Canada
    '97 M3
    Barbecue paint only on the front. The paint won't get very far down the fins.
    Sent from my GTX3582R
    Mar 2010
    Quote Originally Posted by chikinhed View Post
    I think that's prob a pretty good solution as long as you do it super light so it doesn't layer up and potentially trap heat. And being just BBQ paint you can touch it up quick & easy when needed.
    In the end I sanded the powder off of the face of my IC, left it on the tanks. There are some special "heat transfer" coatings that supposedly actually improve transfer but A. not sure I believe it, and B. cost/benefit was not attractive...
    2003 M3CicM6 TiAg
    Former:
    '97 M3
    The surface area of the visible front area is very small compared to the rest of the heat transferring tubes and fins of the intercooler. Anodizing black would be great but it has a tendency of fading to purple after a while and I would prefer to have it bare aluminum on the back side to help reflect the heat from the radiator or AC condenser.
    Nov 2008
    nnj
    Vipers, e46m
    This is my plan, just looking for a recommendation of brand to use.
    Right, which is why I don't want to anodize, besides the cost. Also, it's not a beauty contest, I just want my intercooler basically hidden. Its very, very difficult to tell my car is turbo, and I like it that way.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Ideally, you would coat it with a metallic-ceramic engineered to disperse more heat to the atmosphere. I plan to do some experimentation on aluminum radiators and ICs with Techline's TLTD thermal disperspersant coating (requires an oven cure__do not try this at home... ).
    I already use that coating on lots of other stuff, and it remains black-black, regardless of time or exposure.
    This is TLTD on a trick little Eurosport piece...
    Oct 2005
    Nördlich des Äquators
    M3TTst2Meth-K1300S-1100G
    '97 M3
    Quote Originally Posted by Haifisch M3 View Post
    painting the IC black... not a good idea YouTube Link: https://www.youtube.com/watch?v=z_mmmXTbLP0
    I watched the video. His argument was implying that people paint the whole Intercooler, including in between the fins and on the back side. He was also suggesting that a lot of heat gets taken away from the front face of the intercooler. I would tend to think that the area between the fins is where most of the heat is expelled. I get that paint can be an insulating layer but if I have put a light coat of spray can barbecue flat black on the front surface only and the intercooler lives in the shade behind the bumper cover and stock mesh piece, I really don't think I am jeopardizing much of the thermal efficiency of my 23x18x4" intercooler core. I think a much much larger loss of efficiency is from not ducting the intercooler properly. The paint would be nothing compared to that.
    Apr 2009
    Virginia Beach, VA
    e30 hopefully
    That kid proved nothing that the original video didn't already state. 3% would mean a 3 degree difference if it drops the temp 100 degrees. How much power is gained or lost due to 3 degrees of intake air temp? I'm tempted the to the difference would be negligible. I would rather have a stealth looking intercooler and sacrifice the couple hp we would be talking about. As stated above I think far more could be gained from proper ducting that most people overlook.
    Ship, Pa
    Red Sled, RC51
    If anyone thinks spray paint is going to effect how fast your car is you have some issues.
    "Believe nothing you hear, half of what you read"
    May 2003
    Richmond, Virginia
    Lots.
    I've used Eastwood Radiator paint where I went a bit heavier on end-tanks and fairly light dusting across surface/fins but enough to ensure coverage.
    915whp '98 M3 Sedan /// 37k Mile '95 M3
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by 95RogueM3 View Post
    Your intake temps must be 200°+. ; )
    1996 332IS
    Built 3.2
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by Fender13Bender View Post
    You do know red cars are faster right
    Oct 2005
    3% in stationary test, with a low output fan, can translate into a lot more at speed (at the track)
    The only scenario in which the black IC shows any benefits is while idling at a red light...if the clutch fan isn't working
    While moving... it hurts performance... when you need it.
    The fins in the IC are really close together and even a thin coating of spray-paint will close the already narrow air passages even more.
    Not only does the paint act as a layer on insulation but it also reduces thru-flow ...both reducing efficiency of the IC
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Agreed..I would use a black paint of some sort..something that is UV stable.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
    May 2023
    London
    Honda Civic
    Hi there, I'm currently considering painting my radiator, and during my online research, I came across a paint that appears to be promising. Nevertheless, as I lack experience with such products, I would greatly appreciate your opinion to ensure I don't make any errors. Thank you for your assistance.
