So i got my fog lights wired in on the bumpers end and found the switch is not wired so i have the wire diagram but was wondering if any one knows how to wire it up or could post a photo of a working switch? Mine is the pull knob switch not the button one.
Are you looking at the wire diagram that's linked from the faq/diy thread?
If not, you should, because it's much easier to read.
Also, when it comes to custom wiring, you're pretty much on your own, while following the wire diagram.
The OE fog lights run through a relay and two fuses, via the unloader relay. If you look at the wire diagram, you'll see this.
I believe your car has pre-installed power wires for the fog lights? don't quote me on that though.
Check if the relay and fuses are installed too.
Tbd
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Mine doesn't have existing wires behind grill so I just wired them up to the low beams. Can't use the on/ off switch that what though. Someday I will add or find the wire that comes off the fog light fuses.
Hi Tom, or anybody else
What wire colors do GY and YL represent?
These are the wires colors going to the fog light switch (from the ETM wire diagram)
Tbd
gray - yellow
I pretty sure the switch came with the fog light option and would not be there if it didn't have lights at some time.
yup, just looked it up, the switch was optional.
yellow wire from the headlight switch to the fog switch via connector C63 and then a gray wire going from the fog switch to the fog relay terminal 85, but first through connector C20f
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Ok i wanted to put a up date and thank you for all your help i got the fog lights working on my valance... and i must say they look damn good. I love the way the 325is valence looks on a E21.20150214_000641.jpg
Can anybody point me to the faq/diy diagram for the E21 fog light diagram mentioned in this thread?
Much appreciated.
I see that GDAus helped with a diagram in another thread.
Here are pdf file copies of the wire diagrams that were linked in the diy/faq thread.
'81-83
http://www.findmymerchant.com/images..._1981-1983.pdf
'80
http://www.findmymerchant.com/images...l/ETM_1980.pdf
'79
http://www.findmymerchant.com/images...l/ETM_1979.pdf
'78
http://www.findmymerchant.com/images...l/ETM_1978.pdf
'77
http://www.findmymerchant.com/images...l/ETM_1977.pdf
Tbd
