So, I'm looking at realoem, and there are two different part numbers for the gasket on the rear half of the exhaust: 18101405737 and 18111723379. Does one (the asbestos free one, 18101405737) supersede the other one? Do I need two of each? One of each? Too many part numbers are in my head right now to make sense of this.
Current cars:1997 BMW M3 Sedan, 1983 BMW 320i
Past Cars: 2002 Mini Cooper, 2005 Scion xB, 1998 BMW 318ti,
1999 Chevy Cavalier Coupe, 2001 Suzuki GSX1300R Hayabusa
You need one of each. They are different size. 3&4 in the realoem diagram.
Thanks! It's amazing how good this forum is for answering technical questions. Here's another: P=NP? (Honestly, if someone answers that question below...then...I..well, I've got nothing.).
That question cant be answered!
The asbestos free one is fiberous, the other is a stainless steel type. AFAIK there is not 2 hard metal ones due to the diameter on the fiber one is bigger than that of the hardened steel. Someone can correct me, but that has been my experience.
There are threads in various places saying the p/n's you quoted from the rear exhaust diagram are incorrect (I don't have links but you can find them). Apparently tThe correct p/n's can be found in the middle exhaust diagram:
http://realoem.com/bmw/showparts.do?...18&fg=10&hl=31
(13 and 14):
18111719446
18111723720
Though I don't know why there's a 720 and 721...yet another mystery about rear section gaskets.
If you want to wait I have these on order and I'll be able to verify if they're right or wrong in a week or so when I re-do my hangers.
Cosmos / Amaretta - '97 ///M3
I believe so. I compared the drivers side ones (since it falls out when you pull the exhaust). They looked the same. I decided to re-use the gaskets since they were undamaged and I ended up being rushed to put the system back together so I didn't test fit the passenger side gasket.
OK. I have an official, complete, triple-checked answer. I talked to Pelican Parts yesterday, and called a couple of buddies at BMW this morning, and here's the actual, factual answer: the diagrams are sort of wrong.
18111719446 and 18111723720 are the correct part numbers on the M3. The other two part numbers are because that particular diagram is for the MZ3, not the M3.
Awesome. Looks like RealOEM may have updated their diagrams to reflect these changes. As of 2024 the gaskets parts are #21 & #22 in the new diagram.
21 Gasket ring asbesto-free 48MM 1 18111723720 $8.37 ENDED Required for repair -- Hex nut wiht flange M8 2 18307620549 -- Hex bolt M8X55-8.8 2 07119902957 $5.27 21 Gasket ring asbesto-free 1 18111723721 22 Gasket ring 48MM 1 18111719446 $8.37
[ US spec 10/1995 e36 m3 ]
