Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 79
Thread: I've made a wonderful mistake!
  1. #26
    Mar 2014
    Oregon
    1999 BMW M3 Coupe
    You should reinforce the rear swaybar mounts on that subframe while you're in there welding things. There are kits (akg I think) that work well. Also just a piece of flat bar welded in does 90% of the job if done right.
    They will crack again, if you don't.
    Paint looks great!
  2. #27
    West V
    1995 M3
    I did have the tabs welded.
  3. #28
    West V
    1995 M3
    More pic! Got the rear end out, cradle out, new cradle ready go back in with all new PF bushings, interior mostly stripped and deadening out, and roll bar lined up to mount. Cutting quarter windows from lexan has been a pain in the ass!
    Anyone have a guide to what wires I can strip/cut from the doors? I have nothing left to control so the wires are useless. I don't wanna snip something and the ecu not work.
  4. #29
    West V
    1995 M3
    Well after over a year sabbatical I'm back to the build. This showed up in the middle of it all.
    And with another side project....
    I finally got back to the rear end. Had to get bearings pressed out from a local shop and rebuilt axles...now time for reassembly.
    Now before I seal that case someone tell me the best gears for track duty. 3.64?
  5. #30
    West V
    1995 M3
    So after almost 3 years the M is finally on the ground again. Took me 20 hours over the weekend to shore up the rear suspension and brakes. Got a couple odds and ends to finish up but should finally be ready for track season.
  6. #31
    West V
    1995 M3
    I have exhaust questions if anyone can help me out. I have the S52 manifolds to upgrade too. After that I'm planning to get rid of everything to the muffler. Is there a method to this madness or take it to a local muffler shop and let them build something custom?
  7. #32
    ithaca Ny
    95m3/97m345/powerstroke
    Bimmerworld race exhaust is a solid option for a track car. Or if you want just the mid section and stock muffler, they offer just the mid pipes too. Both will bolt right up to the manifolds.
  8. #33
    West V
    1995 M3
    Quote Originally Posted by Pat533i View Post
    I see that. Is there a cheaper option? I assume my local exhaust shop with fab me some pipes and install a cheap muffler and I can retain the stock collector sections off the manifolds.
  9. #34
    Feb 2016
    NJ
    E36 M3 SEDAN
    Depending on where you live, that may cost more than the Bimmerworld option. I ended up having a custom exhaust made by a race shop since I had long tube headers and went with OBD1 and it cost a lot more than expected. A lot of little parts that add up plus a few hours of fabrication to do it right versus just slapped together. At least it sounds *epic*. Lol. 3" all the way back is awesome...
  10. #35
    West V
    1995 M3
    Quote Originally Posted by tripitz View Post
    We have a company with several local locations that usually does cheap work. For now I think I'm just gonna have them striaght pipe from the last connection back replacing the muffler. Weight reduction!
    Sent from my SAMSUNG-SM-G930A using Tapatalk
  11. #36
    ithaca Ny
    Seems you just answered your own question then
  12. #37
    West V
    1995 M3
    For now. I haven't swapped the 52 manifolds yet and I eventually want to go without cats and less restrictive pipes.
  13. #38
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by BacDoc View Post
    It's gonna be loud!
  14. #39
    West V
    1995 M3
    Quote Originally Posted by jakermac View Post
    It's gonna be loud!
    It's a track car. Its supposed to be loud.
    Now a friend has a daily SS Camaro with full headers and exhaust...he's been asked to leave a track. lol
  15. #40
    West V
    1995 M3
    What's the widest wheel tire combo that fits under these cars? I have the 17x7.5 with 240/45's now I think.
  16. #41
    Vancouver, BC Ca
    1993 325is
    What fits without flares or with flares?
    I run 285/30-18s on 18x10.5 under the flares that are on the car right now - modified Hard Motorsports V1s (see pic below). I plan on modding them a bit more to fit 295/30-18s on same width wheels.
  17. #42
    West V
    1995 M3
    Nice. Right now its stock not even rolled yet. I will roll them out in the next couple weeks. Thanks
  18. #43
    West V
    1995 M3
    After 3 years the ///M lives! Fired up and put some final touches on her today and took her out for a short sprint. This was the most I've ever driven an E36M lol. Gotta finish up some of the interior, mount the light weight battery and install the spal fan kit and I'll be track ready.
  19. #44
    West V
    1995 M3
    S52 header swap, trans mounts, and dropped the driveshaft to swap guibo and replace shifter.
  20. #45
    West V
    1995 M3
    The front diff bolt and bushing seem to have backed out some. I'll retorque ...I think I only used ~80ftlbs last I read. Think its supposed to me more. Is there a spec and is there supposed to be a washer in front of the bushing? I'm using Powerflex purple.
  21. #46
    Nov 2013
    VA
    E36
    Diff bolt should have a spacer. I had the same problem until I started using red loctite.
  22. #47
    West V
    1995 M3
    Quote Originally Posted by bmw328m52 View Post
    Loctite won't cause it to break off? I'm going to get under there today and torque it down. I think I only used 77lbs. I've read up to 12xlbs. Can anyone confirm?
  23. #48
    Nov 2013
    VA
    E36
    I used red loctite as a worst case on my 450whp turbo car. Up the torque to 85 ft lbs first and see if it holds.
    Sent from my XT1585 using Tapatalk
  24. #49
    West V
    1995 M3
    What about replacing the bolt too? I've read some people replaced the bolt or even drilled out and upgraded. I realllllly don't want to have to break this thing down again.
  25. #50
    West V
    1995 M3
    Got light weight battery mounted.
    PowerFlex diff bushing backed out. Retightened but its stopping a fraction short. Anyone else have this problem?
