Page 3 of 8 FirstFirst 12345678 LastLast
Results 51 to 75 of 185
Thread: 2002 BMW M3 Convertible "noob"
  1. #51
    Jan 2015
    Azores, Portugal
    Quote Originally Posted by M_3_X View Post
    That "shaft sensor" might be the TPS, (Throtle Position Sensor) which could have been the culprit in the first place and your actuator was good..and the fact that they didn't charge you for it... You'll never know unless you put the old actuator back...oh well. good thing you got it back soon.
    Thank you for your comments!
    Well, i was dumb in a way. When the car was there to have the "actuator" fixed i told the service adviser that i wanted the old part back. He said that it wouldn't be a problem.
    But with all this frustration and aggravation, i forgot to demand the old "Actuator" back from them. Maybe i could of sold it on Ebay for 300USD and cut down my losses
    In another note.
    My fob key is being stubborn. It didn't work when i purchased the car, and its the only key i have for the ///M. I did opened to change the battery, with a 2016 Energizer battery. I couldn't find a new original battery.
    I tried to reprogram, by watching Youtube vids. No luck!
    When i recover from this massive " ///M for Maintenance" I will bring it back to the dealership to have them look at it.
  2. #52
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Do you have a second key? If so send your busted key to this guy for repair: www.bmwgm5.com
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  3. #53
    Jan 2015
    Azores, Portugal
    Hi friend!
    No i don't have a second key. I only have one. Good site! thx!
    Also today. My air vent went out again, then i hit the passenger side wall where the "FSU" is located, and it started to work. GOD!! I just replaced that "FSU" with a OEM from the dealership. What can possibly be going on this time WTF!
  4. #54
    dworthy's Avatar
    Nov 2010
    Check to make sure your connection is good and tight on the FSU. Also get another key, even if it is the crappy plastic one. Nothing worse than losing your keys, and you have to wait 2-3 days for a new one to come in.
    Darin
    Current:
    Past:
    M-Flight Member
  5. #55
    Jan 2015
    Azores, Portugal
    I don't think its the connection. Because it snaps on, it wouldn't snap if it wasn't...The vents are going on and off. But i can see your point, because on the older FSU i would just touch the wires and the vents would come on. But that was on the beginning stages of the FSU going bad. The other thing i noticed was the A/C is blowing colder...I think its the blower that is causing the FSU to go out every few months...Any other ideas...?
  6. #56
    dworthy's Avatar
    Nov 2010
    Take a closer look at the wiring harness/plug. If you have some contact cleaner, use that to clean it up. Also make sure the wires are tight in the plastic holder, as some could have gotten hot, and loosen up the bracket in which they sit.
    Darin
    Current:
    Past:
    M-Flight Member
  7. #57
    Jan 2015
    Azores, Portugal
    Thank you my friend!
    I will do when it goes out for good... Just dont feel like going thru all the glove compartment thing again.
    in an another note. I didn't know you could do this to your headlights...
    https://www.youtube.com/watch?v=jRcsD2UZkhE
    http://www.ecstuning.com/BMW-E46-M3-S54_3.2L/ES173243/
  8. #58
    dworthy's Avatar
    Nov 2010
    Yes, the plastic is removeable. I had to do that on the wagon, as the lenses were starting to get cracked/spiderwebed along the top side. Now the newer models, they are sealed with glue, and you cannot replace them anymore. So big bucks if you get fogged/crack lights.
    Darin
    Current:
    Past:
    M-Flight Member
  9. #59
    Jan 2015
    Azores, Portugal
    I thought that was a really noice touch from BMW engineers. Oh! My passenger side headrest just took at dump... looked around to see how to get it fix, something about the cable. I will have to tackle that...OH BOY!
  10. #60
    dworthy's Avatar
    Nov 2010
    AFAIK, there is not cable for the headrest, only a motor to move it up/down.
    Darin
    Current:
    Past:
    M-Flight Member
  11. #61
    Jan 2015
    Azores, Portugal
    I did google it, and i found this...
    http://www.bimmerfest.com/forums/sho...d.php?t=635189
  12. #62
    Jan 2015
    Azores, Portugal
    Well i fixed the headrest on it. You were right its just a motor with a rod. I guess it was just duty in there, cuz all i did was spry WB40
  13. #63
    dworthy's Avatar
    Nov 2010
    That can happen, it is over 10 years old. What you can do is note it in the back of your head, and every year when you change the oil, lube it up.
    Darin
    Current:
    Past:
    M-Flight Member
  14. #64
    Jan 2015
    Azores, Portugal
    New side markers 😎
    Installed new side markers
  15. #65
    dworthy's Avatar
    Nov 2010
    Are you using the stealth bulbs? I have installed the ones up front, but have been waiting to do the side blinkers.
    Darin
    Current:
    Past:
    M-Flight Member
  16. #66
    Jan 2015
    Azores, Portugal
    I got it from ECS Tuning. When i purchase my oil change kit.
    https://www.ecstuning.com/ES2090767/
    The stupid FSU or heat is still going on and off... Even tho i have change it myself with a OEM FSU twice!. I have no idea what it can be causing this problem. Probably a bad wire or something
    Probably drop it off to BMW of Newport and let them deal with it
  17. #67
    dworthy's Avatar
    Nov 2010
    Did you buy it from BMW? If so, there is typically a 2yr unlimited warrenty on most parts.
    Darin
    Current:
    Past:
    M-Flight Member
  18. #68
    Jan 2015
    Azores, Portugal
    Yes i did buy it from a dealership. Something wrong somewhere in that area, because i have to kick that part of the floor or side panel a couple of time to so it can start working again. I don't know man...Its something there that is causing the FSU to burn out
  19. #69
    dworthy's Avatar
    Nov 2010
    How dirty is the slot that the FSU goes into? At times if the filter isn't replaced on a regular basis (1 yr) they tend to allow dirt to pass. Otherwise I am thinking that the climate control or fan may have a hand in it.
    Darin
    Current:
    Past:
    M-Flight Member
  20. #70
    Jan 2015
    Azores, Portugal
    Well, my Oil temperature gauge just stopped working...
    But i know what it is...Its the oil level/temperature sensor, that went bad .
    Looks to be a easy fix. Gonna go at it when its warm out
    http://www.m3forum.net/m3forum/showthread.php?t=256859
    http://
  21. #71
    dworthy's Avatar
    Nov 2010
    On that thread, they are replacing the oil level sending unit, which turns on the yellow oil can. If you have that problem too, go ahead and replace it, Hella is the OEM supplier.
    As for the gauge, replace the sending unit on the oil filter housing.
    Darin
    Current:
    Past:
    M-Flight Member
  22. #72
    Jan 2015
    Azores, Portugal
    Oh my word!!
    https://www.ecstuning.com/Search/Sit...sor/ES2856013/
    It does show the "yellow" Oil can on the cluster. Gotta call the BMW of Newport to see how much they charge
  23. #73
    dworthy's Avatar
    Nov 2010
    Pffff don't pay them prices from ECS tuning, you always have to shop around: http://www.amazon.com/HELLA-00786803...ype=automotive
    I would just leave it until you need to do an oil change.
    BTW I used the same on in the wagon about 3 years ago, no issues since.
    Darin
    Current:
    Past:
    M-Flight Member
  24. #74
    M_3_X's Avatar
    M_3_X is offline Breaking Stereotypes BMW CCA Member
    N. Miss - Memphis TN Area
    '02 M3, '05 X3, '91 E30
    Wow, you are having way too many issues with this car, I use to have a 2003 325ci back in 2007-08, and I had a similar experience....got to find out that the car had been in a flood. I didn't want to keep replacing everything so I traded for something else. Water damage/Moisture can cause a LOT of electrical and sensor related issues and gremlins.
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    _____________________
    River City Bimmers Chapter
    2002///M3 Coupe, Steel Gray Metallic on black leather, three pedals.
    2005 X3 3.0i ZPP, Black Sapphire on Terracotta.
    1991 E30 325ic, AW, Black leather, Black top, three pedals.
  25. #75
    Jan 2015
    Azores, Portugal
    Thank you friend for the link. I always buy my oil kit there, so that is why i looked into.
    Yes I'm waiting to do the oil change and that sensor together .
    Yes i been having a few thousand dollars problems with this ///M3. One thing that i noticed i get more fuel miles with a 89 octane then the 93 octane...weird
