Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 185
Thread: 2002 BMW M3 Convertible "noob"
  1. #101
    Jan 2015
    Azores, Portugal
    Go to amazon.com and look-up the Phillips D2S bulbs, they are around 65 bucks there. As a matter of a fact, it is the OEM supplier to BMW for those bulbs. I would replace only one, as they don't tend to yellow until they are about ready to go. I wouldn't bother attempting to modify the buckets to make other bulbs work.
    Great advice my friend once again !
  2. #102
    Jan 2015
    Azores, Portugal
    This?
    https://www.amazon.com/gp/aw/d/B005J...VTL&ref=plSrch
  3. #103
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Quote Originally Posted by Benocehcap View Post
    This?
    Yup, that is it. Since you are getting two as the same time, might as well to replace both of them unless you know for sure when the ones that are in there were replaced last? Or you can just keep the good one as a spare in case one does blow out on you later on down the road.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  4. #104
    Jan 2015
    Azores, Portugal
    Well the infinity FX35 DS2 bulb that I had on my motorcycle is the same as the BMW///M3 bulb.
    So I just swap it since I don't use the motorcycle with headlights any more.
  5. #105
    Jan 2015
    Azores, Portugal
    Now my driver side mirror will not adjust from the passenger side seat using the door adjuster switch. Any thoughts
  6. #106
    M_3_X's Avatar
    M_3_X is offline Breaking Stereotypes BMW CCA Member
    N. Miss - Memphis TN Area
    '02 M3, '05 X3, '91 E30
    Your car has a mirror adjuster on the passenger side??
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    _____________________
    River City Bimmers Chapter
    2002///M3 Coupe, Steel Gray Metallic on black leather, three pedals.
    2005 X3 3.0i ZPP, Black Sapphire on Terracotta.
    1991 E30 325ic, AW, Black leather, Black top, three pedals.
  7. #107
    Jan 2015
    Azores, Portugal
    Quote Originally Posted by M_3_X View Post
    Oh crap!
    My mistake ! From the drivers seat. Sorry! I have memory electric adjuster seats. Do I have electric folding mirrors too.
  8. #108
    M_3_X's Avatar
    lol that's ok.
    No, folding mirrors was not an option in the e46 as far as I know.
    -Mario Andretti.
  9. #109
    Jan 2015
    Azores, Portugal
    lol that's ok.
    Oh ok. Thank you
  10. #110
    Jan 2015
    Azores, Portugal
    Hi there friends,
    Looking for some advice on rotors pads and tires for my ///M3.
    My rotors are pretty much wasted. with a good size lip on top of the rotor.
    I usually buy my oil service at ECS Tuning. and i do like their service...But if there is a better place that can save me a Mitty dollar, that would be great!!
    They also sell OEM rotors.
    https://www.ecstuning.com/b-genuine-...34112229529kt/
    They also have these. They're for the "For vehicles without Competition Package/ZCP/CSL front brakes" Will it fit my ///M3?
    https://www.ecstuning.com/b-genuine-...282801802~oem/
    These are the pads...
    https://www.ecstuning.com/b-genuine-...34112282416kt/
    for tires i usually buy it here:
    http://www.discounttiredirect.com/direct/home.do?
    thank you for your time!!
    Ben
  11. #111
    Jan 2015
    Azores, Portugal
    I have made some re-search and i found out that the ZCP brake Upgrade is the best upgrade you can do to your US ///M3. It will cost me $1,099.00
    Front Euro-spec cross-drilled brake rotors - BMW OEM Part# 282801802
    Rear Euro-spec cross-drilled brake rotors - BMW OEM Part# 282303304
    https://www.ecstuning.com/b-genuine-...282303304~oem/
    Front OEM brake pads (Jurid 187) - BMW OEM part# 34112282416
    https://www.ecstuning.com/b-genuine-...t/34112282416/
    Rear OEM brake pads (Textar T4001) - BMW OEM part# 34216761248
    https://www.ecstuning.com/b-genuine-...t/34216761248/
    Motul 600 brake fluid
  12. #112
    dworthy's Avatar
    Nov 2010
    I have been off the board for a little bit, I have been out of the country.
    While I like the euro spec cross drilled, I ended up with the ECS tuning slotted rotors and OEM pads on all 4 corners. Let me tell you why I went with the slotted vers cross-drilled. Cross drilled can crack or develop cracks around the holes, over time this can get dangerous. The slotted is good for keeping the pad clean, as it cuts the pad every time you brake. The question I have to ask is what type of driving do you like to do? If you are just a street driver with a little bit of spirited driving, then you could use the cross drilled for the appearances.
    Also take a look at Scott's post: http://www.bimmerforums.com/forum/sh...ke-Suggestions
    Darin
    Current:
    Past:
    M-Flight Member
  13. #113
    Jan 2015
    Azores, Portugal
    I only drive to work and back. Freeway miles around 60 miles round trip daily.
    I like the euro specs, cuz it's a better rotor with aluminum hub. And it will cost just about the same as US OEM from the dealership.
    I emailed my adviser at BMW of Newport for a quote. This is what he emailed me back.
    (Ben,
    Good morning, the price quote for the brakes on the M3 is:
    Fronts-$925.00
    Rears-$790.00
    I would need to order the rotors for both fronts and rears, so just let me know if you would like to proceed.
    Thank You,
    Paul Cunha
  14. #114
    dworthy's Avatar
    Nov 2010
    There is a reason why the US never got the fancy rotors: You just don't need them.
    I have worn out the blanks as they are called after 2 years of autobahn driving. The pads were just fine, but the rotors were burnt, so I switched to the slotted for about the same price and better braking.
    So in the end, I would say to stick with the blanks as you really don't push the car from 170 mph down to 65 mph in hard braking.
    Darin
    Current:
    Past:
    M-Flight Member
  15. #115
    Jan 2015
    Azores, Portugal
    How do i set to lock the doors when the car hits 5miles ?
    thx
    Ben
  16. #116
    M_3_X's Avatar
    Yo need INPA, Carsoft, or any other software to connect to the car's computer and re-code the LKE module.
    I got my Carsoft (BMW scanner 1.4) out of eBay for about $25.00.
    You can activate/deactivate a lot more functions too as well as read and clear codes for diagnosis.
    This, or any Dealer/Indy shop will be happy to do it for an hour labor.
    -Mario Andretti.
  17. #117
    dworthy's Avatar
    Nov 2010
    +1
    Here is the list of stuff that the car can do.
    Attached Files Attached Files
    Darin
    Current:
    Past:
    M-Flight Member
  18. #118
    Jan 2015
    Azores, Portugal
    Link please!
    thank you!
  19. #119
    M_3_X's Avatar
    Link please!
    thank you!
    This is the one I bought:
    http://www.ebay.com/itm/291904531364...%3AMEBIDX%3AIT
    You can also code it to flash the turn signals when locking/unlocking, even if you don't have an alarm, close windows with remote, turn DRL's on/off, and a whole lot of additional settings.
    I got a 25 feet USB extension cord so I don't even have to get my laptop in the car.
    -Mario Andretti.
  20. #120
    dworthy's Avatar
    Nov 2010
    INPA will not code the car, but Progman will. I use an old Dell D830 laptop with 2 6-foot serial port cables. I have 2 hard drives, one with Window XP Pro, and a SSD with Win-10. The XP does everything, but I use the Win-10 for INPA and everyday use. The thing with INPA is it doesn't like 64-Bit operating systems.
    Darin
    Current:
    Past:
    M-Flight Member
  21. #121
    Jan 2015
    Azores, Portugal
    Wicked!
  22. #122
    Jan 2015
    Azores, Portugal
    I have a mac book with macOS SIERRA?
  23. #123
    dworthy's Avatar
    Nov 2010
    Not sure, however there are a couple of experts over on the Diagnostic Software sub-forum who are great with INPA and the BMW tools.
    Darin
    Current:
    Past:
    M-Flight Member
  24. #124
    Jan 2015
    Azores, Portugal
    I been having some kind of squeaking when I do left or right hard turns. Coming from my rear wheels
    Do you guys think it is my wheel bearings?
    Thx!
    Ben
  25. #125
    dworthy's Avatar
    Nov 2010
    A wheel bearing make a grinding/helicopter sounds.
    I would look at the rubber bushing like RTABs, and others under the rear end.
    Darin
    Current:
    Past:
    M-Flight Member
