Page 5 of 10 FirstFirst 12345678910 LastLast
Results 101 to 125 of 240
Thread: FS: Z3 Coupe LED 3rd brake lights
  1. #101
    Oct 2007
    VA
    00 Mshoe
    Awesome for quick and dirty! The rubber strip seems to be random on the OEM lights and has no rhyme or reason, some have them some don't, some are on the top edge, some are on the bottom. Once installed I can't tell a difference, but it's nothing I did.
    I added rando's video to the OP. Thanks again for taking the time.
  2. #102
    Apr 2012
    Houston, TX
    2002 M Coupe
    Quote Originally Posted by robb1887 View Post
    Awesome for quick and dirty! The rubber strip seems to be random on the OEM lights and has no rhyme or reason, some have them some don't, some are on the top edge, some are on the bottom. Once installed I can't tell a difference, but it's nothing I did. I added rando's video to the OP. Thanks again for taking the time.
    My pleasure!
    Thanks for clarifying on the rubber strip. Only thing that looked different from my original, aside from the AMAZING LED GOODNESS!!!
    Sent from my iPhone using BF.com
    ___________________________________
    Always looking for my next
    ///M Coupé...
  3. #103
    Oct 2007
    VA
    00 Mshoe
    Core shows up today, who needs the next one?!
  4. #104
    Oct 2007
    VA
    00 Mshoe
    Built, boxed, and ready to ship. Who's an impulse buyer?!
  5. #105
    Oct 2008
    Easton, MD
    Z4MR, Z3MC F30
    I'll take it Robb (Chris Wootten). PM or fb me what you need for payment.
    2006 Z4M Roadster, 2002 M Coupe, 1984 533i, 2-1996 318ti's, 2013 328i M Sport
    Member and officer, ZSCCA
  6. #106
    Sep 2004
    SoCal
    Chariot
    Have you installed any lights with the flasher module? Any updates?
  7. #107
    Oct 2007
    VA
    00 Mshoe
    One, I have another flasher in stock. However, I'm not super excited on how it functions. I'm looking into a more "complicated" flasher that has 3 different settings for normal braking, intermediate braking, and hard braking based on the settings programmed and an accelerometer in the circuit board. The flashers I used that Sky suggested are just that, flashers of constant speed and duration no matter the braking situation or how long the brakes are engaged.
    The newer one is double in price, but can be programed for the g-force required to step between the flashes, and the number of flashes before constant is programmable as well. The price for these systems to be used would increase a decent amount unfortunately since all the customer reviews of them seem to make it complicated to learn to program and the initial price of the unit is double the original.
  8. #108
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    This is a video of the OLD flasher that is not affected by braking force. It is constant. There are many different flash patterns and you can vary the speed of each pattern. Constantly flashing is probably annoying to the guy behind me and almost certainly illegal. All worth it if it prevents somebody from rear ending me.
  9. #109
    Oct 2007
    VA
    00 Mshoe
    Excellent, thanks for posting a video of it. I'll see if Randy can help me with a video if I get the accelerometer based one to try out.
  10. #110
    Oct 2007
    VA
    00 Mshoe
    Bump for core returned and a new one ready to be sent out!
  11. #111
    Oct 2007
    VA
    00 Mshoe
    New LEDs showed up this week. Will have a new light ready to go here in the next day or two depending on my schedule! Who's next?!
  12. #112
    Oct 2007
    VA
    00 Mshoe
    Headed home from vacation today with a core in the trunk. Who's next?!
    P.S. getting one of the new blinkers modules ordered today to play with. We'll see how they work out.
  13. #113
    Sep 2004
    SoCal
    Chariot
    Awesome!
    Mine is on standby.
  14. #114
    Oct 2007
    VA
    00 Mshoe
    Flasher module is IN!
    I haven't gotten to play with it yet, but hopefully will over the weekend.
    The optional functions this little thing can do is impressive. I was reading them last night before we went to visit my parents.
    Default programming would be just that. I take it out of the box and wire it into the circuit as required for operation.
    Default Programming:
    Mounting: Wires toward front of vehicle
    Lockout: None
    Initial power: 6 slow(rate 8) standard flashes then continuous on
    Medium braking: setting 2, 6 fast(rate 4) standard flashes then continuous on
    Hard braking: setting 5, 16 very fast(rate 2) standard flashes then continuous on
    My preferred programming:
    Mounting: Wires toward rear of vehicle
    Lockout: Dynamic #1
    Initial power: 2 slow (rate 8) standard flashes then continuous on
    Medium braking: setting 2, 8 fast (rate 4) standard flashes then continuous on
    Hard braking: setting 6, 16 very fast (rate 2) standard flashes then continuous on
    All Programming options:
    Mounting:
    1-Wires to front
    2-Wires to rear
    3-Wires to driver side
    4-Wires to roof (not really for us but it's an option!)
    Lockout:
    -None
    -Dynamic #1: The longer you engage the pedal the longer it takes to reset the flasher (up to approx. 30 seconds). i.e. you're in bumper to bumper and not giving a EDM show to the guy behind you every foot you move
    -Dynamic #2: The longer you engage the pedal the SHORTER it takes to reset the flasher. i.e. I have no idea why this would ever be useful
    -Timed: 3, 6, 9, 15, 25, 35 seconds
    Brake Forces:
    -Medium: settings 1-5 (0.25-0.50Gs)
    -Hard: settings 1-10 (0.25-0.80Gs)
    Flashing Modes:
    1-Standard (X flashes then continuous on)
    2-Fast Flashing followed by slow flashing
    3-Continuous change from Fast to slow flashing rate
    4-Flashing disabled
    Number of Flashes: 1-20
    Flash rate: 1-8
    Repeat programming:
    1-Disabled
    2-Repeat after 4 sec
    3-Repeat after 8 sec
    4-Repeat after 12 sec
    5-Repeat after 16 sec
    6-Repeat continuously
  15. #115
    West of Philadelphia, PA
    '00 Z3 M Coupe +...
    This sounds very promising. I will look forward to seeing how the install works. I am interested in your retrofit with this new functinality!
    Chris
    1999 M Coupe, Evergreen
    2000 332 iT 6 spd RWD S54 Sport = DD, Orient blue
    Past: 1998 540i 6-speed, Estoril Blue (BMW Individual) - New home in Iowa
    Past: 2000 M Coupe, TiAG - New Home in Austin, TX
    Southeastern PA
  16. #116
    Feb 2001
    Dallas, TX
    2000 M Coupe - 2014 435i
    Robb, can I get on the list for the next unit you have available? Thanks.
    -Joe
  17. #117
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by QuestMCoupe View Post
    Shoot me some photos of your light and you'll be the next in line. I have everything I need to do it but haven't had the time to assemble it. PM me any questions and let me know if you want just a light or the flasher etc etc.
  18. #118
    Feb 2001
    Dallas, TX
    I will get some photos this weekend. Thanks.
    -Joe
  19. #119
    Oct 2007
    VA
    00 Mshoe
    Your light is ready to ship Quest.
    I also pulled mine again today and added this:
    As soon as I'm running again I'll see about getting some video.
  20. #120
    Oct 2007
    VA
    00 Mshoe
    Bump! One still sitting ready to ship as of right now... where are my impulse buyers at?! If ordered soon, I could likely have another one ready to go for anyone attending Schuh that would want it hand delivered!
  21. #121
    Oct 2007
    VA
    00 Mshoe
    bump, a few bites but no one's bought the one ready to ship yet. First come first serve that can get me good photos of your existing light!
    Thanks!
  22. #122
    '00 Z3 M Coupe +...
    bump, a few bites but no one's bought the one ready to ship yet. First come first serve that can get me good photos of your existing light! Thanks!
    Holding out for the deceleration controlled pulsating solution, if that works out for you.
    Chris
    Southeastern PA
  23. #123
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by EBlue540 View Post
    It's all installed, just waiting for the Coupe to be running again. Oil filters show up today which should get me mobile, but I'd prefer to leave the underside apart till I have the oil cooler mounted and lines ran before taking it out. Schuh will likely have Video's captured.
  24. #124
    Oct 2007
    VA
    00 Mshoe
  25. #125
    Oct 2007
    VA
    00 Mshoe
