Page 7 of 8 FirstFirst 12345678 LastLast
Results 151 to 175 of 193
Thread: E39 540I Jaguar supercharger install
  1. #151
    Milford, MI
    2000 M95 325is NASA GTS2
    Yes I do.
    2001 540it manual Solomon
    1995 525i Edy
    2003 525it manual Jeff
    2002 540ia Kruse
    1999 540ita Battle Wagon
    2000 M5 Hazel
    1999 540i sport
    1997 Z3 - BubbaZ
    2017 M240i
    1995 325is NASA GTS2
  2. #152
    Nov 2014
    nh united states
    1986 e30 coupe
    Hey toolman, I'm trying to find your email in your information but it will not take me to the page. I'm interested in your supercharger setup. Would like to put it in my E30
  3. #153
    Connecticut
    BMW
    @toolman2, have you tried fitting on E38 yet? I am really interested in conservative boost (like around 5-8 lbs of boost) for reliability.
    Current
    '03 BMW 330i ZHP alpine white on tan interior (daily)
    '01 BMW 740iL Anthracite metallic on black interior (project)
    '03 BMW 530i automatic (california car) (summer car)
    and few others
    Sold
    '03 BMW 330xi
    2001 BMW M5
    2000 BMW M5
    2000 BMW M5
    1998 BMW M3/4/5 S/C'ed
    2002 BMW M3 SMG
    2002 BMW 330ci
    2002 BMW 525i 5 speed
    and list goes on
  4. #154
    Nov 2014
    Clarkston michigan
    99 e39 540I supercharged
    DeafM5 I haven't personally but a few others have. The only obstacle is getting around the right side cabin filter.
  5. #155
    Nov 2014
    Clarkston michigan
    PROJECT UPDATE; I've joined the twin disc club after my phase 2 M5 clutch passed away. 20180802_163347.jpg20180725_093758.jpg
    UUC has a very nice kit, a bit more pedal effort and you get the trans rattle but ohh how it holds...
  6. #156
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    holy shit toolman lives
    i guess that was his two posts for the year, back to hibernation
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  7. #157
    Nov 2014
    Clarkston michigan
    Ha HA, Ya I'll see if can get on here more this year...Sooo at 13# boost and the new clutch it's truly a blast to drive and fights for traction through 3rd gear. This spring the only thing to do is crank up the boost to 15 or so and see how it likes it.
  8. #158
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Toolman is back!! Keep up with the updates! Crank up that boost! I also went the UUC twin route. Holds whatever I throw at it. Nice kit. I do get some engagement squeal here and there on aggressive starts though, but its not that big of a deal. Totally fine as a daily driving clutch.
  9. #159
    Mar 2019
    Ladson, S.C.
    1997 540i 2011 328i
    Good Evening! I hope you are doing great and thawing out!
    I have a '97 540i m62 build date 3/97. Already have m112 sc and coolers from a Jag 4.0l.
    How much is the adapter setup that you fabricate?
    All The Best,
    Frank
  10. #160
    Nov 2014
    Clarkston michigan
    Philly I'm getting that same squeel every now and then... sounds like tires squeeling. wonder if this is characteristic of the twin disc ??
    Frank pm'd you. This works well with the earlier engines but adds some complexity to the install as you will need to use the jag throttle body (or aftermarket)and adapt the air-idle.
  11. #161
    New York
    M625CSi
    Smile Jag supercharger on M62TU
    Quote Originally Posted by Toolman2 View Post
    Just picked up a black/black E38 740i sport and at 151,000 miles as I'm looking to do the timing chain and guides,... Supercharger time
    Any chance the machined pieces are still available for this?
    What would I need to provide?
    Thanks in advance!
    Chris
  12. #162
    Nov 2014
    Clarkston michigan
    Chris you will need a complete Jag setup for the 98-03 XKR-Xk8 4.0 and me an email at toolmanselberg@aol.com.
    Steve
  13. #163
    May 2018
    Uk
    I guess if money wasn’t important you would go with a Whipple, then you can get the correct front inlet.
  14. #164
    Nov 2014
    Clarkston michigan
    Easily said, but without a cast intake intercooler system it's not feasible, But by all means give it a try.
  15. #165
    Sep 2017
    ontario
    2002 540i 6spd m sport
    Toolman2 are you still using the Cartech RRFPR at 13PSI?
  16. #166
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I stopped using my rrfpr, and am now using just boost pressure to the fpr, it's smoother but still wrong, melted my precats under heavy use.
    And 13 psi is not right, it's around 38 psi
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  17. #167
    Sep 2017
    ontario
    Sorry I was referring to 13psi of boost pressure that he said he was pushing. (I know vortech doesnt recommend use of FMU's past 10PSI)
    I agree that 38psi fuel pressure sounds right at idle.
    1999540im --> Were you using the BeGi/Cartech style or a Vortech style regulator? (I plan to go vortech style)
    Can you give more insight as to why its "still wrong?" I imagine your going Lean now on your AFR guage? How lean? How rich were you before with your regulator on? What setting/disk size did you try?
    What does your fuel line system look like now?
  18. #168
    Milford, MI
    The DME for our car, ME 7.2, has finally been cracked. Thought people interested in Toolman's set-up would be interested in this development. See info here:
    https://github.com/zarboz/BMW-XDFs/wiki
    and Zarboz's thread here;
    https://www.bimmerforums.com/forum/s...7.3+tuning+e39
    Of course I personally do not have the skills to do anything with this information, but I would be interested in talking to anyone that does. Anyone in the Detroit Metro or on this thread willing to work on this?
    Thanks,
    Eric
    1995 525i Edy
    2002 540ia Kruse
    2000 M5 Hazel
    1999 540i sport
    1997 Z3 - BubbaZ
    2017 M240i
  19. #169
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    I'm running a toolman setup and would love to have better control using the 7.2 but it doesn't seem to be able to support boost.
    Sent from my SM-G930F using Tapatalk
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
  20. #170
    Milford, MI
    Hi Kenny,
    See post #11 of Zarboz's thread. Based on this, I believe the DME will support boost. Again, I'm a complete noob when it comes to ECU programming, only pointing people to pertinent information I'm finding.
    Are you currently running stock ecu with jag injectors + FPR? How does it run and have you dyno'd it?
    Eric
    1995 525i Edy
    2002 540ia Kruse
    2000 M5 Hazel
    1999 540i sport
    1997 Z3 - BubbaZ
    2017 M240i
  21. #171
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by rxcess View Post
    Sorry in advance. But.
    That is a GROSS overstatement and oversimplification.
    The E46 M3 DME has 100x more info available in the public domain and even that is fairly challenging to leverage and tune. But maybe you can say that is “cracked” after 10yrs of Open source work on it.
    Not so ME7.2.
    An accurate statement would be “Some information about a limited subset of tables in the ECU are available but it is very challenging to leverage, as plenty of information is missing, some of what is published has errors, and exact logic flow and modeling through the ECU is not publicly documented .”
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  22. #172
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Not so ME7.2.
    With that knowledge and your new endeavor, can you tune my project?
    I'm coming up empty.
    Not enough room for past/present garage
  23. #173
    Sep 2017
    ontario
    Quote Originally Posted by Kenny1958 View Post
    Hi kenny I have recently got my setup running and out of the garage. Its running incredibly rich at idle with a adjustable fuel pressure regulator and FMU style fuel system. I wanted to ask if your running a similar tuning setup and what your fuel pressure is at and so on.
    I currently have my regulator as low as it will go at 30psi idle pressure and still idle at 10.6-11.5 AFR.
    Trying to get a check list going for causes...
  24. #174
    Nov 2011
    Derby UK
    Quote Originally Posted by scotrod View Post
    Hi Scotrod
    I've not been using the adjustable regulator, i used the jag regulator and the tuner did some corrections to the fueling. i'm idling and cruising at 14.7 with the standard bmw fuel pump.
  25. #175
    Jun 2020
    Connecticut
    1995 540i/6
    How can I order an adapter plate off of you? What’s the cost and how long would it take to receive? Is there any way I can contact you
