Page 3 of 8 FirstFirst 12345678 LastLast
Results 51 to 75 of 193
Thread: E39 540I Jaguar supercharger install
  1. #51
    Jul 2013
    Atlanta
    95 e34 540i/6
    I've been watching this thread since it started and really liking the progress! Not to high jack the thread but what do you think about the cts-v supercharger, like this one:
    http://pages.ebay.com/link/?nav=item...770613&alt=web
    What's nice about this one is that the throttle body mount is up front instead of in the rear.
    Keep the pics and progress coming!
  2. #52
    DeWitt, Michigan
    '97 540i/6, '97 328i
    For a non-intercooled setup, those CTS-V blowers look sweet!
  3. #53
    Nov 2014
    Clarkston michigan
    99 e39 540I supercharged
    I actually tried the m122 from the sts but even after extensive modifications it wouldn't fit under the hood.
    They have intercoolers built in to the top.
    I'm working on putting the larger rotors in the m112 case.
  4. #54
    Jul 2013
    Atlanta
    95 e34 540i/6
    Quote Originally Posted by Toolman2 View Post
    That one has the throttle body on the back. The one I referenced had it on the front. Wonder if the height difference is different?
  5. #55
    Bozeman, Mt
    e36/8, W201
    Very nice work! I'm loving the clean install. I just picked up a M90 from the local auto salvage for cheap and I'm going to do a budget build on my Mercedes 190D and I'll be lucky if it looks (and maybe works) half as good as yours does.
  6. #56
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    I'd love to see a dyno graph to see how this set-up performs.
  7. #57
    Nov 2014
    Clarkston michigan
    Good luck on your install! Boost really the way a car feels.
  8. #58
    Nov 2014
    Clarkston michigan
    Here is the eaton m112 with the longer m122 rotors installed. It effectively rebuilds the supercharger while adding displacement. Along with the rotors I also had to use the m122 snout and replaced the rear roller bearings. We shall see how it works after the snow gets out of here.
  9. #59
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Looks good. How much more flow do the bigger rotors provide? Any plans for a dyno soon?
  10. #60
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    I also notice that you have changed the style of the bracing for the idler pulley, which looks stiffer now.
  11. #61
    Bucks County, PA
    '15 MB GL
    Quote Originally Posted by excelsisba View Post
    I've been watching this thread since it started and really liking the progress! Not to high jack the thread but what do you think about the cts-v supercharger, like this one: http://pages.ebay.com/link/?nav=item...770613&alt=web What's nice about this one is that the throttle body mount is up front instead of in the rear. Keep the pics and progress coming!
    That's a tvs1900.
    The tvs2300 for the Hemi's also has front TB.
  12. #62
    Nov 2011
    Derby UK
    I`v also gotta say that is one nice lookin V8 engine with that charger there. My cool chargers don`t say supercharged on them but i could easily swop them locally for ones that do.
  13. #63
    Nov 2014
    Clarkston michigan
    Quote Originally Posted by philly98540 View Post
    Thanks philly. 9% by volume and i'm thinking 5-10% for the tighter clearance. We will see in a few days when the snow melts.
    Thanks Kenny, I remade the idler pulley bracket. It had a little too much rap and actually rubbed together as it was running. so I made the latest version a little different.
  14. #64
    Mar 2015
    california
    1998 BMW M3
    This is my build thread on my 99 e39 540. I first replaced the fuel filter with a pre 99 filter without the regulator and ran a return line from there to the new reg. and fmu. I removed the intake and the wiring harness from the plastic shrouding, and pulled the 7mm intake studs from heads. I seperated the wire harness into three sections. right and left banks for coil and injectors and everthing else down the middle. I did have to splice about six or seven wires to make them long enough to do this.
    Here is the adapter bolted to head
    And the jag manifolds
    The intercoolers and fuel rails are installed.
    And supercharger slid into place.
    Nice !! Looking forward to this thread!
  15. #65
    Nov 2014
    Clarkston michigan
    It's been awhile so I thought I'd give you guys an update. The M122 rotors made it so responsive now first gear is absolutely useless, Their is so much torque it's a blast to drive. With the bigger blower it's now pulling some timing back to 19deg so I know there is more power still on the table. I installed a water/methanol injection to keep it safe and once I get dialed in I'll get it on the dyno.
  16. #66
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Sounds very good. Any thoughts / progress on making parts for sale? About the only thing I would have different for this setup would be having it just truly native tuned and ditching the RRFPR, which personally I just don't like. And maybe routing the intake down into the front fender a la all the other centrifugal kits and the Dinan CAI system.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  17. #67
    Nov 2014
    Clarkston michigan
    Geargrinder I have several kits ready to go now. The way I'm using the FMU is starting at a lower pressure for idle and part throttle to accommodate the larger injectors and rising to normal pressures on boost. I don't like throwing high pressures at injectors for fueling either. If there was somebody in my area that could tune the BM dme I would let them at it. I like the idea of running the filter behind the bumper and plan on doing that soon but now with the snow system the intercoolers are actually cold after getting on it so not sure if it will help any.
  18. #68
    Mar 2010
    Wow - cool - didn't know you were ready to set others up yet. Do you have another thread etc? I know we are prob OK so far but sooner or later we are in sticky territory vs being a site sponsor... I know the RRFPR is a practical solution and sounds like the build running solid - just saying yea ideal will be when you can get the setup to a good tuner... Maybe some time you can get there or can find a tuner to fly in to do the job (becomes an even more worth while idea if you are selling parts so you can sell an finely tuned DME flash to go with it...)
    2003 M3CicM6 TiAg
    Former:
  19. #69
    Jun 2003
    Raleigh NC
    03 M3T, 03 M5T/SC, 01 M5
    Very cool project.
    2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
    2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
    In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
  20. #70
    Nov 2014
    Clarkston michigan
    Under hard acceleration I'm getting an awful noise from the drive train. I think the drive shaft coupler is hitting the tunnel. Anybody else have to control rear end housing with different bushings?
  21. #71
    Apr 2003
    Back in Hunt Valley, MD
    96 ACS S3 CLS, 02 540iA
    Awesome work. Saw your posts over on BimmerBoost as well. The "kit" looks great. Definitely interested in following your footsteps sometime in the future (looking to pick up an E39 540iT soon), but would definitely want to have the ECU tuned instead of the use of an FMU for additional fueling, etc.
    So, you have this installed on an engine with a stock ZF 5HP24 auto trans? How is the trans holding up so far? Any idea what kinda power the car is putting down now with the M122 rotors and the meth injection?
    My car will be an auto (daily driver/family car that the wife needs to be able to drive as well) and the thing I would worry about the most is how the stock auto tranny will hold up.
    I assume you've checked the guibo to see if it's worn, etc? Can't imagine that anything down there is close enough to the tunnel to make contact even with the increase in power...unless something down there (guibo, trans mounts, center bearing, diff mounts, etc) is worn and allowing excessive play.
    Alvin Caragay
    Mpire Automotive (https://www.facebook.com/MpireAutomotive/)
    '96 AC Schnitzer S3 Sport CLS Replica (https://www.facebook.com/ACSS3SportCLSR)
    '02 E39 540iAT
  22. #72
    Jun 2015
    uk
    m1
    I did the machine work myself and bought the Jag parts on line. I have a magnaflo on mine sounds good but dont like the drone.
  23. #73
    Houston
    2001 740il
    Quote Originally Posted by vbhkvjhi View Post
    a write up would be nice or at least make some adapter manifolds for sale.
  24. #74
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Zedbimmer View Post
    Don't think your going to get much from that guy. He isn't even real.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  25. #75
    Mar 2010
    Quote Originally Posted by Butters Stoch View Post
    That's OK. Zed wants a totally unreal setup anyway.
    2003 M3CicM6 TiAg
    Former:
