Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 193
Thread: E39 540I Jaguar supercharger install
  1. #101
    Milford, MI
    2000 M95 325is NASA GTS2
    PM'd you
    2001 540it manual Solomon
    1995 525i Edy
    2003 525it manual Jeff
    2002 540ia Kruse
    1999 540ita Battle Wagon
    2000 M5 Hazel
    1999 540i sport
    1997 Z3 - BubbaZ
    2017 M240i
    1995 325is NASA GTS2
  2. #102
    Jun 2017
    Kenosha, Wi
    99 540i
    Toolman, would you be interested in fabricating another adapter plate for the same supercharger build? I am very interested in buying one. Thanks!
  3. #103
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    ------ gakkk -----------
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  4. #104
    Jun 2017
    Kenosha, Wi
    99 540i
    Quote Originally Posted by Toolman2 View Post
    Thanks everyone for the kind words. Not sure what's up with the pics.
    This was a build I did last spring but decided to pull it apart, make a few changes and do a thread.
    Basically everything bolts together like jaguar intended, I had to change the bolt pattern on the intake plenum for the throttle body so it would bolt up and firewall clearance was limited but it all fits well and runs amazing.
    I used 3 1/2 in. reduced from a 4 in. mass air meter. I rapped it with thermal blanket cause it was getting heat soaked after a long drive. I think I will run it into the lower bumper.
    Would you be interested in fabricating another adapter plate for the same supercharger?
  5. #105
    Mar 2010
    DOH. Thread confusion. I thought this was Wagons current thread/build, sorry. Different guy/setup/etc.
    2003 M3CicM6 TiAg
    Former:
  6. #106
    May 2015
    Dallas,Texas
    98 E39 540i sport
    Bump , would like to see vids of this beast pulling
  7. #107
    Jun 2017
    Baltimore
    BMW M3,2000
    That's for sure
  8. #108
    West Coast
    two 3's one 5 three 7's
    Quote Originally Posted by 99Bimmer540 View Post
    I'm also interested if there is a kit for this Jag modification. Toolman - can you update us if you are offering kits for those who are looking to buy?
  9. #109
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Quote Originally Posted by whiteghost1 View Post
    Email him, they should still be available, it's a fun project
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  10. #110
    Mar 2010
    Quote Originally Posted by 1999 540i m View Post
    Yeah. Toolman isn't a vendor so he can't advertise, and, seems to want to keep a lo-pro on his for sale items and pricing anyway.
    2003 M3CicM6 TiAg
    Former:
  11. #111
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    i'm still interested in the experiments going on over at bimmerbosted of using a newer more compact jaguar blower with a forward facing throttle body, something to keep an eye on for sure.
    http://www.bimmerboost.com/showthrea...981#post755981
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  12. #112
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Toolman2 is kind of Ghost which never apear....))))
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  13. #113
    Jun 2017
    Kenosha, Wi
    99 540i
    Sorry, Autowerke active programmable ecu sold by Urotuning.com
    Sent from my A571VL using Tapatalk
  14. #114
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Looks like you always being tunned by them))))
  15. #115
    Mar 2010
    That seems to be an answer for a question that wasn't asked?
    2003 M3CicM6 TiAg
    Former:
  16. #116
    Nov 2014
    Clarkston michigan
    99 e39 540I supercharged
    Quote Originally Posted by dovlet View Post
    I'm back...
    So i had this extra sts blower sitting around and thought i'd see what the newer design with the larger inlet, possibly improved intercooler, and larger and straight ports would do and if it would actually fit under the hood. The port shape and spacing wouldn't work at all so they were cut from the casting. I made die to form runner tube halves from sheet and welded them together, this way i could form a taper for the intake runners
    20170908_001126.jpg 20170911_223843.jpg and ended up with this 20180128_170357.jpg
  17. #117
    DeWitt, Michigan
    '97 540i/6, '97 328i
  18. #118
    Jul 2013
    Worcester, MA
    sts blower? cool
    but i think at that height, it's less about fitting under the hood and more about how big of a hole you'll have to cut in it for the blower to fit though
    GN92489
  19. #119
    Mar 2010
    Crazy?! Is he saying that it actually DOES fit? Looks HUGE on the mockup motor but if thats it in the engine bay, doesn't look so bad!?
    2003 M3CicM6 TiAg
    Former:
  20. #120
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Impressive job on the runners! From here, it looks like it will fit with the hood closed. What throttle body?
  21. #121
    Nov 2014
    Clarkston michigan
    Technically it did fit...20171214_181602.jpg but i ended up cutting the motor mounts and welding them so the motor set 1/2" lower.
    The STS and the M62 throttle body are basically the same.
  22. #122
    Mar 2010
    Technically it did fit... but i ended up cutting the motor mounts and welding them so the motor set 1/2" lower
    Oh well then as long as it’s just an easy breezy bolt on situation...
    2003 M3CicM6 TiAg
    Former:
  23. #123
    Nov 2015
    Miami, FL
    2001 325i
    That is some impressive work, how is it performing?
  24. #124
    Nov 2014
    Clarkston michigan
    Thanks you guys for the compliments. It's been a lot of work!!!! I've only had had a couple of days i could test and tune with all the snow here in Michigan and with the salt on the roads traction is limited so i can't say if there is an improvement over the XKR setup but hey i'm just happy it works at this point.
    I had a problem with heat soak on the old system and noticed the cheapo coolant pump was kapoot! Heres a pic of the new ZL1 pump verses old dead pump. Made a huge difference!
  25. #125
    Nov 2011
    Greedland
    That is absolutely awesome!!
    What are you doing with your old m122 supercharger?
