Page 28 of 31 FirstFirst ... 31819202122232425262728293031 LastLast
Results 676 to 700 of 755
Thread: State of the mod: M5 cluster -> 540 (yes, I've read the old threads)
  1. #676
    IL
    2000 740i sport
    Quote Originally Posted by Dvbimmerk View Post
    Blacknight530 did my cluster. It’s from an X5 4.6is. Works perfectly in my ‘02 540iT.
    Why is your oil temp so high and on cold the rpm lights should be full?
    Sent from my SM-N910T3 using Tapatalk
  2. #677
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by purplecty View Post
    Yeah, something isn't right.
    Has it always been that way dvbimmerk?
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  3. #678
    Philadelphia, PA
    2005 M3 & 2004 330i
    Seems like the DME might not be flashed with the right software? I feel like I remember the stock software reading oil temps too high back before we figured out how to do this. Hard to google now since this thread is what comes up.
  4. #679
    IL
    2000 740i sport
    Quote Originally Posted by TerraPhantm View Post
    I think at least on the e38 the oil temp didn't register at all...
  5. #680
    Philadelphia, PA
    2005 M3 & 2004 330i
    Found it: https://www.bimmerforums.com/forum/s...4#post28323084
    Facelift E39 is different. They run the right software and do send data to the cluster, but the maps to determine the values are filled with junk. My software corrects those maps so that the temperature reads correctly and the lights turn on/off at the right time.
  6. #681
    Nov 2010
    Charlotte, NC
    I'm thinking when I flashed his DME, it was probably from my desktop computer that hadn't had the files replaced yet like my laptop. It has been updated now, so dvbimmerk should send me his DME again so I can fix it, or if he has WinKFP working, one of us can do it remotely.
    -Paul
  7. #682
    Jan 2017
    CT
    2011 750Lix M sport
    Quote Originally Posted by blackknight530i View Post
    Sorry just got around to reply. Everything worked properly when you flashed it. I then had Dinan Stage 3 engine and tranny software installed and it must’ve cancelled out what you flashed.
    Tbh I wish I can get it to work again however I don’t want to undo what the Dinan software did. (In addition to dismantling the dash again lol) Perhaps someone out there knows how to reflash it while keeping the S3 software intact?
    Any help would be appreciated...thanks.
  8. #683
    Nov 2010
    Charlotte, NC
    I'll let Terra chime in, but the only person I know that can add the function to a Dinan tune is DUDMD.
    -Paul
  9. #684
    Philadelphia, PA
    2005 M3 & 2004 330i
    If the Donna software is based on the newest program version, I can probably build it.
  10. #685
    Nov 2010
    Charlotte, NC
    Looks like it is if it's sending junk info, right?
    -Paul
  11. #686
    Philadelphia, PA
    2005 M3 & 2004 330i
    Could theoretically be on an older program that still has those subroutines. Wouldn't be impossible to modify that, but I'd have to figure out the changes again (and it's been long enough that I don't remember all the details).
    I doubt Dinan flashes old program versions though, so it should be fine.
  12. #687
    Nov 2010
    Charlotte, NC
    I found your changes back on page 5 I think.
    -Paul
  13. #688
    Jan 2017
    CT
    2011 750Lix M sport
    Hey guys thank you for all the information. Just let me know what I need to do if I have to send it out to either one of you guys… It is certainly appreciated.
    I had the Dinan installed about four months ago so I would suspect that the programs are fairly up-to-date. I will be at the dealer on Friday and I can ask the tech that did the install (who I know fairly well) about the oil pressure flash maybe he has some thoughts and can do it for me there...
  14. #689
    IL
    2000 740i sport
    Doubt the dealer can get the oil temp working properly...
  15. #690
    Jan 2017
    CT
    2011 750Lix M sport
    Spoke with dudmd and he said that he can flash the ECU with his tune remotely to work with my Dinan hardware and his program and the oil temp would also function properly. He said I would need to reflash the cluster back to pre-Dinan status.
    Can this reflash of cluster be done remotely?
    (Please pardon any incorrect terminology as I’m no software/tuning expert lol)
  16. #691
    Philadelphia, PA
    2005 M3 & 2004 330i
    Cluster shouldn't have to be touched at all (and wouldn't have been touched by the Dinan software).
  17. #692
    Jan 2017
    CT
    2011 750Lix M sport
    So does DME need to be reflashed? Or what needs to be done to get it back to when blacknight530i shipped to me and oil temp was working? And can this be done remotely via TeamViewer with OBD cable?
  18. #693
    Nov 2010
    Charlotte, NC
    Nothing needs to be done to the cluster. Only the DME gets modified. I think DUDMD is saying that he has his own tune that works with the Dinan equipment already on your car, but is one he made. He's likely telling you that you need to flash the DME back to stock before loading his tune.
    What Terra is saying is he can modify the existing Dinan tune to work with the m5 cluster, which would save you a lot of money and keep you from buying a whole new tune after just spending a bunch on the Dinan tune.
    I could be wrong though, so I'll let him confirm.
    -Paul
  19. #694
    Jan 2017
    CT
    2011 750Lix M sport
    Yes this is exactly what he said.
    That would be fantastic if possible. Please let me know and we can work out details.
    Thank you both for all of your help...
  20. #695
    Philadelphia, PA
    2005 M3 & 2004 330i
    Read out your tune with galletto, and I'll modify it
  21. #696
    Phoenix, AZ
    1999 328i -2000 323i
    I spent about 12 hours figuring this out on my own to find this thread the next day. guess I'm about 3 years late
  22. #697
    Feb 2015
    Norway
    00 540IAT, 93 530D
    any solution for Euro 540ia?
  23. #698
    Feb 2015
    Norway
    00 540IAT, 93 530D
    PM
  24. #699
    Feb 2015
    Norway
    00 540IAT, 93 530D
    Either I’m stupid or can’t read.
    Trying to see if there are a solution to euro 540i auto, I have seen a solution for manual euro 540i but none so far on autos
  25. #700
    Philadelphia, PA
    2005 M3 & 2004 330i
    I haven't made one for Euro 540iA. Euro E39s never came with the right program version to support the oil temp / warning lights, which makes it a bit more complicated. Best would probably be to take the X5 software and edit the relevant values for the E39. But it's not something I feel like pursuing myself at the moment.
