I bought an '08 M-Sport in September and have been chipping away at some of the maintenance items. As far as I can tell I have replaced everything that needed it and still have a few strange symptoms.
What I have done/had done (ie. new parts - shouldn't be the issue anymore):
- VANOS Solenoids
- New electric water pump ($$ ouch)
- New expansion tank, thermostat & hose
- New belts & tensioners
- 2 New ignition coils (they were showing faults and i have 6 working now with no faults)
- New gaskets on Oil filter housing and oil cooler
- Transfer case oil change
Lastly, I did the manual reset of the transmission "learning system" or whatever and noticed SOME improvement, but I still have a few odd things happening.
Here are my symptoms:
1. At idle, I get an intermittent shaking while RPMs dip from ~700 down to ~600 then back up again. It is noticeable for my passengers, and feels like something is wrong - but no engine code or fault. The timing of the dips are different every time, but it happens ~60-80% of the time when I am stopped (at red lights, starting the car for the first time, etc.) - no RPM fluctuation whatsoever at any speeds >5mph. This seems to be more of an issue while in Drive vs in Park of Neutral.
Here is a video of the idle issue, I did this while not moving, changing from Park, Neutral, and Drive, but all while not moving. The RPM movement seems small on the video, but you can definitely feel it throughout the car. - I have since refilled the washer fluid and that indicator has gone away
2. Secondly, sometimes the throttle response is either extremely delayed or non-responsive entirely. This is only an issue when there is significant load on the engine - like going uphill and trying to downshift - the transmission refuses to downshift and the pedal just goes all the way to the floor with no response, then a few seconds later, it seems like the transmission catches up and downshifts pretty harshly. I try and avoid letting that happen, and when I detect no throttle response, I back off and try again - sometimes it cooperates and downshifts as directed.
3. Lastly my cruise control will sometimes shut off entirely. I will set the cruise control with feet off the pedals and it will disengage with no direction from me.
I am not getting any engine codes, and an independent shop near me said the next steps would be 3+ hrs of just investigating to find the issue, and they said if it drives now, they wouldn't recommend it until something happens.
I would prefer to be proactive about this kind of thing, so if anyone has had a similar experience, and has an idea of where to start I would be very grateful!
(Sold) 1997 2.8L Z3 Roadster (M52) - Atlanta Blue
2008 X3 M Sport AT (N52) - Black Sapphire
Id throw this up on bimmerfest.com X3 section, a lot more traffic over there. Without being able to see the video (due to work blocking all that stuff), sounds like a vaccuum leak or fuel pump/filter issue? Just a shot in the dark, hopefully someone else can chime in. I remember when my E46 3-series rpm would bounce all around it was due to tear in the intake boot. Not sure if those newer engines have that or not.
2016 328ix | Wagon | M-Sport | Alpine White | Black | iND | 513M | AC Schnizter | MPerformance |
2005 330CiC | Sparkling Graphite | Black | 6MT | ZHP
2004///M3 | Individual Sterling Gray | Imola Red | 6MT | Eisenmann | Style 163M | SOLD
2011 X5 35d | Black Sapphire | Nevada Brown Cinnamon | Sports Package | Totaled
2009///M3 | Interlagos Blue | Pallidum Silver | DINAN | MPerformance | DCT | SOLD
2002///M3 | Steel Gray Metallic | Imola Red | 6MT | Convertible| SOLD
2006 X5 4.8iS | LeMans Blue Metallic | Creme Beige | SOLD
2006 ///M3 | Silver Gray | Black | Competition Package (ZCP) | 6MT | SOLD
2000 ///M5 | Oxford Green Metallic II | Caramel Nappa Leather | BMW Individual Black Birch Trim | SOLD
2003 X5 4.6iS | Black Saphhire Metallic | Black Sport | SOLD
2006 X3 3.0i M-Sport | Silver Gray | Terracotta | SOLD
Wild guess is the idle is a vacuum leak. A can of starting fluid or electronics cleaner sprayed around the intake etc. Will find it if that's the case.
Johno
-- 2003 e46 M3
-- 2018 e90 M5
-- Warm memories of 99 M3 w/ Eurosport Twin Screw, 2007 335i, 1970 Cutlass, 1989 328is, 1990 328i, 2012 S4, 2018 S4
