Just wondering if anyone have installed NBT in an E31? Hopefully getting a 1999 840ci soon....wondering if it can be done.
so i have a question about the evo harness,i have the evo touch setup with screen,i bought the touch controller module, when i hook it up will the harness for the idrive touch controller be intergrated in the main harness or will i have to purchase it .
Yes
'02 TiAg/Blk E39 ///M5
'08 JZB/FR E92 ///M3
so the CS ATM emulator arrived yesterday as well as the touch moduler,waiting for the evo, screen and controller, due in today!
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
part # is 6816387 02 production date is 1-11-17. i put it on ebay. have to get the part # for the screen you are refering to..jeez!
subscribed for the bezels and console for E39s
i decided to do a little investigating on the f15 evo screen,took it apart and found that it has two screens.the first with the non glare coating and the innerscreen.they are both connected by a foil type ribbon connector and it seems that it is about 10.25 minus the frame but i didn't take it all the way apart because it seemed very fragile and i was'nt that confident in what i was doing. shifting subjects for a moment..would it be better to use the amp that came from the donor evo car, or the e38 oem dsp amp? i have an opportunity to get the donor amp.
What is necessary for a 10.2" retrofit? Which cars can I take parts from? From what I've read I need:
BMW Microphone
iDrive Controller
NBT Emulator (http://www.ebay.com/itm/BMW-NBT-Navi...1WAMhl&vxp=mtr)
Display
Video cable from trunk to dash
BT Antenna
USB / AUX panel
Custom Bezel
NBT Unit (trunk)
I don't think that emulator will work. That auction looks like its for retrofitting into newer cars. If you have a 99 528i as your sig suggests then you will need an Ibus nbt emulator and I think the only place that sells them is Bimmerretrofit. I would try to contact carsystems however they may be able to help you. Also dont forget the gps antenna and a universal hsd (high speed data) cable http://www.ebay.com/itm/For-BMW-CIC-...53.m1438.l2649 to run from the trunk to wherever you decide to put your usb panel
Don't buy sh!# from bimmerretrofit
Well i got the f10 screen mounted using the oem e38 bezel, now im looking at idrive placement...making progress!
Argh - the emulator has been behaving since I unplugged the camera (when plugged in it was causing the black screen) which was annoying but got used to it but today no changes it shut off again - anyone had any experience with this??? Any ideas? All spare wires are taped up and connections tight
Hey guys,
I have acquired a new unused NBT Evo, and would like to transfer the FSC codes from my crashing ID4 flashed to ID5. I have used the function GetFSC to get the FSC codes for each app number, but I am unable to use the functions GetFSCCert and GetSIGCert. FSC comfort mode shows FSCCertStatus unavailable. Is there any way in which I can use these to activate my new NBT Evo?
Alternatively, does anyone know a seller that sells the enable codes?
http://www.ebay.com/itm/BMW-Round-17...-/361061149115
Do I need this if I have the 17 pin connector?
Crosspost:
I cannot find a good diy for this with a parts list (I have a 96 without I-bus line to trunk) and what the various options for the head unit (E38).
I pulled the wiring harness from a 2000 but am not even sure if I will need it, the nav/radio/cd changer/amp?
Edit, well got the carpet out but still not sure if i should replace harness with the one from the 2000 or just run a few more lines like a cat5e or similar?
The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
When answering my questions please use a qualifier if you are not sure.
The more I work on this car the less I respect German engineering.
When you speak in Absolutes you are always wrong!
Semper Fi
i dont think you will need the old ibus stuff,if you had blutooth , maybe the mic.
latest work on idrive console for e3820171001_013532[1].jpg20170930_165409[1].jpg20171001_133853[1].jpg i will wrap it with carbon fiber 3m dinoc matte.trust that all goes well, pics to follow
20170922_190119[1].jpg this is what i'm shooting for, basically.
