Page 78 of 109 FirstFirst ... 2853686970717273747576777879808182838485868788103 ... LastLast
Results 1,926 to 1,950 of 2722
Thread: NBT/CIC/CCC retrofit in E39/E38/E53
  1. #1926
    Feb 2016
    Kent, UK
    2002 BMW 330ci
    I got my NBT Evo back from service with Mick. It needed the firmware updating as Evos with 2GB RAM crash when running nav on ID6 without the most recent firmware. It's working much better now, but I still have a few issues to sort out that Mick's helping with.
    Using a car systems emulator with an NBT EVO in an E46. Does anyone else with this set up have issues with sat nav tracking? Primarily the input from the wheel sensors causing issues, I think the GPS reception is fine, but no service menu that I can find on the EVOs, so can't check. Also, any issues with speed volume from anyone else running this setup?
  2. #1927
    Jun 2013
    United States
    2002 E39 M5
    Quote Originally Posted by pyro225 View Post
    Shady - since doing this with your kit (albeit with issues) a couple of guys followed my diy and have ordered car systems adapters stateside from a dealer there - would that be any help to find out who?
    Thanks Dan,
    I had to purchase the adapters directly from CS. Unbelievable how I still have not heard a peep from this guy, but he's completely active on other platforms.
    '02 TiAg/Blk E39 ///M5
    '08
    JZB/FR E92 ///M3
  3. #1928
    Apr 2006
    Kingdom Of Bahrain
    04 E46 M3 JB/Kiwi
    Quote Originally Posted by theshafro View Post
    Thanks Dan,
    Why don't you message him on those other platforms.
    EURO 04 M3
    Current Mods: GC DA's, Eibach ARB's, INTRAVEE II + Alpine KCA-420i, Depo's, Screen protector for OEM 16:9 display, VCSL Bumper + Race Lip + CF Boot + CF Rear Diffusor, DIETZ TV in Motion, Z8 Starter Button, BBS CHs, Lamin-X, STORM SMG Paddles, RE RTABs/RCAs, OEM CSL Interior, OEM CSL Intake, M3 CSL HP DME, TTFS Tune, STOPTECH ST40's, FXR 3.0 Projectors, SS Stepped headers + Catless S Pipes + Res X-Pipe + Sport Muffler, OEM CSL Roof, OEM CSL Steering.
  4. #1929
    Apr 2009
    UK
    BMW E63 M6, RR L322 4.4
    Hi guys - I have a hw31 that on ista level 59 and now an hw7 on 51. On the hw7 the dab radio is coded exactly the same but I get only about 10% of the stations and they are broken up and horrible , in the hw31 they are spot on any idea?
  5. #1930
    Apr 2009
    UK
    Aside from the above strange question - do you need an fsc code to update maps with these emulators? I spent a good while extracting the 1b file then running the tool to get the activation code I plugged the flash drive in it updated successfully and never asked for a code?
  6. #1931
    Apr 2009
    UK
    Annoyingly just put a destination in sat nav got going and then it asked for the code! I didn't have it typical!
  7. #1932
    Jun 2012
    SAcramento
    2001 540i
    Hi Im having a bit of trouble getting my blutooth mic working. My car didnt come with any phone options so I bought the bmw blutooth mic, installed it in the homelink panel and I plugged my nbt harness mic wire up to what I believe is the mic header in the trunk of the car. Testing it out I can hear the call over the speakers but the caller cant hear my voice. Have I missed (additional hardware component) something? Is there something I need to do codewise in inpa or esys?
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Switch the silver wire from the mic to the open slot in the 3 pin connector. Old mics use the stock configuration, but the upgraded mic uses the other ground wire position.
    Sent from my SM-N910V using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  9. #1934
    Apr 2009
    UK
    Hi all - so my recoded dsp did not work - the only way I could get it recoded as it was in a RR was take it to local garage with autologic - the only thing they could change is the midbasis/boardmonitor setting... didn't work... bought a Philips dsp from a system with a mid and it worked but it is setup for e39 not e53 / l322... problem I now have is autologic won't code it ncs won't work in a lr so I'm trying to find someone in the uk willing to stick it in their car and code it for me for some money obviously... any one able to help?
    Failing that my plan B is to run an external amp and crossovers and bypass dsp. If I set the nbt to hifi and external amp does it output audio on all four channels or just the front like the bm54?
    Cheers
  10. #1935
    Mar 2010
    Kuala Lumpur, Malaysia
    BMW E39 530i Sport
    Hi guys,
    Just had some wild dreams on the E31. Is it currently possible to install NBT in a 840Ci? Havent seen any been done on my search..just wondering if it could be done. Any thoughts?
  11. #1936
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by johnate View Post
    Hi guys,
    It can be done, but might not be completely functional without dsc, I don't know for sure though. Not sure about mounting the screen in an e31 though.
    -Paul
  12. #1937
    Mar 2010
    BMW E39 530i Sport
    Mounting it in the dash is the least of my problem. More important if we can get it to work
  13. #1938
    Apr 2009
    UK
    Hi John - if you look on the car systems.ua website there is a version of the adapter that's universal for any car - I'm pretty certain that would work - you wouldn't get your check control and trip computer but I imagine all else should work.
  14. #1939
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    Got my kit all together and getting prepared for the installation, but was wondering a couple of things; does anyone know the BMW part number for the USB/AUX unit and does it work with the NBT properly? Also, thinking about a DVD/CD changer to be integrated, has anyone tried to replace the navigation computer (in my case MKIV) with a 6 disk changer from say an E70? It's MOST BUS so it should be able to connect up, be seen and used by the NBT.
    Doing the same on my E70 which is a bit easier than on my E38, but that is one thing that is nice, the DVD changer will still be used there with the NBT EVO I'm installing into it.
    '01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
    '99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
    '84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
  15. #1940
    Mar 2011
    Canadian in California
    Makes whoosh noises
    Anyone heard from Mick? Been over a month and no reply...sent multiple emails both from personal and the GermanIKS website. Also facebook messenger. No reply. Is he sick or something?
    1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
  16. #1941
    Jun 2013
    United States
    2002 E39 M5
    Quote Originally Posted by 740iSport303 View Post
    84109237653
    I'll be testing the AUX soon, but it should work fine.
    Quote Originally Posted by Commanderwiggin View Post
    Sucks, looks like he got you too.
    '08
    JZB/FR E92 ///M3
  17. #1942
    Mar 2011
    Makes whoosh noises
    I've had a full setup from Mick for over a year and he has always been excellent in responding to questions and dealing with issues. It seems he's fallen off the radar the past couple months. I sent an NBT EVO Sirius Unit to him for coding to upgrade my current box and the last I heard was in mid February as he was working to get it coded and shipped out. If anyone has had recent conversations with him please let me know.
  18. #1943
    Jun 2013
    United States
    2002 E39 M5
    I, too, had ordered a full setup and everything, then paid for 3 adapters and harnesses and the guy took my money and disappeared. Claiming he was too busy to even give me ETA cuz he has so many orders. Looks like he cashed out. And I don't care if I'm speculating. Many people have came into this forum to warn us about him and just had their posts deleted. He has a bad reputation on the UK and other forums as well.
    '08
    JZB/FR E92 ///M3
  19. #1944
    Apr 2009
    UK
    There is another carsystems dealer in the uk if you need one let me know - he doesn't make the looms though just the emulator
  20. #1945
    Apr 2006
    Kingdom Of Bahrain
    04 E46 M3 JB/Kiwi
    If you guys paid through paypal start filing dispute claims or say bye bye to your money....
    EURO 04 M3
  21. #1946
    Mar 2011
    Makes whoosh noises
    Something recently has happened that's for sure as I sent a newer NBT EVO w/Sirius headunit to him for coding and harness...he would respond frequently up until mid Feb. He has been operating BMW Planet in addition to Germaniks for many years reliably. Either way if anyone gets a response on anything please post it. Opening dispute to hopefully get some communication/resolution out of this.
  22. #1947
    Jun 2013
    United States
    2002 E39 M5
    Guy is a scumbag. His suppliers say so as well.
    '08
    JZB/FR E92 ///M3
  23. #1948
    IL
    2000 740i sport
    He is probably some place drinking alot of guiness...
  24. #1949
    Apr 2009
    UK
    Or in prison for selling stolen goods lol
  25. #1950
    Feb 2016
    Kent, UK
    2002 BMW 330ci
    Mick went quiet with me for a while after I sent back my unit to be firmware flashed. I got it back eventually, found that he responded best to a phone call. Used the number on his website.
    Still having issues with the GPS tracking though. Really want to get that sorted.
