-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
BMW iBus RR were from 2002 to 2004. If your RR is a 2005 model with Touch screen, then this is no BMW system, then NBT won't work unless you go for the generic iBUS enabling module, with probably no support for steering wheel buttons. Then this Logic7 amp won't work either. This has to be a BMW TOP HIFI AMP end of story. Not Range Rover, not Rover and whatever else
If you want Top HIFI From a F series, then any TOP HIFI will work. Keep in mind none of the time domain settings can be adjusted. And that like you pointed out to me before, is an issue unless it comes from a car that has the same dimensions as your car. But will be nearly impossible. a 10 cm variation can make a big difference in hearing the rear speakers or not.
Just waste of time here in my opinion. Just go aftermarket amplifier or two with standalone DSP processor. Will be far superior to the TOP HIFI Harman Kardon any day anyway.
BMW OSS Master - BMW Coding, flashing, and NBT/CIC retrofits for breakfast.
Founder of BMW Planet, serving wiring diagrams to BMW enthusiasts and independent garages all over the world since 2008
NBT installation document updated with bezel for iDrive controller in e39
http://www.bmw-planet.com/lib/BMW_NBT_iBUS.pdf
Looks good! Can't wait to get the Fascia's for my E46!
1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
Looks good Mick. Just need center dash screen bezel and I'm in.
2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
Hi,
I had a meeting with the local to me specialist capable of making high quality low number production batches of products. Making a bezel for holding the TFT panel in the E39 oem head unit location can easily be done with their on site capabilities. I mentioned this project and it's 'relative' low numbers of potential owners going for it and in response their minimum batch they'd do would be for 20 pieces. The next stage would be the design and CAD work needed. Without some initial design or drawings it's hard to get accurate costs, however I did get some 'ballpark' figures.
CAD/Design work - 'Around' the £800-1000 level (this currently equates to about $1215 to $1518 USD)
Individual Unit - 'Around' the £150-175 level (this currently equates to about $227 - 265 USD)
This would be using the correct automotive grade materials/plastics/resins and automotive grade finishing paints to ensure a very high quality product/item.
With seemingly 3 different TFT screens themselves then the reverse side of the bezel will need a method of mounting all 3 so an arrangement of shapes to do that needs to be incorporated. If there's any small sizing discrepancies then the end owner would need to use some packing material to hold the monitor in place. If it turns out there's shape and curvature differences between each potential monitor that can be used, then 3 CAD designs will need to be developed. The E46 is a totally different shape and size so this would absolutely require it's own specific piece designed.
Whilst in the meeting, I also asked about the potential about 'extending' the bezel to a full fitting kit/frame to hold the NBT unit itself in the oem dash location. This of course would increase complexity in terms of the design but it is possible. Without more information I couldn't get a ballpark on doing this ! plus, seeing as the NBT is 'sort of' traditional double DIN sized, it looks like the cabin airbox needs to be modified to make the space for it. This will increase costs if an owner doesn't have the skills or confidence to do this mod and add's I'd say £200-250 to the cost of the whole project - over in the US, I'd say a reputable shop that knows what it's doing and doesn't mess up the airbox's internal airflow flaps will charge a similar sort of amount - say in the region of around $250-400 USD.
I will ask at another specialist I know of and compare. I can then update here for you guys.
Is there any interest in perhaps taking this idea forward? So far in the thread there's perhaps 7 to 10 members seemingly already in midst of this mod or about to start with a few 'might do' members.
Cheers, Dennis!
Interesting Dennis but this mostly sorted out for cheaper price. Custom design indeed is not cheap and while this is probably a very good deal overall, very little people here will pay 400 USD for a bezel after spending 2000 bucks more or less on a NBT system for their e38, e39...
I have e46 sorted out already. Both e39 and e46 fascia are going for molding and fine sanding/painting on Monday. So I can get these made very quick.
Send pricing to me if you would via PM, Mick. Will the fascia for E39 have a mount as well? Mine is held in with some poorly fabricated but secure home-brew mounts.
What about the E38 controller mount? That's my main concern at this point.
I think there isn't any better place than this. I'm not done cutting out the hole yet but it will find it's place there no matter what
I like that it is less clunky than the others I saw yet but for my taste I would stil try to get it little bit more flat.
There is gaps with the screen, but now if you get this wrapped with leather, gaps should disappear as they are very small.
Can't blame you for trying, let us know how do you get on.
You should use hot glue gun to hold the screen behind instead of fibre glass and a self taping screw. A lot mess messy.
I use hot glue all the time, not an issue. In fact all my NBT retrofits in e6x/e7x/e9x have the radio buttons panel hot glue to the trim since it can not be attached to the NBT. Never had any issue. You were probably using low grade glue.
Gaps are from the screen itself and the radio trim.
2016-1 North America maps available if anyone needs help with this fore their NBT.
looking Nice Nick
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
