Hey guys,
Shady (@theshafro) just got me set up with the first set of e39 center console and bezel trim custom made for NBT and I couldn't be happier. This stuff looks totally factory and everything is mounted so solid that you would be hard-pressed to tell that this didn't come from the factory way back in 2003. I have the piano black (a bit of metallic in it) trim in my car and he matched the paint perfectly. The e60 hazard and central lock buttons work great and look even better than the stock ones. To say I'm impressed with the build quality is a huge understatement. You should all be lining up to get a set of these, I really mean that. The bezel looks like a completely OE piece and fits the dash like the original nav screen would. There is a bracket for the screen to mount it in the stock bracket, then the bezel sticks on with magnets. It sits flush with the dash as it should and is way easier to install than the method I had been using for the longest time.
There are a few caveats to installing it, but they are easily overcome. You might want to purchase a used center console piece so you don't have to modify your original one, in case you want to sell it or keep the original. I got one at a local pull a part for $10. You'll need to cut it down to just leave the back portion from the edge of the wood/plastic trim back. If you use a wood console, I highly recommend removing the wood first from the base, because this will allow you to cut off the tabs and such cleanly with a dremel without risking making a rough edge that meets up with the new console. Other than that, there is no custom modifying of any stock parts. He even supplied a custom wiring adapter for the two plugs for the hazard and central lock to go into a single plug for the new switch. I don't know if that is planned for his kits, but I would think it would.
Ok, on to some pics:
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
2006 Porsche Cayman S - Soul Performance Competition Headers and Exhaust, H&R Coilovers, 718 Boxster Spyder wheels, Rennline 35mm rear spacers
Very nice Paul.
I need some of these for my 740
I like to pretend I know stuff
FINALLY got to cut the console trim and test fit my controller panel. Fitment came out 100% perfect.
The console has to be machined out to fit my panel and some of the plastic under needs to trimmed. (I will be offering this CNC service)
The panel is bolted from up top using some stainless steel countersunk hex screws. I personally love clean exposed hardware, but they can covered with a wrap, paint, etc; will be up to the customer.
I was worried about the components or wiring crashing into the HVAC tube below, but everything fit with 0 issues.
The bezel uses my same "magsnap" style as the E39 version: bracket->monitor->bezel.
Panel is CNC machined out of 6061 aluminum, bezel kit is steel and ABS.
'02 TiAg/Blk E39 ///M5
'08 JZB/FR E92 ///M3
Looks great
EURO 04 M3 Current Mods: GC DA's, Eibach ARB's, INTRAVEE II + Alpine KCA-420i, Depo's, Screen protector for OEM 16:9 display, VCSL Bumper + Race Lip + CF Boot + CF Rear Diffusor, DIETZ TV in Motion, Z8 Starter Button, BBS CHs, Lamin-X, STORM SMG Paddles, RE RTABs/RCAs, OEM CSL Interior, OEM CSL Intake, M3 CSL HP DME, TTFS Tune, STOPTECH ST40's, FXR 3.0 Projectors, SS Stepped headers + Catless S Pipes + Res X-Pipe + Sport Muffler, OEM CSL Roof, OEM CSL Steering.
Can I ask how many people so far have actually got this kit. Or made this actually work fully.
@theshafro,
Bump for updates please?
No worries mate!
I'm in no rush either ...... just need to know how you going with fabrication.
This thread has my complete attention for our 2003 530i (no DSP. No Nav, etc ) Major props here!
Finally got around to designing the E53 controller panel. I'm gonna try to start a 3D print tonight and checking the fitment. It's pretty similar to my E38 panel.
Cannot see the attached pic?
-Paul
Still can't see...
Dude wtf. It was just there. I hate the coding on this forum, it's ridiculously unstable.
https://i.imgur.com/hHrrTMv.png
-Paul
Damn man that looks good.
Sent from my SM-N975U using Tapatalk
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
I'll see if I can use another pc...
@theshafro
No luck....tried on three pc and ipad / mobile phone...
different browsers too.. I give up!
-Paul
