Page 87 of 87 FirstFirst ... 37627778798081828384858687
Results 2,151 to 2,166 of 2166
Thread: NBT/CIC/CCC retrofit in E39/E38/E53
  1. #2151
    Mar 2010
    Kuala Lumpur, Malaysia
    BMW E39 530i Sport
    Just wondering if anyone have installed NBT in an E31? Hopefully getting a 1999 840ci soon....wondering if it can be done.
  2. #2152
    Nov 2008
    MOTOR CITY
    01 740 S- 08 X5-95 325ic
    so i have a question about the evo harness,i have the evo touch setup with screen,i bought the touch controller module, when i hook it up will the harness for the idrive touch controller be intergrated in the main harness or will i have to purchase it .
  3. #2153
    Jun 2013
    United States
    2002 E39 M5
    Quote Originally Posted by lad740 View Post
    Your question is a bit confusing, but the iDrive controller and the touch module take the same exact 4-pin plug. The harness will have to have the wiring for 2 plugs and it'll work right away
    '02 TiAg/Blk E39 ///M5
    '08
    JZB/FR E92 ///M3
  4. #2154
    Nov 2008
    MOTOR CITY
    Quote Originally Posted by theshafro View Post
    I've seen y connectors for that harness on eBay which is why I asked a question so I will have to specify wiring for two plugs?
    Sent from my SM-N910P using Tapatalk
  5. #2155
    Jun 2013
    United States
    2002 E39 M5
    Yes
    '08
    JZB/FR E92 ///M3
  6. #2156
    Nov 2008
    MOTOR CITY
    so the CS ATM emulator arrived yesterday as well as the touch moduler,waiting for the evo, screen and controller, due in today!
  7. #2157
    Nov 2008
    MOTOR CITY
    rude awakening! the touch screen from the f85 (x5m) is huuuuge! it wont fit my e38! epic fail on that one,i will sell the f15 and try to find an f10 touch screen if there even is one,or go with a regular screen,although i did want the touch screen.bummer.
  8. #2158
    Nov 2010
    Charlotte, NC
    549i6/530it6
    F15 late 2016 model is supposed to be the same size as the early f15 screens and have touch.
    -Paul
    2003 "M5" - S62/420g swap, M5 diff, M5 driveshaft, M5 brakes, M5 Traction Bars, M5 Bumpers, M5 Extended Leather Interior Swap,
    Eibach Sway Bars, UUC Evo3/DSSR, Custom Exhaust, BMW NBT Retrofit, M5 Gauge Cluster, Hella G4 Bi-Xenon Retrofit, APEX PS-7s, e60 Hubs, Koni Sports
    Coming Soon - M5 Ground Control Coilovers, M5 Mirrors, M5 Gloss Shadowline Trim, M5 Borla Exhaust with Muffler Delete
    530i 6-speed swap build thread
    2003 530it6 - M54b30/S6S-420g swap, 3.15 540it diff, e60 SSK, VMR VB2 19" Wheels, M5 Gauge Cluster, Hella G4 Bi-xenon Retrofit, NBT Retrofit, Koni Sports, 540i Brakes
    2001 749i6 - Retired and being parted out - M5Board Build Log
  9. #2159
    Nov 2008
    MOTOR CITY
    part # is 6816387 02 production date is 1-11-17. i put it on ebay. have to get the part # for the screen you are refering to..jeez!
  10. #2160
    Mar 2011
    Ladera Ranch, CA
    01 M5 and 05 M3
    subscribed for the bezels and console for E39s
  11. #2161
    Nov 2008
    MOTOR CITY
    i decided to do a little investigating on the f15 evo screen,took it apart and found that it has two screens.the first with the non glare coating and the innerscreen.they are both connected by a foil type ribbon connector and it seems that it is about 10.25 minus the frame but i didn't take it all the way apart because it seemed very fragile and i was'nt that confident in what i was doing. shifting subjects for a moment..would it be better to use the amp that came from the donor evo car, or the e38 oem dsp amp? i have an opportunity to get the donor amp.
  12. #2162
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    What is necessary for a 10.2" retrofit? Which cars can I take parts from? From what I've read I need:
    BMW Microphone
    iDrive Controller
    NBT Emulator (http://www.ebay.com/itm/BMW-NBT-Navi...1WAMhl&vxp=mtr)
    Display
    Video cable from trunk to dash
    BT Antenna
    USB / AUX panel
    Custom Bezel
    NBT Unit (trunk)
  13. #2163
    Jun 2012
    SAcramento
    2001 540i
    I don't think that emulator will work. That auction looks like its for retrofitting into newer cars. If you have a 99 528i as your sig suggests then you will need an Ibus nbt emulator and I think the only place that sells them is Bimmerretrofit. I would try to contact carsystems however they may be able to help you. Also dont forget the gps antenna and a universal hsd (high speed data) cable http://www.ebay.com/itm/For-BMW-CIC-...53.m1438.l2649 to run from the trunk to wherever you decide to put your usb panel
  14. #2164
    Jun 2013
    United States
    2002 E39 M5
    Don't buy sh!# from bimmerretrofit
    '08
    JZB/FR E92 ///M3
  15. #2165
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    Don't buy sh from bimmerretrofit
    Why not?
  16. #2166
    Jun 2013
    United States
    2002 E39 M5
    Quote Originally Posted by Perern View Post
    Why not?
    Cuz their adapter doesn't work.
    '08
    JZB/FR E92 ///M3
