Hi,Help. turn h/lamp switch on nothing , turn front fog lights on and w e have park and high beam alas no low beam. low beam globes are ok.
Regards, Ron
Moved from BMW employee forum to E32 forum. 2015? Is the problem still existing? Check the light control module = LKM, pull the cover off from the module and squeeze the relay contacts inside the LKM, sometimes cleaning the contacts helps or rebending them.
When I had this problem I ended up removing as much of the old solder as I could in both the LKM and the mustard relay and resoldering. The had cracked solder joints all over the place.
Here I have made a pic of the LKM with cover removed and showing all the relays and how to test http://www.bimmerboard.com/members/s...egung_engl.jpg
