Originally Posted by
phenom4
Up for grabs is a set of DEPO headlights for an E36 sedan. Worked as they should when removed, although be warned, they are VERY bright when running HID's so I'd suggest 35 watt bulbs, max.
They are not in perfect condition, but they work. The halos all function properly and are very bright. The passenger side headlight has a crack/chip in the glass that can be seen in the pictures. The passenger side corner light has a small crack as well.
The previous owner of the car decided to try and glue the corner lights onto the headlights, resulting in all the glue you see on the headlight housings. Luckily, it can't really be seen when they are installed.
It looks like all of the clips are intact. The lights fit well when they were on the car.
Bulbs are not included.
I'm looking for $75 shipped. Thanks guys.
