Afr on cold start SHOULD be richer then when the car is hot.
The ONLY issue with my 115LB E85 tune on OBD2 is that when it is COLD outside (~35* and colder) there is a slight lean spot at 10-15% throttle from 1300-1500rpms for the first 10-15 secounds of the car turning on.
It DOES start right up, idle perfectly, and drive normal when cold.
I am trying to resolve the issue currently.
please note if you start the car. and let it warm up for 1-2 min as you should anyway when its VERY cold out you would never even notice it..
RK tunes
Technica only charges for revisions when hardware is changed. They will dial in your setup at one cost. But if you decide to change cams down the road, a small fee will be required to revise your tune.
Its not like your dropping another G on tuning. Its more for his time.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
Gotcha, just wanted to make sure you thought about it. Its a big reason to stay with stock ECU if you are OBDII
That probably depends on what the standards are as they vary from state to state. Here if you don't have an OBD port functioning for OBDII it becomes a hassle very quick. We don't have shop inspections or similar like California.
I know NickG has flex fuel working on the E46, but no word on the E36. My biggest concern with the factory DME E85 tunes is the part throttle,cold start, constant AFR. Which seem to be an issue, especially with the larger injectors, both 115lb and id2000. If the Factory DME was limited to just over 1000hp on race gas, that puts E85 maxing out at a little over 800, thats me assuming its limited.
Yeah I remember hearing that about Nick G some time ago. I hope e36's aren't 'too far gone' for him or anyone else to put the time into figuring it out for us obd2 guys. Or time for s54 swap..
For me personally, I would really just like to have my tuner (stock dme or standalone) be within driving distance (anywhere on the west coast) so that if I were to have an issue, which is almost certain that at least one will arise, I could just call them up and trailer the car over. Remote tuning is an awesome advancement but I still feel that there is just no replacement for a tune dialed in in person.
Why does the east coast have all the damn tuners..
So I spoke with Bret on the phone again. He said revisions are free to dial an OBD2 car but every tune will cost a little extra so sorry about the confusion earlier. He also gave me a quote on proEFI (which has flexfuel built in so just dump whatever mixture in the tank and ethanol contant will change the boost setting, also has a lot of safety features) 1200cc injectors and southbend stage 5 clutch. There, I just blew few extra grand than expected
Sooo... ProEFI it is?
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
