Results 1 to 12 of 12
Thread: Walnut Blasting BMW N54 & N55 motors is a MUST
    Jun 2008
    La Habra, CA
    E46/E92/F82
    Hello Everyone
    Check out our blog about getting your N54 and N55 Intake manifold cleaned by walnut shell blasting. You should have this service done every 30,000 miles and before tuning your engine. Here is a link to the full blog write up on the service we performed on our own Mod Expert Alan's E92 335i and a few pictures
    http://blog.modbargains.com/get-nuts-feed-bmw-n55-walnuts-get-clean-tune/
    This is is an actual photo of how Mod Expert Alan Wei’s N54 looked after 70,000 miles. Isn’t that a disgusting mess? What’s more alarming is that YOUR INTAKE VALVES PROBABLY LOOK JUST AS NASTY!
    And here’s an actual photo of Alan’s motor right after doing the service. You can actually see the valve now!
    Walnut Blasting now available at ModBargains’ Install shop, Mod Auto! Take advantage of our introductory pricing!
    Contact Sean@modbargains.com or directly at 714-582-3330ext8009 to set up an appointment
    McKean township Pennsylva
    1999 M3 , 1999 328is
    The beauty of the direct injected engine... No gasoline (which is a brilliant solvent) traveling through the intake valves to clean up all of the mess.
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
    Sep 2008
    Miami, FL
    '13 x1 35i, '13 Mustang
    Yeah my N55 has a hair under 30k miles so after Santa makes his visit I'll be getting this done. My local stealer is advertising $450 for this. Not too shabby.
    '13 328i F30
    '13 Mustang 3.7 V6 Coupe Premium Pony Package
    PAST
    87 528eA. 01 525i/5 Sport
    87 528e/5. 01 M5
    92 525i/5. 03 325xi
    92 535iA. 10 Mustang V6 4.slow
    99 528iA Sport. 13 X1 xDrive 35i
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    With all the di engines out there you'd think there would be an easier solution.
    Sent from my iPhone using BF.com
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Aug 2008
    HHI, Worst Carolina
    2013 135i, 1994 Jeep XJ
    Quote Originally Posted by Kevlar View Post
    Yeah, it's called "mechanic-in-a-can". Do you really want to send all that sludge plus solvents and detergents through your turbos and catalytic converters?
    OP, every 30k miles? I realize you are trying to sell something, but your photos are from a 70k engine. I've done many of these. 30k miles, IMHO, seems a bit premature. Let's be honest and split the difference, say every 50k miles?
    Raleigh, NC
    SR-71 Blackbird
    I think there's a paper/journal going around on SAE about dealing with these DI gasoline engines and the effect of deposits on the back of intake valves. They're trying to come up with a solution. So far Toyota is the only manufacturer that I know who did something clever about it. They have DI already but added with the conventional injectors on the intake manifold. The idea behind it was simple. To keep the valves or the intake port as clean as possible like always. Clever, don't you think?
    Aug 2008
    HHI, Worst Carolina
    Quote Originally Posted by auaq View Post
    Yeah, I actually thought about that... You have to consider the negative aspects though. Increased complexity, cost, diminished fuel economy to say the least. Maybe use conventional style injection only on cold starts? IDK, I'm just a grease monkey...
    How often is a blast of detergenated (did I invent that word?) gasoline needed to keep the valves clean? What is the cost ratio for BMW to not do a goddamn thing? BMW will not cover this "service" until it becomes a blatant (misfire) problem.
    Jun 2008
    La Habra, CA
    E46/E92/F82
    Get your valves cleaned today and get your motor running healthy again!
    Call Sean at 714-582-3330ext8009 to inquire about our current specials!
    Feb 2001
    Jul 2011
    Houston
    LS e39, LT e53,
    Quote Originally Posted by E39Chris525i View Post
    cheap dealer... Would look up the labor to r-I intake maybe 2 hrs plus 2.5 for cleaning.. 6-800 ... 450/150hr is only 3 hours
    2003 X5 4.6is - for sale
    2006 X5 L83 5.3 6l80 swapped in progress - for sale
    1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff - for sale
    2007 ZX-10r - sold
    1987 R-10 SWB L83 5.3L 6L80e swapped
    www.87chevy.com
    Jun 2008
    La Habra, CA
    E46/E92/F82
    Jan 2016
    Ca
    2001 525it
    Having watch my techs do it it is a complete pain in the ass and Time consuming job. I don't believe it needs to be done every 30 k. Just did one that had 150k on it and it was pretty dirty. But every 30k no. The build up in the before pictures is not very much.
