I am reluctantly listing my car, unfortunately living on Long Island, NY doesn't make it easy for me to get to the track. To be Honest this year deserves to be at the track more then the 2, maybe 3 track days i get to do a year.
Ideally would like to either sell or trade my car for a dual purpose car, streetable track car... Something i can drive daily and still take to the track. This will also allow me to sell my Pickup Truck that i hate driving .
This Car is Street Legal Have Title, And Registered and Insured In NYS
-1996 Dakar Yellow E36 M3 about 103k
No sunroof from factory
102,XXX Miles
Crank Pistons Rods Balancer Flywheel And Pressure Plate Balanced Together
Engine:
S52 OBDII
All New Gaskets and Seals (101k)
-Epic Motorsports Tune (101k
Internals:
-Maxsil OEM Style Coated Pistons (101k)
-Eagle Rods (102k)
-ARP Main Studs (102K)
-S50b32 Dual Pickup Oil Pump (Rebuilt) (101k)
- Oil Pump Nut Wired.
Head:
-ARP Head Studs (101k)
-3 Angle Valve Job (101k)
-Supertech high performance valve spring kit
-VAC High Performance Valve Guides (101k)
-Rebuilt Vanos (102K)(Anti Rattle And Shimmed)
-Vac IP Dominator Cams (101K)
-Vac Coolant Adapter (101k)
-Bimmerworld Coolant Blockoff (101k)
-Bimmerworld Low Temp T-stat (101k)
-Bimmerworld Water Pump Nut
-OEM BMW Coolant
Engine Exterior:
-24 lb/hr injectors
-M50 manifold
-3.5" to 3" intake elbow
-Porsche 3.5" hfm
-Custom CAI w/ K&N filter
-Carr Aluminum Radiator
-Spal Electric Fan
-UUC Underdrive Pulleys + Belt (101k)
-Dual fuel pumps
-Billet Machined Idler Pulleys
-Asc Delete
-SAP Delete
-Wix Fuel Filter (101k)
- K&N Filter (101K)
Driveline:
-UUC Organic clutch kit with an 8.5lb aluminum flywheel
-UUC Evo 3 Short Shifter
-UUC DSSR
-UUC Redline Trans Fluid Cocktail (101k)
-UUC Stainless Cluth Line (101k)
- Oem Guibo (101k)
Exhaust:
-Real Supersprint Long Tube Headers
-Supersprint Mid Pipe
Suspension:
-Vorschlag Motor Mounts (101k)
-Subframe Welded and Reinforced (101k)
-Control Arms (101K)
-Ground Control Advanced Designs Double Adjustable Shocks
-Eibach Springs 875 lb/in R 800 lb/in F
-Ground Control Race Camber/Caster Plates
-Ground Control Rear Height Adjusters
-Ground Control Monoball Race RSM's
-RD Swaybars w/Adj. Rear Endlinks
-Custom Adjustable Front Endlinks (101k)
-X-brace Powdercoated red (101k)
-Turner delrin Lower Control Arm bushings
-Powerflex Reat Trailing Arm Bushings
-Kosei K1's w/ Toyo r888 245-40/17 (101k)
Brakes:
-Stock Calipers
-Brass Guide Bushings
-Turner Stainless Brake Lines
-Bimmerworld Stainless Pistons
-Hawk HT-10 Pads
-Brembo Blanks Front
-Brembo Slotted Rear
-Custom Brake Ducts
- Wheel Stud Kit
Interior:
-6-point Cage With X-Doors
- Custom Dead Pedal
-Corbeau FX-1 seat
-Sparco Pro-2000 (driver side)
-Vac Billet Seat Mounts
-G-force 6 point Harnesses
-Schroth side net
-Momo Steering Wheel
-LTB Steering Wheel Quick Release
-VDO Coolant Temp
-VDO Oil Temp
-VDO Volt Temp
-Innovate Wideband
-Hard Motorsports Gauge Panel (101k)
-Hard Motorsports Batt Kill Switch and Panel (101k)
-Custom .0625" Aluminum door panels
-Custom .125" Aluminum floor panels w/anti-skid
-AC and heating all removed/deleted
- Custom Battery Box
- Deka ETX-14 Battery
Exterior:
-LTW OEM adjustable front splitter
-LTW replica rear spoiler
-Headlight Delete With Intake Duct (101k)
-Brake Light Flashing Module
All vin tags match, hood and fender has some bumps and bruses from working on the car.
Hard Motorsport Gauge Panel Not installed Yet, currently has oil temp and coolant temp.
Headlight intake not
Just a few pictures i was able to dig up, send me a message and i will be able to take pictutes or answer any of the questions you may have.
Looking for 25k OBO Open To offers and trades.
PM/Email Matthew.Sucich@gmail.com
Bump for a great guy and a solid car. Matt, if you want to sell that wing, let me know, Vinny would buy it for sure.
Bump for an awesome looking local car.
Ever have any issues with your Epic tune? I have an OBD tune for similar intake mods and can't get away from a CEL for fuel trim issues...
No issues but I really haven't been driving it much. Thanks for the bump!
Looks like very solid and well built track car. Good luck with sale. I am sure you will miss it.
2014 F10 M5
2014 F15 X5d
1990 E30 325is S50 (track car)
1990 E30 325is (garage queen)
Remember seeing this car at Bald Hill a few summers ago. Looked stout and well put together, GLWS!
What a solid car. Well done sir.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Thanks guys!
Nice ride! Bump for a fellow Long Islander
I currently have a 1995 M3 Hellrot Red, with 81,000 miles that I would consider trading. I was planning to turn it into a dedicated track car but it might make more sense to trade or sell and get a car that has already been set up for track. I have tweaked the car for track use, including the following: Vorshlag camaber plates, X Brace, SS brake lines, Turner brass bushings, rebuilt front M calipers, HT 10 pads front and rear, harness bar, OMP and Cobra seats, 6 point harness, Bilstein sports, H&R Race springs, Turner chip, clutch and flywheel replaced this summer, rebuilt shift linkages at same time. The car has been very well maintained. I also have stock vaders that are in perfect shape.
If you are interested feel free to give me a call at 603-667-8254.
[2004 330xi/6] Orient/Natural :: 117-142k :: ZSP :: ZPP :: ZCW
[1998 M3/4/5] Cosmos/Black :: 113-125k :: TCKline D/A (500/600) :: GC Plates :: RD Sways :: GC Rear Arms :: ZHP Rack :: 3.64 Diffsonline :: PF FCAB :: BW RTAB :: AKG Subframe :: TMS Pulleys :: AA & Borla :: XBrace :: TRM C2s :: BW lines :: DTC60 :: Safety Equipment
Past:
[1995 M3] Avus/Dove :: 141-242k :: S52 OBDI :: M50 manifold :: 3.5 HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport :: Z3 rack
[1999 M3] Cosmos/Black :: 65-87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Safety Equipment
[1993 325is] Brilliant/Black :: 135-139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
[1983 320i] Safari/Brownish :: 219-242k :: homebrew CAI :: some rust :: multicolor body panels
The following was a great deal, too bad I missed it :-)
http://www.bimmerforums.com/forum/sh...original-miles
Speaking of the OP car, what's the current price?
Past:
Track season is right around the corner
beautiful car, man. GLWS
If you think can't, you're right
Bruce
Also interested in price.
Past:
[/QUOTE]
PM/Email Matthew.Sucich@gmail.com[/CENTER]
[/QUOTE]
Still. Yeesh.
Past:
Lol something like that I guess.
Past:
