Can anyone please help me with an INPA install that will access the bleeding procedure for the ABS module?
I have a modified vagcom KKL cable that works with most modules but will not communicate with the ABS/DSC module.
I feel I've tried all the versions of INPA out there but only the oldest version did communicate with the ABS/DSC module but there where compability issues due to the fact that the module was newer than the INPA used. Could run the internal pump though, but noe the bleeding procedure.
No I have the EDIABAS/INPA 6.4.7/5.0.1 installed but it cannot connect to the module, IFH-0009 no response.
This version of INPA does not have the bleeding procedure under special tests.
Use DIS.
PM me with an email address and I will send you a .pdf with the bleeding procedure.
PM Sent! Thanks
