Page 1 of 7 1234567 LastLast
Results 1 to 25 of 158
Thread: Which MC for Massive Brake Booster Delete?
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Can someone post a link to a good option for a master cylinder for use with the massive booster delete on an e30?
    thanks.
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    I use the 25mm 7 Series master. I like it a lot, I would not change a thing.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Thanks. What year/chassis 7 series?
    edit:
    this the guy?
    http://www.ecstuning.com/BMW-E32-735...ale/ES2534782/
    Northeast PA
    jimmy p.
    04 Ford F350 - V10
    Jun 2006
    Powder Springs, GA
    e30 e34
    Are you still running stock calipers?
    I am running a 22mm MC with e46 m3 front calipers and e39 rear. It has a decent amount of travel, but obviously requires way less pressure than it did when I still had the stock brakes on the car. With 22mm MC and stock brakes the pedal was too hard IMO
    '88 s54 e30, '00 m5
    Montreal
    2002, e30 M3, 535
    Ah, ah, ah. Jimmy must be built like a Silver Back gorilla with legs the size of an hipopotamus ;-) 25mm MC might be too big for most of us, or without "hardcore racing" background... ;-)
    I suggest a 19/19 and, on the e30, you have to ditch the bias valve to the rear calipers to get full pressure.
    19/19 comes from older turbo cars such as Porsche's 944 and 911. Check for the non-ABS cars. You need not spend a lot of money purchasing an ATE part. Plenty of knock offs available. Centric being one of them. Also, for calipers with small pistons, some 17/17 MCs are available, coming from older Audis (Audi 100?) and VW Rabbits, which had no assist...
    1969 2002 racecar + 1989 e30 M3 racecar
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by Massive Lee View Post
    Does it matter the year 944? Sorry to seem obtuse about this stuff; just want to try and get it right.
    The 944 MC's I'm seeing are in the $125-200 range.
    And any more more details on removing the bias valve? I was going to rerun the brake lines anyway.
    Montreal
    2002, e30 M3, 535
    The 944 had several MCs. So, make a search for a Turbo 944 non-ABS and make sure it is 19/19. There a re a few threads on what MCs are needed, with part #, on this forum.
    Lee
    Feb 2013
    MD, USA
    2005 M3 Coupe
    The thing that stinks about eBay and most parts sites is the don't list the bore diameters. I'm still digging around for a thread of part numbers.
    Vancouver, BC Ca
    1993 325is
    Porsche 914 had both 19 and 17mm masters and if memory serves me right, they had the correct bolt pattern for the Massive delete kit.
    Northeast PA
    While I'm certainly not a small / frail guy, I just don't find it to have very much effort at all.
    I like the brake pedal to be rock solid.
    I think my perfect brake pedal would be a rock solid pedal at the height of my gas pedal that only moved 1/4" and I attenuated the brakes with varying pressure.
    I wouldn't be afraid of the 25mm master.
    Agree on running equal pressure everywhere.
    Get rid of that e30 bias valve.
    jimmy p.
    04 Ford F350 - V10
    Feb 2009
    PR
    87 e30 sedan
    Lee
    Hey Lee,
    Any plans on a black friday sale on your products?
    Feb 2013
    MD, USA
    2005 M3 Coupe
    On the topic of the bias valve, that's for the input. I am going to run fresh lines everywhere so getting rid of the bias valve should be no trouble.
    I am not against getting the porsche 944 MC, but I have yet to find a definitive "use this PN". I can find non-ABS 944 turbo MC's, but I can't find any info on diameters crossed back to part numbers.
    Montreal
    2002, e30 M3, 535
    Quote Originally Posted by darvo View Post
    Hey Lee,
    Nah... Never done such a sale. If I did, it would probably mean parts are overpriced the rest of the season. ;-) If you need anything, be aware I will be closed from Dec 7th to January 17th for a 5 week motorcycle trip in France, Spain, Morocco, Italy and Tunisia. ;-) And no internet in the middle of the Sahara.
    Feb 2009
    PR
    87 e30 sedan
    The only vw/audi 17mm masters and 19mm masters I've seen comer from Vw Bugs and Karman Ghia's... Lack of part #'s for stock calipers and holding me down on buying
    new york
    e30/e36 m3
    Hey Lee I'm in the process of building an E30 M3 with a S62 v8, I'm also installing the 135 Brembo calipers front and rear with your booster less setup. Let me know what MC size you recommend ........ thanks in advance
    Montreal
    2002, e30 M3, 535
    I don't think you can fit the booster delete kit there. As clearance between back of head and fiewall is less than an inch. Noneheless, if you are willing to try something else, you can fit a padal box with inboard MCs (check Tilton and Wilwood kits). Check Garagistic fortheir install kit. Also, I designed a version of the booster delete kit but with a single inboard MC especially for V8 swaps. Sadly the Tilton Mc is not cheap. ;-(
    new york
    e30/e36 m3
    Thanks for the info.
    Feb 2013
    MD, USA
    2005 M3 Coupe
    I found a super cheap MC from a 944 Turbo on eBay. I'll give that one a go and then go from there. For $25 it was worth a shot. I'll report back on what I end up finding that works for the benefit of others.
    Feb 2009
    PR
    87 e30 sedan
    Quote Originally Posted by dmw16 View Post
    Thanks! You have stock calipers right?
    Montreal
    2002, e30 M3, 535
    ATE 130.37500 or equivalent replacement part seems to be 19/19 - To be confirmed.
    1988 Porsche 924 S Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    1987 Porsche 924 S Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    Non-ABS 1986 Porsche 944 Base Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    Non-ABS 1986 Porsche 944 Turbo Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Turbocharged
    1985 Porsche 944 Base Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    1984 Porsche 944 Base Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    1983 Porsche 944 Base Coupe 2-Door 2.5L 2475CC l4 GAS SOHC Naturally Aspirated
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Thanks for the info Lee. I ended up with an 87 MC from a 944. Not sure if it will work, but for $20 if it doesn't then no real loss.
    Feb 2009
    PR
    87 e30 sedan
    Have you tried it?
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Have you tried it?
    Not yet. It will still be a few weeks. The car is pretty taken apart right now.
    Montreal
    2002, e30 M3, 535
    Can you take a picture of the MC?
    TIA
    Lee
