Page 6 of 62 FirstFirst 123456789101112131415163156 ... LastLast
Results 126 to 150 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #126
    Sep 2002
    USA
    BMWs
    I've used the sealing splices on mcmaster and they're every bit as good as the crazy expensive MIL ones I have. If I hadn't gotten my MIL ones from work I'd have never used them - they're cool, but literally the same as some of the ones McMaster sells.
  2. #127
    Jul 2005
    PEI, Canada
    2001 330i
    Another supplies shipment arrived:
    Raychem boots for the milspec connectors:
    Left to right - Heat shrink for adding drain wire to shielded wire, Kapton tape, Kevlar lacing:
    This stuff is for re-work...as in I'm re-doing the Autosport AS and ASL connectors:
    Closer look at the heat shrink tubes for shielded wire:
    800ft more Tefzel wire:
    New tools:
    AFM8 crimper and 20awg positioner:
    Comparison with the AF8:
    The Cadillac of wire strippers, the Ideal Industries Stripmaster Ergo Elite:
    They have a composite frame, so it's super light in the hand:
    Wire length stopper installed:
  3. #128
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    OOOH. I've never seen that wire length stopper before! I gotta get me one of those!
    The Ergo Elite stripper is so much better than any stripper I've ever used, it's just ridiculous.
    --Peter
  4. #129
    Louisville, KY
    turbo m3
    Quote Originally Posted by PEI330Ci View Post
    The Butt connectors are from TE, which I'm using 12, 16, and 20 awg types. They come in 2 pieces: The metal tube, and the heat shrink tube. As previously pictured, there is a specific crimp tool for metal part, and the heat shrink tube is a multi component part with an outer shrink shell, and then each end has a "ring" of glue that bleeds out when you apply heat. I should warn you, I spent about $700 on what's pictured above. As far of the knowledge goes: I'm not the knowledgeable one...I just find smart people, and try to support their business.
    Quote Originally Posted by 5mall5nail5 View Post
    Good call - I always use adhesive shrink and used the same butt splices only it didn't cost me $700
    I know you two (Adam and Jon) have done plenty of electrical work.
    So, obviously I'm asking because I don't know, these are the best style butt connectors?
    I realize $700 is a lot. I'm just wanting to you know. Having said that, this is recommended over soldering and heat shrink?
    This is my signature....
  5. #130
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by herrubermensch View Post
    --Peter
    Peter,
    It's got some benefits and drawbacks.
    Yes you can set the length, but it blocks your view of the slots. After some practice you do get a feel for where you place the wire, but it takes some practice.
    I've only used it for 2 days...but I think it's fast becoming my favourite tool in the box! Super nice piece!
    The AFM8 is a lot easier to use than the AF8 for 20awg as well. I think I did over 100 pins today with it...
  6. #131
    Louisville, KY
    turbo m3
    Quote Originally Posted by TerraPhantm View Post
    What's the advantage to those compared to these? I usually use those + heatshrink. About $0.50/ea from BMW, and I'm sure they can be found cheaper from whoever makes them (probably TE). The crimper I have was pretty cheap and works well enough, though if I did as many as you, I'd probably spend a couple hundred on a high quality crimper.
    How do those work? Do you have to crimp each section? Or, crimp the middle and close the ends with some pliers or something?
    Do you have a part number or name?
  7. #132
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by BadBoostedBmwM3 View Post
    In a vibration environment, crimping is preferred over soldering. (Assuming both are performed properly) As long as the solder joint is properly performed, it should be fine for the life of the average car. On an F1 engine though, which is where most of these snazzy Autosport connectors originate, vibration has killed connections....
    Building the Power Interconnect harness to bring power from the PDM to the driver's side of the engine bay. (Where the M150 ECU is)
    The harness has 8 runs of 12 awg wire, and the yellow "string" around the bundle to keep it tight is Kevlar lace:
    Not everything goes to plan. In the image below, you can see how I cut off a $20 Raychem boot because I messed up the shrink installation:
    My mistake was installing it full length. In the image below you can see the trimmed boot on the right ready to be applied to the connector:
    Nobody has ever mentioned this before, so I thought it would be useful for others to learn from.
    Boot installed on the Power Interconnect harness connector:
    That was yesterday's progress.
  8. #133
    Mar 2015
    Camarillo, CA
    2005 M3 Coupe
    Quote Originally Posted by 5speed300 View Post
    Can't believe there aren't more replies -- I've been reading threads in here for 8 years, this is maybe the coolest/most thorough build I've ever seen. So awesome to see all the little details. The amount of data you will have on that car is incredible!
    No kidding ! wow! Kudo's, well done !
  9. #134
    Sep 2011
    Ogden, utah
    2001 330ci
    Pei! You have done everything sofar apart from the full on rewiring that I had planned on!! Haha level of jealousy right now is immense! I cannot wait to hear this thing scream! It's funny I stumbled upon this thread while looking for references and ideas.
    Been following you 2000_328ci- chase and a few others but had some things come up and started another build and find great inspiration from you all!!
    devin
  10. #135
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by Erik Motoman View Post
    Quote Originally Posted by mrbimmerdude View Post
    devin
    Thanks guys!
    Continuing on, below shows the construction of what I call the "Interconnect" harness:
    I'm using a method called Concentric twisting to layer the wires in a flexible cluster. The 2nd layer completed:
    Wrapping the 3rd layer:
    Wrapped with Kevlar lacing:
    Setting up to apply 3/4" heat shrink:
    Raychem boot applied to connector:
    Test fitting on the car:
    The purpose of the 39 pin "Interconnect" harness is to transfer signals between the left and right side of the engine bay. This includes 3 CAN bus lines, and various other I/Os.
    The next harness I started was the "Ignition" harness. Below I'm populating the 32 pin connector utilizing the pin insertion tool provided with the connector:
    A little bit further along in the process:
    Resealed OEM ignition coil section:
    Connector and transitions:
    Aside from the ignition coil signals, this harness also has connections for the Racegrade TC-8, Motec LTC, and what's called the CJC-1 for the E888. . This CJC (Short for Cold Junction Compensation) is a temp sensor that is positioned close to thermocouples connected to the E888. This used to establish the ambient temp baseline, and then the E888 corrects the the thermocouple measurements.
    Completed Ignition Coil harness:
    Constructing the harness that runs from the center console to the "drug bin":
    And that's as far as I got with that, I need more 1/2" heat shrink.
    I've also started the left side engine harness (41 pin connector is full of pins), but I don't have any pictures of that yet.
  11. #136
    Nov 2008
    New York, NY
    Beautiful work, Adam. Puts my twisting to absolute shame!
    --Peter
  12. #137
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    WOW the work is top notch (always has been)
    quick question, when you were drag racing the 330 way back with the 330i rear brakes what was your wheel setup in the rear?
  13. #138
    Jul 2005
    PEI, Canada
    2001 330i
    --Peter
    Thanks Peter...but I've seen pictures of the back of your car, and it's stunning!!!
    Quote Originally Posted by E36 HateR View Post
    Custom 16" X 9.5" wheels, with an offset of 45mm I think?
    Tires were MT ET Street 26 X 10.5
  14. #139
    Butte, Montana
    Suck
    Are those black wires used for signal or something or are they just there for shielding?
    Go ahead and bite. Plenty for everyone.
  15. #140
    Bellingham, WA
    e30
    Great work Adam! Thats a cool way to make a harness with the wires wrapped like that. Never seen it done like that before.
    I like reading your threads and learning new things!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  16. #141
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by Binjammin View Post
    They are all signal wires.
    For signals that I'd like to shield, I have mil-spec shielded wire as well. (M27500)
    Quote Originally Posted by wazzu70 View Post
    Thanks Nick
    The primary benefit to twisting wire bundles like this is flexibility; the wires move more sideways instead of in compression and tension.
    The secondary benefit is that the layup is compact.
    And a third benefit is that it looks really cool....
    To be clear guys, this is not my profession. I draw inspiration (and instruction) from the real professionals at Apex Speed Technology.
  17. #142
    Sep 2002
    USA
    BMWs
    Thanks Nick
    Adam -
    While that looks cool and Apex may do that, I cannot find any reference to doing anything like that in a MIL specification. In fact, the only twist that I have ever seen referenced is specific to TPI for noise reduction. I am worried that your wires being spiraled around like that is going to make for issues with high frequency noise in addition to the fact that your cabling is unnecessarily long as such. If you wanted to get a clamp on there or use a pierce for oscilloscope or volt meter/logic analyzer, you're going to have a hell of a time find the wire.
  18. #143
    Nov 2008
    New York, NY
    Adam -
    Jon:
    This method of concentric twisting is absolutely standard for all autosport harnesses. It adds strength, flexibility and noise resistance. No doubt that it makes finding a wire that you want to clamp hard to find and reach. But if you look at every Sakata, Apex, Motec or other harness, they all use this technique. I'll see if I can dig up some of the resources that describe why this is done and how to do it.
    --Peter
    PS: Here's a good starter link: https://www.rbracing-rsr.com/wiring_ecu.html
  19. #144
    Sep 2002
    USA
    BMWs
    Jon:
    --Peter
    Interesting thanks Peter. I would just be very careful what you're wrapping the wires around. Wrapping wires is in fact a long-used method for noise cancellation but you have to be very careful what the noise you're trying to cancel is. Wrapping all your low level signals around a high current source may not be ideal.
  20. #145
    Jul 2005
    PEI, Canada
    2001 330i
    Jon,
    I suggest you try this out and see how you like the feel of the bundle. There is a difference.
    As far as any noise issue goes, I'm using Motec which comes with Elf Level - 14 protection against this.
  21. #146
    Sep 2002
    USA
    BMWs
    Jon,
    Adam my harness is wrapped but in twists on signal wires. Its compact still but a little different. If you have some sort of active protection against noise I suppose that'd work, but 5vref signals do not have a whole lot of amplitude and can be exceptionally vulnerable to noise. I am sure you've prepared for that though it looks cool.
  22. #147
    LI NY
    Turbo 99' M3
    Looks like you're taking to it like a fish takes to water, Adam! Nice work as always.
    For anyone on instagram interested in seeing more super impressive wiring skills, check out @RACESPEC. He does "motorsport wiring" and "motec installation" work. Very cool stuff/pics to look at.
  23. #148
    Jul 2005
    PEI, Canada
    2001 330i
    On a non-wiring related note, I assembled this contraption to test boost lines and the solenoids:
    Sometimes I just like to prove things work...
  24. #149
    Sep 2002
    USA
    BMWs
    Very useful! I turned a PVC cap on a lathe to get it the right diameter for my turbo inlet. I used a silicone coupler to attach the PVC cap to the turbo inlet, drilled an NPT hole in the cap, and pressurize it just like you are from my air compressor w/ a gauge so I can watch boost "leakdown". Very useful stuffs.
  25. #150
    Jul 2005
    PEI, Canada
    2001 330i
    Adam -
    Jon,
    Your comments did not sit well with me, so I've taken some time to reflect and reply in a constructive manor.
    There are many "directions" one can follow including specifications, documented industry best practice guidelines, and guidance from industry professionals. In general, I tend to pursue all 3, and balance their application based on my own tool and skill set.
    There are no MIL specifications for concentric twisting because that is not the purpose of MIL specifications by design. Concentric twisting would part of a work order, work instruction, or as part of a Quality Specification guideline. MIL specifications define how a part is constructed, not how the assembly of those parts is performed.
    Harnware is the wiring industry's benchmark design and construction software from TE. As part of it's "Help" documentation, it lists best practice for many types of harness construction steps. Below is a link to the document for Hand Cable Laying, as part of their Harness Assembly Instructions:
    http://www.te.com/commerce/DocumentD...=SS&DocLang=EN
    This is an example of industry best practice.
    Lastly, I have been lucky to spend a fair amount of time in a number of professional automotive racing environments. This gave the opportunity to see first hand how wiring harnesses were constructed and utilized in some really nasty user environments. I've seen the innards of quite a few harnesses; some because they were torn apart due to crash damage, some due to maintenance damage, and some due to fire damage. All of the top race teams seemed to share common wiring harness practices, including concentric twisting. One such example was Penske Racing with the now retired Porsche LMP2 car. They had electrical gremlins, so harnesses were being cut open in the pits to try understand what was happening out the track. I saw those harnesses, which were built by Porsche Motorsport.
    This is an example of professional experience.
