Page 50 of 62 FirstFirst ... 25404142434445464748495051525354555657585960 ... LastLast
Results 1,226 to 1,250 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #1226
    Jul 2005
    PEI, Canada
    2001 330i
    ...and I blew up my valve cover today.
  2. #1227
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    Quote Originally Posted by PEI330Ci View Post
    Quite a spike! Sorry, big guy. You were going to tear down for improvements anyway, no?
    --Peter
  3. #1228
    Apr 2006
    Minnesota eh?
    86 325es
    Holy cow, does it still have piston rings?
  4. #1229
    May 2013
    Australia
    E30 M50B28 Turbo
    This is a typical FET PWM board:
    https://www.ebay.com.au/itm/3X-Elect...53.m1438.l2649
    As you can see, three boards for cheep cheep. But quality.....umm....yeah, not sure. I don't really trust those China semiconductors, but I can always just replace the dubious parts and solder in some quality, but I can test proof of concept with the board as it stands.
    Edit: FWIW, the Hella SSR I have seen numerous videos demonstrating its use as a PWM pump controller. A few ECU makers also sell this part as an accessory, but with their own brand label on it. Hella say that it is good for 1Khz PWM.
    Valve cover? Did you nuke a piston or two or just kink a vent hose?
    Yes please share the results Nutzy, I'm also interested in pwm'd my pumps and I run the same AEM pumps as you.
    1989 E30 - M50B28 Turbo - ZF 8 Speed
  5. #1230
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Was it an oily mess?
  6. #1231
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Nutzy View Post
    Thats great info and those Hella relays are cheap enough to keep a spare one the glovebox. Looks like the amperage rating would be plenty for one relay per 044 or AEM 380
  7. #1232
    Jul 2005
    PEI, Canada
    2001 330i
    The valve cover failure was not caused directly by an engine issue.
    I have been working on cold start tuning, and parked the car outside to freeze the engine. The Catch can and filter also froze. When the engine was started, there was no-where for normal blow-by to escape, so pressure started to build. Eventually the pressure in the crank case was enough that when coasting in gear, oil was being pushed into the combustion chamber resulting in plumes of smoke behind the car when lifting off the throttle.
    At this point the oil temp was still very low, so I thought I was having a scavenging problem from the turbo due to the thickness of the oil. (From being cold) Keep in mind I haven't driven the car when it's been "frozen" before, so all of this was new territory. I checked that the scavenge pump was working, and it was, so I decided to limp the car back to my shop to further investigate. Shortly after, I saw some smoke from the engine compartment, and stopped again to check under the hood. This time I could see that oil was being sprayed from the valve cover area.....but I couldn't see anything dripping down onto the turbo manifold, so I decided to continue driving back to my shop at low RPMs.
    When I pulled the data from the car, everything became clear what had happened. I checked the catch can line for flow, and was seriously restricted. I had literally frozen the engine up.
    Talking to some mechanic friends, they said that this was actually a pretty common problem now with heavy equipment. The solution applied there is to have the CCV system heated by circulating coolant around and through various components.
    The biggest contributor to this issue is that I've mounted the catch can away from the engine in a place that receives a lot of cold air directly. The OEMs in contrast are now mounting their systems under the intake manifold next to the engine block to keep them warm.
  8. #1233
    Jul 2005
    PEI, Canada
    2001 330i
    Image Testing
  9. #1234
    Jun 2005
    New England
    Must be really cold up there. I have never had a problem in NH, car is parked outside and driven in winter. Had a catch can for most of the past 12 years. Temps are below 0 F on rare occasions and below freezing most of winter.
  10. #1235
    Bellingham, WA
    e30
    Interesting. I was going to comment we have had issues with crank vent lines freezing in the cold chamber causing the same end result. I thought it wouldnt be relevant....
    We use resistance heaters on the lines to keep from freezing. We also hook the test cell up to crank case pressure to shut things down if the vent is not working. Maybe set up crank case pressure to a torque limit or something as a safety since you live in a cold climate??
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  11. #1236
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by wazzu70 View Post
    I
    had
    a
    crankcase
    pressure
    safety
    measure
    not
    enabled.....
  12. #1237
    Jul 2005
    PEI, Canada
    2001 330i
    Normal diff ear:
    Broken diff ear:
    The entire diff rotated:
    Light damage:
    The diff cover was damaged in shipping in September, but I decided to use it check the fitment of the driveshaft and axles. Then I decided to drive the car.....which was a mistake. I fixed this more than a week ago....
  13. #1238
    Jul 2005
    PEI, Canada
    2001 330i
    Diff oil after about 100 miles of break-in:
    Ready to change the cover:
    Making the swap:
    Injector upgrade:
    I had to extend the injector harness by 10cm:
  14. #1239
    Jul 2005
    PEI, Canada
    2001 330i
    Dmitry,
    This is what I mean by "rotated":
    Out tuning low-load VE:
    Parting shot:
  15. #1240
    Jun 2005
    New England
    At least for some E39, like the 99 528i we had for 10 years, BMW offered a “cold weather” CCV kit that had insulation. No heater, though.
  16. #1241
    Bellingham, WA
    e30
    I
    had
    a
    crankcase
    pressure
    safety
    measure
    not
    enabled.....
    Doh. I figured since you could log the channel there would be a safety associated. Thats the sucky part about development...the feature you needed is never quite calibrated/enabled!!
    -Nick
    91 E30 M42 on VEMS
  17. #1242
    Jul 2005
    PEI, Canada
    2001 330i
    It's setup now...but I'm looking to change the hardware in the system so that I never need it.
    Also considering going to a dry sump....so that will get rid of that vent in it's current use.
  18. #1243
    A house
    '86 325e, '14 VW EPA
    Dmitry,
    Adam,
    you're low on fuel.
  19. #1244
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by TheJuggernaut View Post
    Adam,
    you're low on fuel.
    And its overheating.
  20. #1245
    Sep 2002
    USA
    BMWs
    Ironically there's actually a recall on E90s/etc. right now with the CCV heater causing fires, just an FYI!
    https://www.usatoday.com/story/money...res/828690001/
  21. #1246
    Jul 2005
    PEI, Canada
    2001 330i
    At least we know that the M54 Dipstick will hold 35 PSI of crank case pressure.
    I'm going to remove the valve cover, and try using a plastic epoxy to put it back together....
  22. #1247
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Could be worth trying to plastic weld it with an epoxy backing.. But it probably has glass fiber in it, not sure how that would react to plastic welding.
  23. #1248
    Vancouver, BC Ca
    1993 325is
    I have a good valve cover if you just want to replace it. And no border to deal with!
  24. #1249
    May 2013
    Australia
    E30 M50B28 Turbo
    I have ordered some of those FET boards, I will let ya'll know how it goes.
    It was supposed to hit 102F here yesterday, so I took the E30 out for some stress test. It ended up only hitting 95F, but temps always stayed under control and the 16" PWM controlled SPAL never hit much over about 60%.
    I also hurt the feelings of a dude showing off in an AMG A45, roll race from 2nd. He had my measure in 2nd because I was laying 11's down, but 3rd gear tore the AMG a new asshole! He'd have done me like a roast turkey from a dig though!
  25. #1250
    Sep 2002
    USA
    BMWs
    Damn Adam 35 psi in the crank case? Check the front and rear mains man. As you prob know, dipsticks always hold massive pressure due to small surface area. It's the bigger gaskets and seals that let the smoke out.
