Page 42 of 62 FirstFirst ... 17323334353637383940414243444546474849505152 ... LastLast
Results 1,026 to 1,050 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #1026
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Your oil pressure trace is very concerning. Are those dips down for real? Based on the data trace, I'd say it is, unless you've got a lot of smoothing on that channel. That is, unless you're fine with what looks like <15 psi of pressure at idle. I'd personally bump up my idle before subjecting the engine to that little pressure.
  2. #1027
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by Def View Post
    I agree the low drops look suspect, but it also looks like maybe noise as well - notice the difference between 2:30 and 9:10. RPM is different but I wouldn't expect it to flap around so wildly with only 500 - 700 RPM variance.
  3. #1028
    A house
    '86 325e, '14 VW EPA
    10-12psi is typical M5x idle pressure
  4. #1029
    Jul 2005
    PEI, Canada
    2001 330i
    You guys are hilarious.
    Some of those drops are because there is ZERO engine speed.
    Also, the oil pressure scale starts at 20 PSI.
  5. #1030
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 5mall5nail5 View Post
    The RPM is actually pretty steady at 2:30; 850 RPM.
    The issue is oil temp with 20W50 oil, where it's holding 70 PSI at idle, then the valve will cycle open dropping pressure to 50 PSI, spiking briefly to 80 PSI, before settling back to 70 PSI. The pressure relief valve, and this oil pump, simply wasn't designed to operated like this. (Heavy oil)
    I started the car at 67 deg F, and at 2:30 it is at 80 deg F. Once the oil gets up to about 160 deg F, oil pressure is very stable. Idle is at 850 RPM, and I have 20 - 22 PSI of oil pressure.
    One variable that I've been working with since 2009 on my car, that nobody else on here has, is billet oil squirters. They have no check valve, so in theory, I should be seeing lower oil pressure at idle. The race engine I ran in 2009 had 15 PSI oil pressure when hot. My current engine will see 15 PSI briefly if idle drops to 800 RPM.
    This will shock people, but I'm also not running a synthetic oil....as I seem to pull my engine apart before I hit any reasonable oil change intervals. I do have 11 quarts of oil in the system though....so that's another variable that's different from most.
  6. #1031
    Def's Avatar
    Aug 2002
    SW22, Volt
    Quote Originally Posted by PEI330Ci View Post
    Looks like it goes below that (maybe 15 psi), and it's off the chart low when you get to idle. Just concerned me, as I'm used to seeing 20-25 psi hot oil pressure at idle.
  7. #1032
    Jul 2005
    PEI, Canada
    2001 330i
    I've been looking at this data for 2 years now, and bouncing stuff off a guy that has tuned a lot of engines at a very high level.
    There were things that I was concerned about, because I had a very clear and high resolution signal trace, that I learned to be very normal. Most of the time people are used to seeing averages of a sensor across 10 or more data points, or the sensor's ability to measure change is in seconds vs milliseconds. When you start looking at a sensor trace 100 times a second, versus 1 time a second, you think you're seeing all kinds of problems. Fuel pressure is a good example. Depending on proximity to the fuel rail, it can have a lot of noise in it. Fuel pressure can also be caused to oscillate due to the size and length of vacuum line to the FPR. There are lots of variables that I'm learning about....
    One of my current data mysteries is fuel pressure. At 15-16 PSI of manifold pressure, it holds steady at 70 PSI on a static base pressure of 58 PSI. Injector duty cycle doesn't ramp up dramatically, the lambda target holds, and total fuel flow is well below the fuel pump's capability. My theory is that either the FPR or the Fuel pump have maxed out pressure wise, but not on flow capability. I'm contacting Aeromotive to see what they think....
  8. #1033
    Def's Avatar
    Aug 2002
    SW22, Volt
    The Aeromotive regulator should be able to do a base pressure of 58 psi, and I don't think there's a limitation for the rising rate, as that's just pressure across the diaphram. I will say that my regulator out of the box had a super leaky pressure port fitting. The regulator spring is right behind the port, so you can't just screw it in more. I think I used some green loctite on the fitting to really seal it up, as it'd slightly bubble with even 3-4 wraps of teflon tape on it. It was 1/16" NPT IIRC.
    As for a noisy fuel pressure signal, that is real, and it's not necessarily "normal." You can run a fuel pulsation damper. More and more OEMs are using them on cars. Here's a nice aftermarket solution: http://www.radiumauto.com/Blog/Post/...lse-Dampers-90
  9. #1034
    Aug 2012
    CT
    Twin turbo LS E36 M3
    The double sides sword of good data. You see all these cool things, but you also see a bunch of things that dont make sense either.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  10. #1035
    Jul 2005
    PEI, Canada
    2001 330i
    I was involved with a nitrous pro-mod program from 2008 to 2011. It was using a MASSIVE wet single stage with PWM control, and there was a LOT of work being done on the fuel pressure side. What was learned was that you didn't just need "a" damper, you needed one tuned to the resonant frequency of the fuel circuit. There were a few different iterations tried before it was "right". The Radium one I suspect is tuned for the S54 fuel rail and fuel system.
    You can see the damper mounted to the end of the fuel rail in the image below with a very high resolution fuel pressure sensor on the bottom. (It was like $500 IIRC?)
    You'd want to do an FFT analysis of the fuel pressure trace to see if there was a problem. We found that the issue was in the frequency domain, not in the time domain....
  11. #1036
    Def's Avatar
    Aug 2002
    SW22, Volt
    Why would the Radium damper be tuned for an S54? It's more often used on Japanese imports than anything else...
    I don't really agree it needs to be perfectly tuned for a system either, as providing a much more compliant accumulator (which is what it does) is naturally going to smooth out fast pressure responses, regardless of its natural frequency. I would also argue the compliance of the accumulator reservoir is so soft that it is likely VERY FAR from the natural frequency of the fuel injector pulses, even at idle.
    My very rigid PTFE hose and hardline fuel system got a huge amount of resonance between the 2-5k RPM range, and above that it was likely getting smoothed somewhat from the sensor response time. The same system with a lot of rubber lines in it was nice and smooth all over. OEMs started using a lot of fuel pulsation dampers when they switched from plain rubber fuel lines to the low permeability type hoses in the early 2000's.
    tldr; Natural freq of pulsation damper is likely so far away from excitation freq of system that there is no concern.
  12. #1037
    Jul 2005
    PEI, Canada
    2001 330i
    Have you ever talked to Paul Yaw?
  13. #1038
    Aug 2012
    CT
    I like nitrous and pro mods.
  14. #1039
    Jul 2005
    PEI, Canada
    2001 330i
    Detailed look at oil pressure:
    There's nearly 70,000 samples of oil temp, across 2 driving sessions with I've overlaid to show consistency. I have filtered the values based on temp, which you can see on the legend on the top right. I can overlay lots of files...but you get a sense of the trends from these 2.
    From this data, I then populate a slightly modified oil pressure warning system in the M1 ECU:
    If the oil pressure exceeds the low or high value limit, the oil pressure alarm triggers. Then, if the alarm is active for a duration of my choosing, I can limit engine RPM to a set value. In this case, I've chosen 2000 RPM, and the alarm triggers the SLM to flash red at me.
  15. #1040
    Apr 2006
    Minnesota eh?
    86 325es
    neat
  16. #1041
    Toronto, Canada
    E36 Turbo
    That's sweet
  17. #1042
    Jul 2005
    PEI, Canada
    2001 330i
    One more for fuel pressure:
    Fuel Current = Lift Pump + Main Pump + Injectors (Total current draw of fuel system)
    2 log files over-laid.
  18. #1043
    Def's Avatar
    Aug 2002
    SW22, Volt
    No, who is he?
  19. #1044
    Toronto, Canada
    E36 Turbo
    No, who is he?
    Co-founder of Injector Dynamics
  20. #1045
    Jul 2005
    PEI, Canada
    2001 330i
    I'm going to try a lighter weight oil, probably a 5W40 Motul 300V. Will be interesting to see how it shifts the pressure/temp signature....
  21. #1046
    Bellingham, WA
    e30
    Yes it will.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  22. #1047
    Jul 2005
    PEI, Canada
    2001 330i
    Just set up the fuel and oil pressure channels to be able to log at 1000 hz.
    If anyone reading this has a Motec M1, you won't be able to do this unless you have 2 things:
    1.) Logging Level 3
    2.) Development License
    The default oil logging rate is 10 hz. You can reduce this frequency in M1 Tune, but you can't increase it. To go from 10 hz to 1000 hz sample capability, you have to change in M1 Build both the sensor input logging rate, and the update script under the pressure group.
    Fuel pressure is limited to 100 hz logging from Motec, so you have to do the same thing to that channel.
  23. #1048
    Jul 2017
    Zurich
    TT RS
    What kind of extra info do you think you'll be able to get by logging oil pressure at 1000 hz vs current rate? And can you put 1000 hz into perspective as far as how fast/slow it is compared to the frequency you are using to log most other sensors?
  24. #1049
    Def's Avatar
    Aug 2002
    SW22, Volt
    Do you think your transducers are going to give good information at 1000 Hz? In my experience, you need some pretty fancy stuff to actually get usable/accurate data at that rate.
  25. #1050
    Toronto, Canada
    E36 Turbo
    I can't see any good reason to look at pressures at 1000 Hz at all.
