What exhaust size will be on this e46 ? 3" or larger ? Looking forward to seeing the data.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
1996 332IS
Built 3.2
I'll let you know how Urethane works...
3" from the turbo all the way to the back, with 1.75" WG pipe re-circulated.
I've got 3 mufflers from Magnaflow in that flow path (6" in front, 14" in middle, 24" in back) I went with different sizes to try hit a wider range of resonant frequencies.
I actually have thought about that, and put an app on my Macbook called "Soundview" that lets you see spectrum distribution. If I really wanted to go nuts, I could dig out lab grade stuff at my Dads. (LMS) Looking to get the car up and running, then doing some sound analysis to see if there's anything sticking out.....
A couple of guys I know with HPF cars (E46 Turbo) were sick of the drone, and added a Helmholtz resonator to their exhausts with good effect.
Fourier is an FFT analyzer for iphone/pad. I have to say its pretty easy to at least remove unwanted sounds using ashrae calculations and the app. I havent experimented with it beyond removiing unwanteds but I did obliterate the crap that I wanted gone.
....from the black car in 2008:
I miss her...
My Motec M1 ECU licence is being upgraded significantly again.
To understand how, a bit of background needs to be explained.
The Motec M1 platform gives the user a choice of 6 ECUs (Hardware), and pairs it with either a generic, or custom firmware package.(Software) You pay for the hardware and software to run it separately, but there is a fairly wide choice of firmware packages now versus when the ECU first was released in 2014. In addition to this, there is another piece of software available (M1 Build) that allows you to write your own firmware starting with a full featured Motec template. Then there are the logging options, which have levels of licensing that you can buy, followed by data analysis software called i2 which also has a basic and advanced version. ($$$)
The Options:
GPA Generic Package (Normal Functions)
GPR Generic Package (Includes race car functions)
Custom Packages for specific vehicles (Features locked by creator)
M1 Build Licence (Unlimited feature authoring based on GPR Project)
Level 1 Logging - Basic fixed channels, and low logging rate. (1 - 10 Hz)
Level 2 Logging - 200 Channels, including basic fixed channels, logging rate user selectable on individual channels up to 200 Hz.
Level 3 Logging - 2000 Channels, logging rate user selectable on individual channels up to 1000 Hz.
i2 Standard Data Analysis - Basic Analysis and graphing software for up to 12 channels simultaneously. 1 Workbook.
i2 Professional Data Analysis - Full featured analysis and graphing software for unlimited channels, and unlimited workbooks.
What I had:
M150 ECU
M1 Build License
Level 2 Logging
The new configuration:
M150 ECU
M1 Build License
Level 3 Logging
i2 Pro Data Analysis
This will allow me to continuously log all kinds of channels of interest, instead of picking and choosing which ones I have room for on the log. Secondly, and most importantly, I will be able to do extremely detailed data analysis with the logs.
The Steed Speed Twinscroll is going to be one heck of a "lab" toy....
What's your plan for low boost ? Unless your running an EFR with dual gates, you may not be able to control it under 13#. This is factoring a 3" exhaust.
With a 3.5 or 4" exhaust, that 13# becomes 23-28#.
1996 332IS
Built 3.2
The level 2 logging was pretty good, but level 3 is crazy
Do you have the ability to output the data logs in a .csv or some other format? I usually write matlab scripts to look at what I want in the data...but having ready made software is the way to go
You can output in .csv, but you don't need to. i2 Pro has extremely flexible maths channel functionality. Besides, with data analysis....you really don't know what to look for until you look at it. i2Pro lets you setup workbook/worksheet templates for any data input, so you have a baseline of view tables. From there, it's really up to your creativity....just like Matlab.
The car is back together, and has 2 test drives under it's belt.
The transmission won't go into reverse. (Yes, I know where it is...and the shifter is setup to go there) When you push the selector up and left, it slots into "a gear" but it's 1st gear. 5th gear is fine.
No help from Google on this....any ideas anyone?
1996 332IS
Built 3.2
there are two compression springs with locking pins that secure the reverse and the fifth gear. they often fail. have you checked them?
parts 11,12,13,14
http://bmwfans.info/parts-catalog/E3...hifting_parts/
1996 332IS
Built 3.2
To rule out the fancy shifter, you can disconnect the dssr , stick a screwdriver in the shift selector bushing and manually put it in reverse.
Is this a 5 or 6 speed ZF ?
1996 332IS
Built 3.2
On a completely separate note, the Steed Speed Twinscroll is holding 10 PSI of boost on a 10 psi WG spring (Using an MVR). Spool isn't as quick as I was hoping, but I think this is probably a function of how I have the VANOS tuned and very conservative ignition timing. Once I have some time to sort through all the data, I'll post some graphs here.
The solid engine and transmission mounts make driving even 20 kph an event. It definitely feels like a race car....and the added noise being transmitted through the chassis makes the exhaust note difficult to hear. I honestly think it's louder inside the car than outside....and that's with full sound deadening in place.
I've also fully plumbed in and wired up the Water/Meth injection system. (I previously hadn't gotten to that) There's a dedicated flow control valve for pre-turbo injection, and a second flow control valve for manifold injection. This should make for some interesting control strategies.....
There's a test and tune session next Tuesday night that I might take the car out to make a few passes. We'll see how I get on with many other projects that need tidying up.....
I pulled up the boot and stuck a flashlight in there.
The shifter is hitting the mounting plate, then as you move it forward, it follows the curve of the circle.
What's interesting is that I mounted the shifter so that in neutral, it sits dead center of the circle.
Either I pull the exhaust and driveshaft off to move the mounting plate (It's really a block off plate), and still might encounter the tunnel metal, or I take a grinder to the mounting plate and hog out the area needed for the reverse throw. Looking to do the latter....
This is exactly an issue I had. Personally I would open that base plate up with tin snips/dremel/whatever. It's too small IMO. Also hate to say it, but get rid of that boot too. Again, too small IMO. I almost had a couple mis shifts going into 5th and the shifter sliding into 3rd. So I must have been a hair the other way from where you are at. These shifters have zero clearance.
1996 332IS
Built 3.2
