Page 60 of 62 FirstFirst ... 103550515253545556575859606162 LastLast
Results 1,476 to 1,500 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #1476
    Apr 2006
    Minnesota eh?
    86 325es
    Ah, gotcha.
  2. #1477
    Jul 2005
    PEI, Canada
    2001 330i
    The next thing I need to figure out is the clutch situation.
    With the 76mm turbo, I could make over 900 ft/lb.....and from experience it is good to have a little bit of extra capacity for drag racing launches.
    My current CM850 twin disc clutch won't hold that power, so I contacted a vendor to go over options. I was advised to go with an entirely new basket, and either a twin disc or triple disc plate stack. (These are custom clutches from Clutch Masters)
    Another option I'm considering is going to a Tilton Carbon / Carbon triple disc....but the price is nearly 3 times that of the Tilton triple disc.
  3. #1478
    Apr 2006
    Minnesota eh?
    86 325es
    Keep it nice to drive. Get a carbon carbon tilton or a mantic twin or triple disc. The mantic twin is $1000 with no flywheel. You can either machine an m20 flywheel to bolt it on or I have a solidworks file I can send you and you can have someone CNC one out of steel.
  4. #1479
    Jul 2005
    PEI, Canada
    2001 330i
    Thanks for the options!
  5. #1480
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    The Tilton 7.25" dual disk cerametallic (rally clutch) is not bad to drive honestly, especially when you pair it with a flywheel that has some inertia. You can probably get a nice Tilton 8.5" setup too if you're going to make crazy crazy power, but the 7.25" stuff will hold quite a lot (800 ft-lbs isn't hard from what I remember).
    A carbon clutch is nice, but they tend to wear quickly, and I seem to recall their driveability goes down as they get hot and the coefficient of friction ramps up.
  6. #1481
    Jul 2005
    PEI, Canada
    2001 330i
    I talked to people that have first hand experience with the products that I'm looking at. One of them is currently at the Nurburgring.....on track as I write this....testing for the race this weekend. Others are doing things far in excess of my goals, and had useful feedback. Again...first hand experience...or in some cases...I got to sample stuff.
    Tilton triple disc carbon / carbon clutch
    Tilton flywheel
    Tilton HRB
    Tilton 800 Series pedal box
    Tilton 79 series master cylinders
    Incoming.
  7. #1482
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    Quote Originally Posted by PEI330Ci View Post
    Tilton flywheel
    Tilton HRB
    Incoming.
    Now THAT is quite a stack, my friend! Interested in your decision to go with the pedal box in lieu of a dual master cylinder booster (e.g., Massive Lee) delete to achieve manual braking. I have gone back and forth with that decision on my E46 M3 race car.
    Regardless, all good stuff!
    Best,
    Peter
  8. #1483
    Apr 2006
    Minnesota eh?
    86 325es
    Very nice!
  9. #1484
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by herrubermensch View Post
    Best,
    Peter
    Thanks! I'm not sure if I'm more excited about the clutch or the pedal box!
    I went with the dual cylinders to allow tuning of brake bias with the wide range of tires I'm liking to have in the back of the car.
    The Tilton pedals also will allow me to put my feet where I'm most comfortable, and adjust the pedal effort to taste.
    Very nice!
    Only took me 10 years to pull the trigger....
  10. #1485
    Mar 2018
    Australia
    E36 BMW
    HI, I use a OS Giken Tripple. not bad to drive and holds the power I make.
  11. #1486
    Jul 2005
    PEI, Canada
    2001 330i
    Delicious ATI:
  12. #1487
    Jul 2005
    PEI, Canada
    2001 330i
    The old ATI damper that was good to 600 HP:
    Comparison of the 600 HP damper and the new 1200 HP damper:
    The LPS Fab Alphaloc coupler:
    I'll be using these instead of silicone couplers/t-bolt clamps, or Wiggins clamps. A 1/8 turn twist, and they come apart without any bits to hold. (No pins, or clamps)
  13. #1488
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Is the stock BMW damper good for 240 hp?
  14. #1489
    Jul 2005
    PEI, Canada
    2001 330i
    In new condition yes. Over time the rubber ring wears out....
    N62 throttle body:
    New throttle pedal, linkage, and position sensor:
    From left to right - 76 series clutch master cylinder, 79 series front brake master cylinder, 79 series rear brake master cylinder:
  15. #1490
    Jul 2005
    PEI, Canada
    2001 330i
    Clutch and brake fluid reservoir:
    Hydraulic throw-out bearing kit:
    Tilton 800 Series Pedal box:
    Billet brake bias adjuster:
  16. #1491
    Jul 2005
    PEI, Canada
    2001 330i
    Tilton flywheel:
    Tilton triple disc carbon/carbon clutch:
    I'm impressed with the details from A.R.E.
    This is a billet machined oil tank cap:
  17. #1492
    Jul 2005
    PEI, Canada
    2001 330i
    The cap installed:
    The bottom of the oil tank has an interesting fitting:
  18. #1493
    Vancouver, B.C., Canada
    '97 M3
    All of that is a step up from the usual low budget stuff around here. I love the clutch but that is a pricy piece. 250-300 ft lbs per disc.
  19. #1494
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Laying it down! Nice kit.
  20. #1495
    Jul 2005
    PEI, Canada
    2001 330i
    The clutch in the configuration that I've selected is rated by Tilton at 1005 ft/lbs, and was bench tested on a torque dyno to over 1300 ft/lb. (Tilton break-in, and test every carbon clutch prior to shipment) I've also selected the softest hub spring; there are a number of stiffer springs that I can change to that will increase the capacity further at the cost of additional pedal effort.
    However, I didn't chose this clutch because of torque capacity alone. Everyone that has driven one has said it has the best modulated slip of anything they have ever tried. For a street car, that is mostly about my enjoyment of experience, this was a very important strength. Secondly, the heat capacity of this clutch will make running multiple back to back passes at the drag strip a breeze. It's service life is also well beyond any conventional clutch...
    The fitting is for a 110v oil heater element:
    I'll be able to pre-heat the oil before running the engine.
  21. #1496
    Jul 2005
    PEI, Canada
    2001 330i
    Spintric Air / Oil separator:
    The fluid that is pulled out of the dry sump oil pan is basically a foam of aerated oil. (This is the working state of fluid in wet sump oil pans as well) The Spintric has a velocity based separator element that removes a lot of air from the oil mixture coming from the engine. The Spintric outputs oil and air separately to the top of the Oil Tank, each getting a dedicated entry location to maximize further de-aeration of the oil. The entry point of the oil into the tank also promotes swirling of the 2.5 Gallon oil reservoir, which has 3 additional baffle plate systems to further de-aerate the oil.
    To summarize, the oil foam is pulled out of the engine's oil pan with 3 suction stages, passed through the Spintric to remove air, circulates through 3 stages of baffles in the oil tank, then is pulled out of the bottom of the oil tank to be circulated back to the engine by a 4th pressure stage in the dry sump pump housing.
    4 Stage A.R.E. dry sump pump:
    The oil volume and pressure can be tuned by varying pulley sizes, and there is pressure regulator in the pressure stage to fine tune the pressure curve.
  22. #1497
    Bellingham, WA
    e30
    Those Spintech deaeration systems are nice. The ARE stuff is finished off really nice.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  23. #1498
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by wazzu70 View Post
    Not only is the product great, the people you deal with are first class. Great experience so far!
    This is the universal mounting plate you can get for the pump:
    Super nice mounting brackets for the oil tank:
  24. #1499
    Jul 2005
    PEI, Canada
    2001 330i
    A.R.E. dry sump pan:
    Billet remote oil filter housing:
    A standard SBC filter screws on.
  25. #1500
    Jul 2005
    PEI, Canada
    2001 330i
    Oil Tank vent can.
