Page 59 of 62 FirstFirst ... 9344950515253545556575859606162 LastLast
Results 1,451 to 1,475 of 1544
Thread: E46 330i Automatic - M54B30 Turbo
  1. #1451
    Jul 2005
    PEI, Canada
    2001 330i
    3.391
    2.319
    1.725
    1.295
    1.000
  2. #1452
    Jul 2005
    PEI, Canada
    2001 330i
    Life beyond synchros...
    Regardless of torque capacity, does one really want to limit their shift speed?
    The bigger the turbo, the more important this topic becomes.
  3. #1453
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You should buy a samsonas.
  4. #1454
    Jul 2005
    PEI, Canada
    2001 330i
    If you placed a 50% deposit up front, how long would you be willing to wait for one?
    I've been informed it's 9 to 12 months...from someone who currently uses one. (An owner/vendor)
  5. #1455
    Jun 2005
    New England
    You should have placed the order 9-12 months ago.
    In that price range, I might look at the Tremec T56 Magnum. I like the top loader shifter since it won’t lose the geometry due to flex of motor and trans mounts under load/windup.
  6. #1456
    Jul 2005
    PEI, Canada
    2001 330i
    Are you referencing the ZF cased gear set, or the 5 speed Sequential?
    I was looking at the Sequential, which comes in at $11k.
    More recently I've been talking to GForce and Liberty about drag specific gearboxes....
  7. #1457
    Jun 2005
    New England
    For drag specific use the Ford C4 or the Chevy 3 speed others are working on adapting.
    I would guess the drag racing season is shorter on PEI than in NH. If you have to do all the safety stuff we have to do here, the car you don’t drive very much now will become a car you barely ever drive.
  8. #1458
    Mar 2012
    Renton, Wa
    98 m3
    Why not go with a s6-53?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  9. #1459
    Jul 2005
    PEI, Canada
    2001 330i
    Thanks to a gluttonous global economy over many decades, and a complete disregard for environmental consequences, PEI might have it's summer drag racing season expanded from 4 to 6 months! Woo hoo!
    The TH400 is still under consideration, but I am more focused on how fun the car is to drive, vs how outright quick it is. I still want to take it on road courses, and then there's my unfulfilled ambition from the black car of doing Targa NFLD.
    Quote Originally Posted by vollosso View Post
    Shift speed.
    I'm looking to go to a dog box, with non-H pattern shifting.
  10. #1460
    Jul 2005
    PEI, Canada
    2001 330i
    After a few revisions, this is the gearing that I'll be using:
    3.391
    2.186
    1.670
    1.295
    1.000
    Diff is 3.62
  11. #1461
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    You take this thing on the highway at all? 1:1 with a 3.62 would get... old.
  12. #1462
    Mar 2013
    Upstate NY
    M3
    Don't you need dog style engadgement for high power stuff? Pretty sure synchro transmissions are just prone to not shifting under high power reguardless of who it's by. I'm sure that's an arm and a leg option for BMW.
  13. #1463
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by Def View Post
    Where I live, I would have a really hard time seeing that speed on public roads.
    The gearing is for the drag strip.
    If I wanted to do something else, like an airstrip event, I would just change the diff.
    Quote Originally Posted by Mklock View Post
    I bought a GForce GF-5R:
    Dog engagement
    Straight cut gears
  14. #1464
    Mar 2013
    Upstate NY
    M3
    Guess I'm lazy as I'm sure you've covered it but any reason why you are wanting manuel transmission? I know they do keep certain classes in drag racing.
    Enjoy the straight gears, rally car noises incoming.
  15. #1465
    Jul 2005
    PEI, Canada
    2001 330i
    I want to drive the car.
    This is more about my interaction with the machine, than the result it achieves in ET.
  16. #1466
    A house
    '86 325e, '14 VW EPA
    Synchros are for synchronizing the internal shafts of the transmission, they are not meant to be exposed to any load beyond the momentum of the shafts and gears. So the amount of power the transmission is fed by the motor is irrelevant but what does matter is the violence of the shifts. If you try to shift a synchronized transmission quickly, even though the mass of the transmission shafts isn't very significant, asking the change in velocity to happen very quickly results in a LOT of force which the synchronizer clutches aren't meant for and will wear out prematurely. This is when the transmission will appear to be hard shifting.
    That's where the dog boxes shine because while they are painful to drive casually/inattentively, requiring double clutching (using the clutch to synchronize the transmission internally for the next gear), they enter their element on track. If you shift them like an asshole and get your throttle timing right (lift as you move the stick for up shift, blip for downshift), then you don't need the clutch except to get rolling and it shifts like a sequential, and you can slam gears all day long, quickly and safely.
    It's one of those things that needs to be answered when you are deciding what you want from the car - reliable violent operation on track, or quiet, smooth and easy operation cruising around on the street. Dog boxes, even without straight cut gears, sound like they're a pile of rocks by modern standards and require extra effort to operate (either mental to get your rev matching right or physical via double clutch). Synchronized transmissions are buttery and quiet shifting on the street but won't last being shifted quickly.
    Or get a DCT and you can have your cake and eat it while receiving a blumpkin.
  17. #1467
    Jul 2005
    PEI, Canada
    2001 330i
    That's a pretty darn spectacular explanation, comrade.
  18. #1468
    Apr 2006
    Minnesota eh?
    86 325es
    Cool. Whats are you planning to use for a bellhousing?
  19. #1469
    Toronto, Canada
    E36 Turbo
    I could not imagine anything shorter than the 2.93 I have personally with no OD.
  20. #1470
    Jun 2005
    New England
    I drove a 3.64 for a year or so while supercharged and liked it everywhere but on highway trips over an hour long. With 255/40/17 a 3.64 is more like a 3.58.
  21. #1471
    Jul 2017
    Zurich
    TT RS
    Quote Originally Posted by PEI330Ci View Post
    Dog engagement
    Straight cut gears
    Could you set it up with some sort of shifter activated ignition cut for no-lift shift?
  22. #1472
    Jul 2005
    PEI, Canada
    2001 330i
    Quicktime
    Quote Originally Posted by NOTORIOUS VR View Post
    I probably misread his comment.
    With the 5 Speed ZF....I didn't mind driving around in 5th with the 3.62 diff. Keep in mind the speed limits where I live are 80km/hr most places, and there are some 90km/hr roads, but I stay off of them because there are lots of cars. (Main access)
    Quote Originally Posted by AlexQuattro View Post
    That functionality is already on the car, I just haven't been using it. I have cut on upshift, and blip on downshift available.
  23. #1473
    Toronto, Canada
    E36 Turbo
    Well that certainly makes a big difference for sure... Here most highways the traffic is flowing anywhere from 120-140 km/h... that get's old real quick with a short diff lol.
  24. #1474
    Apr 2006
    Minnesota eh?
    86 325es
    Quicktime
    Is that going to be a one off or are they going to add that to there catalog? GF-5R uses the regular 4 bolt muncie bolt pattern right? If so that would open up options for a ton of 4 and 5 speed race boxes for people.
  25. #1475
    Jul 2005
    PEI, Canada
    2001 330i
    This one:
    https://www.holley.com/products/driv.../parts/RM-4089
    Don't mind the CAD...it looks backwards in a couple of images.
    GForce will do an adapter plate on the transmission to fit any Bellhousing.
