Results 1 to 4 of 4
Thread: E83 x3 auto transmission fluids how many QTs
    Nanjing, China
    2011 328xi
    I am going to change auto transmission fluid on my 2004 X3 3.0i. I am wondering how many quarts fluids I need? I searched many threads, but I did not see any clearly saying how many quarts are needed. I guess 5?
    Also, I found the fluid has to be Dexron VI, so is this fluid OK? Thanks a lot.
    Fluid: Castrol 06822 Transmax Dexron VI Automatic Transmission Fluid
    Why am I always getting some code?
    Illesheim, DE
    750i, 280ZXT
    Valvoline Dex VI is what I chose for mine. It took just under 5.5ish quarts per change. Changed the sump oil twice, dropped the pan, and filled up. Bought 20 bottles and returned 3.
    Nanjing, China
    2011 328xi
    Quote Originally Posted by 750i View Post
    So it takes only 5.5 quarts per change? So your 17 quarts is for 3 changes? I am sorry I am trying understand you precisely.
    Illesheim, DE
    750i, 280ZXT
    Yeah... I remember it not needing quite 6 quarts per change. The reason I did three is because that's the only way to do a full fluid change without a machine. You end up with about 90% new fluid.
