Results 1 to 25 of 25
Thread: Battery master switch? S818A
    Dec 2012
    barrie ontario canada
    90 & 92 735i 2004 MINI
    Just looking at the Data for vehicle identification number: WBAGB4316NDB70111 for my 92 735i and under Optional Equipment is: S818A - Batteriehauptschalter - Battery master switch. Is there a switch (anti theft) to turn off the battery somehwere that I don't know about?
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Those switches were installed at BMW factory in Germany before shipping vehicles over sea, to safe battery life due to long travel.
    When car arrives, dealer removes the switch and sell car without it.
    I've installed that switch separately on my car...
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The complete unit looks like this http://www.bimmerboard.com/members/q...y%20Switch.jpg http://www.idon-industries.com/bimmer/various/89.jpg
    The dealer ships it usually back to the factory.
    Zionsville, IN
    93 740i, 84 533i
    Do they just leave it lay in the trunk and leave the key there, but in the off position? Or do they tuck it in behind the trunk's panels?
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    dancerst's Avatar
    Virginia Beach, VA
    They just leave it in the trunk
    Feb 2008
    Calgary, AB, Canada
    BMW 850, Alpina B10 Biturbo, Alpina B12 5.0
    Is that the OEM switch or an aftermarket one you have in there? I have been wanting to do something like this on my cars as they go into hibernation for the winter. Saves having to pull batteries or have a fleet of trickel chargers. If you could kindly share some detail on how you installed that and what you used I would greatly appreciate it. Or if there are instructions somewhere I could follow.
    cheers,
    Rob
    The kids:
    Alpinas: 91 E34 B10 Biturbo; 91 E32 B12 5.0; 91 E34 B10 3.0 Allrad (mom's car); '91 B10 3.5
    Bimmers: 91 E31 850; 93 E34 525i w/ aftermarket turbo; '01 X5 4.4; 93 E31 850i Dinan TT; 89 E32 750il Dinan TT; 92 750il w/ S70 engine and transmission
    Mercedes: 92 600sel; 93 S600 Lorinser
    VW: 04 Jetta GLS TDI
    dancerst's Avatar
    Virginia Beach, VA
    This is a Hella Battery main switch.
    They were used by BMW.
    It's about 8 feet long.
    I don't remember if I have pic of installation process, but I'll look.
    Brantford ON Canada
    735iL - 1989
    My E32s are fitted with simple switches like: NOCO ID220S 6V-24V 125 Amp Battery Disconnect Switch
    They work great! You do have to lift the rear seat to get at it, of course. It's a good theft deterrent as well.
    Loveland, Colorado USA
    1993 740i
    I have one in my car, it's on the right side of the trunk. Pretty flimsy looking piece of black painted plywood and a red handle. Makes it easy to disconnect the battery if I'm working with the airbags or around the starter. I'd take a picture but it's dark and raining out...
    '93 740i - Mine
    '13 Range Rover Sport - Hers
    '08 Land Rover LR2 - Hers
    '96 328i - Son's
    '97 328ic - Daughter's
    '87 944 Turbo - Mistress
    '74 Alfa Romeo Spider - Italian Mistress
    Northern Colorado, USA
    Dec 2012
    It doesn't list it on the data sheet for my 1990. Looks like the ones used as emergency shut offs on race cars. You can get them after market, I just thought mine was already equiped with one.
    1993 740i
    Finally remembered to take a picture of mine:
    '93 740i - Mine
    '96 328i - Son's
    Feb 2008
    Calgary, AB, Canada
    Thanks for posting that - nice clean install!
    The kids:
    Zionsville, IN
    93 740i, 84 533i
    Does that completely shut down everything, including clock and radio? It might be worth it to run a power line to them to bypass the master switch.
    1993 740i
    It shuts down everything
    '93 740i - Mine
    '96 328i - Son's
    Nov 2013
    Wellington, New Zealand
    1989 BMW 735i
    Out of interest - Why would you want one? If you just wanted a theft deterrent it would be much easier to have a switch for the starter or something? I guess in the USA winterising your vehicles would be a good reason.
    1993 740i
    For the record, my car lists "S818A Battery master switch" on the VIN decoder, so I'm assuming it came from the factory with it installed, maybe they forgot to remove it prior to delivery?
    '93 740i - Mine
    '96 328i - Son's
    Feb 2008
    Calgary, AB, Canada
    For me it is for the winter hibernation. I store most of my cars in the winter and it would be easiest to be able to just turn a switch like this rather than having to lift up the rear seat to disconnect the battery each time.
    The kids:
    West Coast
    two 3's one 5 three 7's
    Quote Originally Posted by cdnalpina View Post
    Why don't you just disconnect the negative cable rather than remove the rear seat? This is a pain on the iL models.......
    This can be easily done by popping open the access panel and undoing the 13mm nut, at least you could do this on your e32's.
    Zionsville, IN
    93 740i, 84 533i
    Quote Originally Posted by whiteghost1 View Post
    Very easy to do. Plus, that is exactly what that is designed for.
    Also, Every BMW shipped from Germany has a battery master switch listed on its build sheet. It us supposed to be removed by the dealership and returned to the factory.
    Jan 2005
    Japan
    Feb 2008
    Calgary, AB, Canada
    I always wondered what that plastic part there was for! Thanks so much guys, that makes life a whole lot easier!!
    The kids:
    Jan 2005
    Japan
    The battery main switch for transportation from factory to verseas is shown here again, the factory options sheet list "Battery Master Switch", option code S818A
    http://www.bimmerforums.com/forum/sh...-Master-Switch
    Jul 2011
    Portugal
    1990 BMW 850i
    Sorry, is that cover + ground wire inside the cabin on the 8 series?
    Jan 2005
    Japan
    It is the cover and ground wire inside 7 series E32. On the E31 8 series the 2 batteries are not under the seat, they are in the trunk, so completely different arrangment, better ask in the E31 forum for details.
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Related to this thread is the question " How best to store the battery over the winter in a cold climate?" I previously removed the rear seat cushion, discon the positive cable and put on a ctek charger on it, inspecting every 2-4 weeks. Then I got a little smarter and used the hot post in the engine compartment so that the charger would stay out of the weather. This way, all electronics were normally energized. But beware: crappy chargers will boil your battery dry. CTEK's are pretty good, I top it off when I put the White Whale to sleep, but I check fluid level every month. Sure wish I had a heated garage for it, but that precious spot is taken by my E24.....
  1. S818 battery master switch
    By ross1 in forum 1988 - 1996 (E34)
    Last Post: 01-13-2017, 07:43 AM
  2. Battery Master Switch
    By kpintoronto in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-05-2015, 03:58 PM
  3. Battery master switch
    By bimmernuwb in forum 1995 - 2001 (E38)
    Last Post: 11-01-2012, 01:20 AM
  4. Battery Master Switch?
    By jammer1138 in forum 1995 - 2001 (E38)
    Last Post: 10-31-2012, 10:57 PM
  5. Battery Master Switch??
    By DV8OR in forum 1988 - 1994 (E32)
    Last Post: 09-07-2012, 04:43 PM
