Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 433
Thread: My New Project: LS/T56 swap into a 2003 E39 M5
  1. #26
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by James39 View Post
    Love the interior! Looks like a Dynavin or something already installed too.
    Looks like OEM NAV.
  2. #27
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by rao View Post
    Great point
    I would use the Ford mount. It doesn't hang below the transmission and you know it fits.
    Agreed.
    Did some mock up with the BMW mounts and it's a no go. At least it would be a lot of effort to make them work so Ford mount it is.
    I have a mount drawn up to work with the Ford mount. Just need to grab some steel from the local place before they close at noon then I can get to work.
    Just OEM Nav.
    Interior needs a lot of cleaning. Previous owner loved to eat in the car and was messy. There were fries all over the bottom of the driver's seat. Add a summich and you could make a McDonald's kid's meal.
    Seats are currently out of the car so that I can shampoo the carpets.
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
  3. #28
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
  4. #29
    Jan 2012
    Frederick, MD
    2001 BMW M5
    Quote Originally Posted by Schitzo View Post
    Btw.. thanks to Thaniel's work, I was able to get the oil temp gauge and LED lights working with the GM oil temp sensor. Will document that thoroughly in case you would like to do the same for your car.
    I saw your post in Thaniel's thread that you were able to get the oil temp gauge/tach lights working on the M cluster, that's awesome! I've been meaning to work on it when I find the time. The only other thing I'd like to get working is the cruise control buttons on the steering wheel. Right now I'm using some Rostra buttons for cruise.
    2001 M5, 5.3 LSx/T56 swap with I6 subframe (rack and pinion steering):
    http://forums.bimmerforums.com/forum...th-I6-subframe
  5. #30
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by zr6sbc View Post
    Sweet car. In the end, I think the M5 is the way to go. So much of the good stuff.
    I recall my 2002 E39's NAV display having engine related data. Do you think it can be Thanielized? That would be neat.
    Hi Lenny, I think it is doable. I assume you would have to take the info from the LS and inject it into the K-bus. An OBD to K-BUS gateway of some sort should work.
    Got some work done on the trans cross-member but did not get it finished.
    Here is rough sketch of what I have in mind for the mount.
    I started by making the center section, or the "little metal couch" as the girl called it.
    First measured the bolt spacing on the Ford mount. Here is a neat trick for measuring a bolt pattern. It works if the bolt (or bolt holes) being measured are the same diameter. Measure one bolt then zero the caliper. Next measure the bolts, end to end. The measurement you see will be the distance between the centerline of the two bolts. In my case, 3.128". I marked the position for the holes on the plate, center punched it, then drilled the holes.
    Not bad!
    Next I bent the plate to match the angles on the mount, then added a back plate and two side plates. There is plenty of space between the plates and the rubber mount itself.
    Once everything was lined, I tacked the plates then sewed them all together.
    Next up will be tying the little metal couch to the chassis. I think I'll use some 1-1/4" tubing I have.
    Build Thread
  6. #31
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Nice tip using the calipers.
    You must have a nice heavy duty break to bend that steel plate.
  7. #32
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I always love your threads, and this one looks like it will continue the trend of awesomeness -- Fantastic looking fabrication on those mounts!!!
    What are your plans for the engine build? An LS 427 e39 M5 sounds like one phenomenal idea.
  8. #33
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Loving this... subscribed!
    E39 LSX SWAP PARTS FORSALE
  9. #34
    Minneapolis,MN
    2003 M5, 2014 535i
    I wouldn't call it heavy duty but it works for my needs. 1/4" steel plate is the max thickness it'll take. I use it on a 20 ton HF press.
    Quote Originally Posted by tptrsn View Post
    Nothing too crazy. Just looking for something with decent torque and more importantly, great street manners. It has to be something I can deal with on a daily basis. More details to come.
    Build Thread
  10. #35
    Nov 2014
    Los Angeles
    E39 M5, E3 Bavaria, supe
    Subscribe, and good going so far!
  11. #36
    VA
    E63AMG/Z31/Tacoma/F31
    Are you using the same motor as I have or going with aluminum block?
  12. #37
    Minneapolis,MN
    2003 M5, 2014 535i
    It's an aluminum block.
    Build Thread
  13. #38
    Feb 2008
    Upstate
    I would love to see documentation also.
    Thanks in advance
  14. #39
    Buffalo, NY
    2001 BMW 540i/6
    nice tip on the bolt spacing. Glad to see some documentation out of your hard (done right) work.
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
  15. #40
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    Subscribed!
    --Peter
  16. #41
    Minneapolis,MN
    2003 M5, 2014 535i
    I finally had a chance to fabricate the rest of the transmission mount this evening.
    Tack welding the pieces together while laying on my back underneath the car turned out to be the most difficult part of the entire process.
    Tacks made.
    Crossmember welded up. Later on, I will add a doubler plate to tie the square tubing to the back of the center section.
    For the driveshaft, I'll be running a CF single piece from DSS. Frank at DSS made me an offer for the CF shaft as consolation for some issues I had had on a prior transaction with his shop.
    Once I provided him with the DS length, he had it to my door in less than 2 weeks. The shaft is 46" long, 3.25" in diameter, and weighs 12 lbs.
    Once I mounts the DS, I check it for runout. This is not necessary but certainly does not hurt. I check runout at the front, middle and rear. Max runout I measured was 0.006 - 0.007" which should be fine.
    The fitment is tight around the front u-joint. There is about a finger clearance between the shaft and body. I'm sure this is ample clearance but I may still cut the hump pictured below to allow more clearance.
    Next up I'll work on the exhaust, starting with headers.
    Build Thread
  17. #42
    DeWitt, Michigan
    Looking beautiful! (And I love your plan for a large displacement LS motor. I may have to ponder that in lieu of my normal thoughts of a turbo--packaging under e39s is so damn tight...)
    I'm guessing you have a hoist to work on? If not, what is your setup to get your car up in the air sufficiently to work under it with nice clearance like that?
  18. #43
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    Nice work on the transmission mount, looks stout Robert.
  19. #44
    Minneapolis,MN
    2003 M5, 2014 535i
    A lift would be nice. I'm on jackstands.
    Quote Originally Posted by ckpitt55 View Post
    I will place an order for exhaust tubing so hopefully I can start on that this coming weekend. The headers will be tri-y (4-2-1) and either mid or full length. I'm staying away from full 4-1 headers for the sake of clearance including ground clearance. I'd prefer the headers not hang below the frame rail. Past the headers will be dual 2.5" pipes with cats and an X-pipe at the fuel tank. I have yet to decide what to do for the mufflers.
    Build Thread
  20. #45
    Mar 2004
    USA
    96 328is 6.0L
    ... I'm staying away from full 4-1 headers for the sake of clearance including ground clearance. I'd prefer the headers not hang below the frame rail.
    I would imagine if it is possible to do 4 into 1 and still not hang below frame rail on e36, then on e39 it should be even easier
  21. #46
    Aug 2011
    Salt Lake City
    '95 M3, 97' E39 540i-LS3
    Nice trans mount.
    What happened to the killer 2-pc drive shaft that you built up?
    540i-LS3-TR6060 swap thread
  22. #47
    JimLev's Avatar
    Sundance Mesa, NM
    Robert, nice CF driveshaft and everything else you do.
  23. #48
    Jul 2011
    Houston
    LS e39, LT e53
    Hey nice to see another one of your build threads . Havn't been on this side of the forums in a while.
    2006 X5 L83 5.3 6l80 swapped in progress
    1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
    2007 ZX-10r - sold
    1987 R-10 SWB L83 5.3L 6L80e swapped
  24. #49
    May 2014
    Vancouver,WA
    00 Maxima SE
    OP,
    Any idea what Durometer that tranny rubber mount is?
    FEEDBACK THREAD
    00-03 Nissan Maxima HID Retrofit
    6th gen AV6 FX35 Retrofit
    Chassis and Suspension
    2011 Space Grey E82 N55 DCT
    2000 Sunlit Sand Maxima SE 5Spd.
    1997 Arctic Silver E36 M3/4/5.
    1997 Techno Violet E36 M3 Coupe 5Spd (SOLD).
  25. #50
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by bimerok View Post
    If fabricating a full length 4-1 header, the 4 runners would end-up in the area directly underneath the floor board. The distance from the floor board heat shield to the bottom of the rail is 3.25". If you stack two 1.75" tubes in there, they will hang below the frame. My car is not that low tubing sticking below the frame rail will not necessarily scrape but I know that is all I would see looking under my car and it would drive me insane. I'm ok sacrificing a few ponies for ideal fitment.
    Nice trans mount.
    Thanks. The 2 pc has been partially parted out. The aluminum rear section and the transmission yoke were sold to be used on a Miata 5.3/T56 swap.
    I will put up the mid yoke for sale on an offroad forum. That yoke is commonly used on front driveshafts and intermediate shafts on crawlers.
    Quote Originally Posted by Genes1s View Post
    OP,
    No idea but if I was to guess I'd say 50A to 60A.
    It has a hollow center and does have some give to it. It is comparable to the stock GM T56 mount.
    Build Thread
