Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 101 to 125 of 336
Thread: My first turbo build....m52/t4spa/6262
  1. #101
    Aug 2014
    United States
    97 M3, 08 X3, 96 VW TDI
    Sweet, I'm prepping my charge and down pipe for welding. Tough trying to keep up with you.
    S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
    97 BMW M3
    | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
  2. #102
    Nov 2013
    VA
    E36
    Quote Originally Posted by fletcher0780 View Post
    Hell yea! I'll spend this weekend timing the engine with the m3 cams/vanos and then install the turbo. At the end of the month I'll buy all the coolant overhaul parts and get the oil bung and IC piping welded. First startup, should be at the beginning of March at the latest.
  3. #103
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by xcghcgh View Post
    Looks great. From personal experience, get those M3 cams as soon as u can. Night and day vs the m52 cams.
    Reported , we don't like you types around here.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #104
    Nov 2013
    VA
    E36
    Bimmerforums is getting killed by these fake accounts
  5. #105
    South Carolina
    2004 330 vert 2004 X5
    Following this build. I'm collecting parts for my S52 turbo. Why did you pick the 6262 turbo?
  6. #106
    Nov 2013
    VA
    E36
    Quote Originally Posted by flyfishvt View Post
    I picked up a t4 spa off of ebay for $250 which is pretty cheap. However, the variety of turbo options is very limited when compared to the t3 spa manifold. But some people have already tried the 6262 and 6466 on the t4 including highboostingm3 who has helped me alot up to this point. Plus if I ever go fully built, the 6262 is more than enough to support 500+.
  7. #107
    Nov 2013
    VA
    E36
    Going to button up the head tonight. Anyone know the best spark plugs to use for turbo setups? I would also like to know the gaps that are used. I've been told between 0.20 and 0.25. Thanks!
  8. #108
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by bmw328m52 View Post
    .022
    1996 332IS
    Built 3.2
  9. #109
    Nov 2013
    VA
    E36
    .022
    Missed a decimal place but that's what I meant haha. Thanks again butters!
  10. #110
    dublin, Virginia
    95' 325is
    I've always heard OE style copper plugs with that gap do the best.
  11. #111
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    NGK 4554's gapped to .022ish have worked well for me and many others. They're also only like $1 or $2 a piece and I change them with the oil and filter every 2k miles or so. Always nice to get frequent updates of what's going on inside your combustion chamber
  12. #112
    Nov 2013
    VA
    E36
    Thanks for the advice. Some pics of my progress this weekend. Sometimes I wish I would've went top mount.
    M52 vs S52 cams...thanks again m3mods!!!
    Need to get a new dump tube made. But this will do for first startup.
    I was able to get the oil return line straight down. This setup is not the final install....
    Its awesome finally seeing everything come together. First startup should be late February! Also does anyone know which o2 sensor Jordan(RK Tunes) uses? Is it bank 1(first three cylinders) or bank 2(cylinders closest to driver)?
  13. #113
    Aug 2014
    United States
    Jordan told me he uses bank 1. Are you using a factory O2, or are you using a wide band and connecting the narrow band output to the DME? I put 2 O2 bungs in my down pipe in case the DME is finicky about the signal it wants to see. worst case I'll run two sensors, otherwise I may fit an EGT in one and wb in the other.
    97 BMW M3
  14. #114
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Your aftermarket wb02 narrow band output may not read the same as a factory titanium oxide 02. Maybe you could program it to do so but I am not sure it will match up perfectly with a tune designed around the factory input. Seems like a recipe for issues to me, but let us know how it goes.
  15. #115
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    Hey glad I could help. Love seeing the progress, keep up the good work!
  16. #116
    Nov 2013
    VA
    E36
    Jordan told me it is and only bank 1 o2 sensor. I have two o2 bungs in my downpipe so I'll use one o2 sensor for the ecu and the other o2 sensor that came with the wideband. I just ripped off the oil pan today and I'll send it off to ar design for the oil return bung. Also did a complete coolant system overhaul. Getting so close!
  17. #117
    LI NY
    Turbo 99' M3
    Quote Originally Posted by m3mods View Post
    Synthetic oil I assume? If so, thats really excessive no?
  18. #118
    Nov 2013
    VA
    E36
    Quote Originally Posted by jszy25 View Post
    ^That's what I was thinking. Especially when running a thicker oil like 10w60 for turbo setups...
  19. #119
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    It is excessive but it takes me a few months to put 2k miles on the car so it's not really that expensive. With how much money I already have invested into the built motor & turbo, I don't mind spending a little extra on oil and filters every couple months.
  20. #120
    Manchester, N.H.
    96 332IS 6466 turbo
    Goes in clean, comes out clean. I save my "dirty" turbo e36 oil, and use it on my Dakota winter drift truck.
    1996 332IS
    Built 3.2
  21. #121
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    Haha hell yeah the old t100 is my recycler of choice
  22. #122
    Nov 2013
    VA
    E36
    Got some work in over the weekend.
    Wired oil pump unt
    Ar design weld in bung
    Not very confident with this drain setup. Theres a slight kink but when it is reduced there is no downward slope going to the bung. Need to figure something out.
    Fabbing FMIC piping
    As of now, I just need to get the fmic piping welded, install the intake mani with my ptuning vacuum block for all vacuum lines, and download tune. First startup is near!
  23. #123
    Apr 2012
    Tampa, FL
    E36,E38, and E46
  24. #124
    Huntsville, AL
    95 M3
    Can you get back in there and redue that lock wire?
    WOT
  25. #125
    Oct 2012
    NYC
    93 e36 sedan
    Quote Originally Posted by hsvturbo View Post
    Def pulling the wrong way, also needs to twist in between nut and anchor.
