Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 301 to 325 of 336
Thread: My first turbo build....m52/t4spa/6262
  1. #301
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    If you are dragging and drifting you will break the 188 diff or the output shafts and have to go to a 210 and the delicate and pretty cover that is helpful only on a track car will no longer fit.
  2. #302
    Nov 2013
    VA
    E36
    Not dragging nor drifting, but maybe track days. In all honesty, the rogue diff cover is overkill even on a lot of track cars. I just bought it cuz its too damn sexy lol.
  3. #303
    Manchester, N.H.
    96 332IS 6466 turbo
    I don't think there is one of those for sale in the country. I'm real happy I was able to get one.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #304
    Jun 2005
    New England
    You just buy a broken E32 750il, remove the diff and crush the car.
  5. #305
    Nov 2013
    VA
    E36
    ~Update~
    Everything is back on the car and feels better than ever. But I decided to sell the fenders as I was too big of a p*%sy to drill my quarters. Instead, I purchased a set of Apex arc8s 17x9.5 et35 square. I'm still debating on tire sizes but I think I'm gonna go 255/40. I will post pics when I receive the wheels later in the week.
  6. #306
    Nov 2013
    VA
    E36
    I've been so busy lately with a new job at work but I'm finally back! I decide to go with 255/40 dunlop star specs and couldn't be happier with the grip. The car hooks up so much better especially with minimal camber. I was gonna turn up the boost this year but with everything going on I doubt it will happen. I still need a clutch...
    L
    Last thing is to get a proper alignment so I can finally enjoy car season.
  7. #307
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by bmw328m52 View Post
    Finally had the time to remove the head off the car. Every single valve was leaking after the valve job by the machine shop. I guess this explains the 50 psi compression in all cylinders. They gave me my money back for labor but refused to reimburse or meet me halfway for a new head and new cutring gasket. VAC motorsports is going to supply a head and recondition it for me and I'll get the new gasket from CES. Literally, the one thing I go cheap on in my build and it bites me in the butt. You definitely get what you pay for.
    Why did you have to do valve job on the head? When you say "cheap" what was cheap about it?
  8. #308
    Jun 2006
    lombard,il
    93 325is
    Why did you choose star specs? Ive been debating for while on what tires to go with.. 595 rsr, r888 for the rear, rs3s. Def looking on the cheaper side as this will be a daily hence the 595s.
  9. #309
    Nov 2013
    VA
    E36
    Quote Originally Posted by hakentt View Post
    Someone recommended a local shop to machine my head. They're pricing was good so I told them to check the valves as well. I should've turned around when they said they couldn't measure surface roughness. Long story short every valve leaked after their work but I got a head built by VAC and all has been good since. I've learned never go cheap on machine work.
  10. #310
    Nov 2013
    VA
    E36
    Quote Originally Posted by abq View Post
    I barely drive the car and traction was an issue. I was looking at rs3s but they're a little more sketchy in the rain. Tirerack also didn't have them in stock. I've used these tires in the past and the grip has always been top notch.
  11. #311
    Feb 2009
    Arizona
    1998 e36
    Means nothing. You can pay a lot of money for machine shop work and it still can be a bad product. All it takes a good machinist on his bad day.
  12. #312
    Nov 2013
    VA
    E36
    Okay thanks for your helpful insight. 30 days left and counting.
  13. #313
    Jul 2014
    Finland
    BMW E36 328i Turbo
    Something new going here? Readed the thread all the way from post 1. Nice job with this e36
  14. #314
    Nov 2013
    VA
    E36
    Nothing really but thanks. Currently working on my LM-2 data logger/bimmerlogger so I can log outputs coming from the ECU. This year has been busy but next year will be interesting. Up the boost, new clutch/trans parts, full black interior and makeover.
  15. #315
    Aug 2014
    United States
    97 M3, 08 X3, 96 VW TDI
    How much boost are you running now? I've got my base set to about 8psi with a high boost 15psi switch. rear tires are junk, getting new installed today. 1st and 2nd were useless on high boost mode. I'm thinking about replacing my old turbonetics bov with something I can actually buy parts for.
    S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
    97 BMW M3
    | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
  16. #316
    Nov 2013
    VA
    E36
    I'm running 11 lbs and make around 400whp. Tires hook really well though from a dig.
  17. #317
    Virginia
    97' m52 turbo
    So,
    How many miles on your build? Hows the car running? Psi?
  18. #318
    Nov 2013
    VA
    E36
    Quote Originally Posted by 328iFun View Post
    So,
    Just saw this comment lol. Car has been running great until recently after sitting for about two months. At about 2k rpm, the car starts going lean and it continues into boost. I'm going to check the vac line going to the fpr and clean the maf to start. I'm currently running 18lbs off spring.
  19. #319
    Feb 2009
    Hackettstown, NJ
    1998 328i
    At what rpm are you seeing 18lbs? I'm thinking of going spa mani and 6266 or rsi and s366. The internal struggle I'm having haha.
  20. #320
    Nov 2013
    VA
    E36
    Quote Originally Posted by 96bmftw View Post
    Right at 4k with jb 6262 precision. Plan on going with garret gt35r bb for road racing next year.
  21. #321
    Nov 2013
    VA
    E36
    Been awhile but I thought I'd update this thread. The local college, VA Tech, where I got my ME degree had a nice car show this year. In addition, they even had a dynoject. I've never dyno'd my car since turning it up 17 lbs so I decided to go for it. For $40 you can't go wrong for two runs.
  22. #322
    Jun 2005
    New England
    485/425 is fun and relatively trouble free. Good result for an M52 at 17 psi with 6262. Stock cams or S52 cams?
  23. #323
    Nov 2013
    VA
    E36
    Thanks. But yes this is with s52 cams
    Sent from my Moto Z (2) using Tapatalk
  24. #324
    Virginia
    97' m52 turbo
    Nice
    Sent from my SM-G960U using Tapatalk
  25. #325
    Nov 2013
    VA
    E36
    Hey its been awhile since I've updated this thread. Still running on 18lbs(490whp) and the car has been running great. However, I've broken 2 non m axles within the last year so I've decided to start upgrading the drivetrain/brakes.
    New brake setup
    Porsche 996 calipers front/rear
    Fronts machined 12mm by rally road to run 17" wheels
    Cross bridges/bleed screws have been swapped on rears.
    Rally road brake lines front/rear
    e46 m3 non csl front rotors
    e38 750il rear rotors. I've heard this gives correct hub diameter for proper ebrake adjustment
    CM Motorsports adapters
    Drivetrain
    Free m3 front spindles, trailings arms, and axles(thank you Gary)
    M3 subframe with AKG 75D subframe bushings
    Rogue differential cover with with AKG 75D bushings front/rear
    Going to run my old RTABS again
    Wheel bearings, ball joints, e-brake shoes, ebrake cables, and dust shields all new
    Now to the pics.....
    If you notice one of the front subframe bushings was installed wrong. It was a long day but has since been fixed. Things left do...
    -repaint all the calipers(don't know if I want to use brembo decals)
    -brake pads...anyone know of a good set that don't cause squeal in the rear?
    -install 75d diff bushings on the rogue cover
    -wheels???...don't think the front 17x9.5et35 concave wheels that I have now will work. Yes I can use a spacer but I'd have to run a lot of camber. Cutting my fenders up isn't an option....
