It usually flips sides because it encounters resistance like you would at the end of a tape. Due to the gearing inside. I had the same problem with mine that was connected to a 3.5mm jack input and fixed it. If you are using a cassette adapter with a cable do this:
Pry the cassette adapter apart at the seam like a clam. Remove the gears inside that interconnect the 2 spindles together. This relieves any tension from the gears inside and make sure the spindles now spin freely. Put halves back together and use small pieces of scotch tape to wrap across the edges to secure it.
1998 (9/97 production date) 540i 6 Speed Sport / black on black / shadow trim / debadged / black-out grill / Carbon fiber roundels / 80w Yellow Fogs / 2.81 non- lsd diff. / 17" BBS Sport Style 19 wheels/ 245 all around tires / modified CDV / Stage I Dinan software / 5w30 synthetic/ 244k miles and counting
E65 2007 Alpina B7: Black on Black, Supercharged autobahn eater, 500hp/515trq, 245/295 tires, 141k miles with major systems rebuilt/replaced!
