this is retarded when you update things and what once worked no longer works. I have windows 7 32 bit ie 11 and java 8u25. I have installed the SGV plugin several times by the way.. When I select US on the WDS main screen it says
"CAUTION
Your system does not meet the technical requirements
to view the content!
Please read System Requirements and Installation.
and the system test indicates:
Browser
Browser OK: NO Java enabled: Yes JavaScript enabled: Yes
Adobe® SVG Plugin
SVG Plugin installed: NO
does anyone know how to fix this? I have spent quite some time and only gotten java to finally show loading on the System Test page.
much appreciated,
Clint
2006 X5 L83 5.3 6l80 swapped in progress
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
i gave up and just use this, they fixed all compatibility issues and made it web based
http://www.bmw-planet.com/diagrams/release/en/
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Just in case someone else needs to run wds 12.0 on Windows 10 Home. This is how i got it to work :
Google Chrome Version 50.0.2661.94 m
SVGview v3.0 ( installer from cd)- install as admin
Java Runtime Environment v1.6.0.23 -install as admin
IE TAB ( Chrome extension) https://chrome.google.com/webstore/d...bkbammjbdenadd
THX Seapaladin, IE TAB is the solution
