Page 27 of 27 FirstFirst ... 21718192021222324252627
Results 651 to 674 of 674
Thread: Mike's "Vanilla Gorilla" M3 V2.0 Build
  1. #651
    Louisville, KY
    turbo m3
    Quote Originally Posted by MikeE36 View Post
    This is the 9180 still. I don't have my hands on an 8374 yet. Mike
    sounds like it comes on strong.
    How much does your car weigh?
    This is my signature....
  2. #652
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by BadBoostedBmwM3 View Post
    2650-2700 ish. I weighed it awhile back and it was 2640 with a 1/2 tank of fuel. I'd say it's probably 2700-2750 lbs with a full tank of fuel right now. I'll put it on the scale again soon.
    Mike
    IG: @mikevanshellenbeck
  3. #653
    Joliet, IL
    Out of Service
    On your fuel tank lines update, I'm a bit confused on what you did with the large vent line, where your fuel return goes and how do you get fuel from the drivers side to the passenger side?
  4. #654
    Austin, TX
    S13, Turbo M3
    Did another event this weekend with Lonestar Drift. It was a combo practice day / teaching event for newer drivers.
    Here is a video from a passenger cam of a lap on Saturday's layout:
    It was a blast! Most of the event it rained, so there was almost no tire wear all weekend and I was able to drive a ton. I checked the fluids saturday morning, and didn't open the hood again all weekend!
    Mike
  5. #655
    Austin, TX
    S13, Turbo M3
    More video - The Lonestar Drift 2017 season starts next weekend, so expect a bunch more content soon!
    I am in love with this thing all over again! It is working so well right now. I'm really really pleased with it.
    Mike
  6. #656
    Vancouver, B.C., Canada
    '97 M3
    Mike
    Still on the EFR 9180?
  7. #657
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Dude, you're an internet sensation!
    Question for you, I notice you don't just let the wheel spin via self-steer like the S-chassis guys seem to do. Is that something about the E36 chassis, or just your personal preference?
  8. #658
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by tptrsn View Post
    Thanks!
    E36's don't seem to self steer nearly as much as the S-chassis do, so I just have to deliberately point it where I want to go.
    Mike
  9. #659
    Austin, TX
    S13, Turbo M3
    Yesterday was pretty fun
    Mike
  10. #660
    '97 M3
    What turbo and turbine housing are you using these days?
  11. #661
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by chikinhed View Post
    This is an 8374 1.05 A/R at 25psi on E85. I have run it at 30psi but it broke 3rd gear the first event I tried. The powerband is awesome.
    Mike
  12. #662
    '97 M3
    Have you dynoed it? Do you have boost creep issues?
  13. #663
    Austin, TX
    S13, Turbo M3
    Have not been on the dyno since the swap to the 8374. I'm not sure it creeps necessarily, it just runs way more boost than what the Tial spring colors suggest it should. I have 1 bar springs and it hits 25psi, but it does it everywhere, not just up top as RPMs increase.
    Mike
  14. #664
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    How light is that car? Looks like a blast to beat on. Power to weight looks nuts
  15. #665
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    Just saw your car on AdamLZ's latest YouTube video. Car looks and sounds great Mike!
    Sent from my VS988 using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  16. #666
    DeWitt, Michigan
  17. #667
    Apr 2006
    Minnesota eh?
    86 325es
    Nice work Mike, you do us proud
  18. #668
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by philly98540 View Post
    I've only weighed it years ago and it was 2660 with 1/2 tank of fuel and no driver. I think It's probably 2750-2800 lbs with a full tank of fuel.
    Quote Originally Posted by tyr283 View Post
    Thanks!
    Internet sensation!!
    That backwards entry was wicked.
    Thanks! It was super fun
    Thanks!
    Here's some more clips from Harris Hill Raceway, as well as MSR Houston. This old 2.9L still puts in work!
    Mike
  19. #669
    '97 M3
    Is your cage tied into the rear subframe mounting points? Pics of back half of your cage please.
  20. #670
    Austin, TX
    S13, Turbo M3
    Yes it is, all 4 subframe points as well as the RTAB pockets and rear shock towers. I'll shoot some tomorrow for you.
    Mike
  21. #671
    Austin, TX
    S13, Turbo M3
    Here's some more fun laps - this thing is still out doing work!
    8374 EFR, 1.05 A/R, 25 psi on E85:
    20 minutes of road course drifting!
    Enjoy!
    Mike
  22. #672
    Apr 2012
    Peoria , AZ
    2002 325i
    Man that looks like so much fun! One thing I noticed was that your car doesn’t self steer? Is there a reason for this?
    | BAGGEDE46 |
  23. #673
    DeWitt, Michigan
    This was discussed quite a bit in a thread in the drifting forum, and I was really interested in the topic at the time. After riding in the car though, I have to say that I didn't notice anything odd at all. Mike and the car are total animals, and the car seems to behave ridiculously well considering all of the mayhem that is happening.
  24. #674
    Apr 2012
    Peoria , AZ
    2002 325i
    Yeah I’m sure it’s fine for his driving lol, I just mentioned it because it looks like a handful sometimes!
    | BAGGEDE46 |
