Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 152
Thread: E30 Street/TimeAttack
  1. #101
    Oct 2014
    Finland
    E30 & E36
    Thank you lughed!
    I've forgot to post few updates, but here's one video clip
  2. #102
    Oct 2014
    Finland
    E30 & E36
    Here's more comprehensive update of what's done and what not:
    S369 turbo seems to fill up the space effectively, in fact my earlier S467 was equipped with a rare small comp cover which is smaller in diameter...
    I got my injectors and made couple of weld bungs which turned out too short after drilling the holes
    Pile of ignition coils:
    I was thinking to order a laser cutted rack for coils, so I made a "coarse" 3D mockup one evening:
    Primarily I focused on drivetrain, gearbox adapter plate needed a few holes, apparently I had cutted my cardboard mockup along the wrong line and there was not enough material for one hole, but it was easily fixed with a welder:
    Before I was able to make a cross member I hung gearbox from the inside, also I've forgot to take pictures of the cross member and mounts in the chassis:
    The gear shifter episode:
    Got to start from somewhere, this is what felt a good location:
    And how it turned out:
  3. #103
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    super solid update!
    keep them coming!
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  4. #104
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Sick
  5. #105
    Jan 2016
    Stuttgart, DE
    1987 325iS
    absolutely gorgeous work man!
    Paynemw
    I Live in Stuttgart, DE now!
    1986 Toyota 4Runner SR5 - Sold!
    1987 BMW 325is 2.7L Track Build & Grocery Getter - Back in RVA driven by my pops
    1988 BMW 535is - RIP but my dream BMW
  6. #106
    Feb 2015
    Nevada City, CA
    E60 550i 6MT
    Oh man this is some hot action! Keep it coming
  7. #107
    Oct 2014
    Finland
    E30 & E36
    Thanks everyone! More updates as requested:
    I got my new longer injector weld bungs and welded the plenum chamber together. Injectors are Bosch 210lb with 15mm extensions with filters.
    I also got 2x 380LPH fuel pumps which will feed E85 through the 7micron inline filter.
    One day I scanned the oil pump back plate and made a 3D model, a blank will be most likely water jet cut, then machined:
    Apparently it was time to finish the new engine mounts, now with delrin bushing:
    You might remember I just did one gearbox cross member, but surprisingly I wasn't happy with the outcome so I did a new one:
    [/QUOTE]
    E60 M5 driveshaft needed to be shortened 400mm, I hope my welds will hold:
    While fabricating the drivetrain I wanted to revise rear axle carrier mounting one more time. I machined a couple of delrin bushings and formed some sheet metal pieces to get this appearance:
    Prototype of a M30 ignition coil rack was finished too:
  8. #108
    Oct 2014
    Finland
    E30 & E36
    I've seen lot's of discussion about damper/crank hub related problems in M30 engine builds lately. I found out some Finnish builders have used ATI 2JZ damper in their builds (both M20 and S38), but I wanted to have some facts before heading to buy one. That made me contact ATI directly, luckily I did, because they didn't recommend using 2JZ damper, probably because it's low weight/inertia (for M30). Their recommendation was bigger 7" damper for a SBC so I started to search one..
    One very slightly used item showed up on eBay so I had to buy it
    I'll have to fabricate a new crank hub and trigger wheel to make it fit, a good thing that's a serpentine damper so I can directly drive my alternator belt with it:
    Some time ago I acquired couple of aluminum chunks to fabricate some engine flanges, the first one was oil pickup plate I made by hand. Still need to add AN10 fittings to draw the oil line to remote oil filter sandwich plate.
  9. #109
    NJ
    323is Coupe
    this is amazing work, keep it up !
  10. #110
    Oct 2014
    Finland
    E30 & E36
    Sure, thanks!
    Yesterday I spent few hours thinking about the damper solution, first I gathered critical dimensions of the orginal damper, crank and hub, then I moved on designing new parts.
    Chevy hub is much sturdier than M30 hub, but changing the crank front seal to a next ID size I could grow the wall thickness
    Everything seems to fit rather well, trigger wheel could be located behind the damper which means orginal sensor location could be used, also belt line remains pretty much the same as orginal of course the v-belt pulleys should be changed..
  11. #111
    Oct 2014
    Finland
    E30 & E36
    I made two more flanges, one for water in and another for water out, I'll weld 40mm bends to both flanges. No more need for that big thermostat housing because EWP
    Earlier I acquired boxful of silicone hoses for coolant and charge pipes from size range 16mm to 100mm:
  12. #112
    Oct 2014
    Finland
    E30 & E36
    Quick update of the ATI damper I'm currently printing 1/3 of the trigger wheel.. why didn't I buy a bigger printer...
  13. #113
    Oct 2014
    Finland
    E30 & E36
    Here it is, took almost 1½ hours to print one third, at least it looks what it supposed to:
    Next I should try if it fits in the engine
  14. #114
    Aug 2011
    Lowell, MI
    VW TDI
    This is awesome! great use of a 3d printer too! makes me wish I had one.
    - Brad
  15. #115
    Oct 2014
    Finland
    E30 & E36
    Thanks! 3D printing can become a quite addicting hobby too I can tell... A printer isn't that big investment nowadays, they're getting cheaper and cheaper.
    Clutch setup arrived, probably not going to use twin mass flywheel
    Now that I also got silicone hoses I continued welding, first mounted a throttle body:
    Then the other side, that's the only place where I was able to mount blow off valve:
    Some coolant pipes and new mounts for the power steering pump:
  16. #116
    Aug 2011
    Lowell, MI
    VW TDI
    is that a nascar quartermaster? I take it you'll be adapting it to work with the current trans/engine combo?
    - Brad
  17. #117
    Oct 2014
    Finland
    E30 & E36
    It is, I'll just have to change disc hubs, a local company makes them. Those fine spline BMW discs are hard to find, anyway they're almost as expensive than this whole clutch assembly
  18. #118
    Oct 2014
    Finland
    E30 & E36
    I had some struggle machining the oil pump back plate manually, I did two versions which didn't turn out too good. I also tried a shortcut welding a sleeve into the orginal cast cover.. Because of the high Mg content welds won't hold even if they would look good, here's the result of light hammering, crispy:
    It was time to start over, I did some changes to model and discarded the idea of a water jet cut blank because of it's ridiculous price. I happened to find a company which would machine the part for me very cheap with their 5-axis machine. I just confirmed it fits by 3D printing a mockup:
    The final part (made of AW-7075) should arrive in three weeks
  19. #119
    Oct 2014
    Finland
    E30 & E36
    ...Not again
    Reason? I managed to change the engine position after modifying steering rack mounts, so when I renewed engine mounts I positioned it as low as possible and even further back. Besides the welds looked terrible now that I've learned to TIG somehow Upcoming version will be looking quite different.
    Now that I got the taste of cutting I cut the comp housing outlet too:
    To change it to this:
    Few Finnish fellows were inquiring M20/M30 cam sensor covers from us as we had made some 3D printed prototypes earlier (in co-operation with Juuso's Garage), these anodized aluminum versions are about to arrive soon:
  20. #120
    Oct 2014
    Finland
    E30 & E36
    Oil pan project:
    Front sump is only to clear oil pump:
    Long welds:
    Oil pan baffle with trapdoors, screws are only temporary, those will be replaced with rivets:
    Assembly taking shape:
  21. #121
    Oct 2014
    Finland
    E30 & E36
    Stainless steel oil intake screen, not yet welded, custom made of course:
    Aluminum fuel rail, not yet anodized, custom made of course:
  22. #122
    Oct 2014
    Finland
    E30 & E36
    This week I started and finished making a coolant reservoir and oil catch can with crankcase + cylinder head ventilation:
  23. #123
    Oct 2014
    Finland
    E30 & E36
    One more aluminum tank.. Fuel surge tank that has been in progress for a loong time. It needed a baffle inside, end cap and AN fittings for fuel in and out, unfortunately AN6 fittings were out of stock at the local store so I wasn't able to completely finish it Underneath my FPR with AN10 in/outlets:
    Finally got this part I've been waiting for, shiny aluminum bit from Italy:
  24. #124
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    So I take it you're sticking with turbo only now? No more Eaton SC to be added any more?
  25. #125
    Oct 2014
    Finland
    E30 & E36
    Yes turbo booost only, I should update the first post some day
    Okay where were we..
    Oil pan bolted to the engine and it still fits, couple of small additions need to be done before I can say it's complete. Oil stick will be attached with AN fitting, as easy as it gets:
    I ordered a batch of AN12 fittings and hose for IC water lines and oil breather lines (yeah I already welded stupid hose fittings in the breather can so I need to change them):
    Had to push the car out while cleaning the garage, notice my nice new wheels:
