Page 3 of 26 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 631
Thread: My 2000 Royalrot sport
  1. #51
    IL
    2000 740i sport
    Quote Originally Posted by M I C H A E L View Post
    You'd need to. Unless you want it running like a dog.
    My buddy has a spare good one I will use for testing before I purchase a new VW MAF...
  2. #52
    IL
    2000 740i sport
    When using a used MAF do I need to reset the engine adaptations on the ME7.2?
  3. #53
    Arizona
    2015 328i M Sport
    No
  4. #54
    IL
    2000 740i sport
    Quote Originally Posted by NordmanMg View Post
    19 are not that much expencive, i've got set from tirerack for 580+60delivery+60 mount and balance
    Whats the price for set of 20"s?
    When i bought my first bmw two years ago, i was looking for x5 20" y-spoke rims, but then find set from e65 with good tires for just $250, but drove down to indianapolis to get them
    Pirelli P Zeros 255 35 20 are $400 closeout on tire rack...
    http://www.tirerack.com/tires/tires....wtpackage=true
  5. #55
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    On this link one tire is $499
    i've got sumitomos for 580- 4 tires stagered set 2x-245/45/19 and 2x-275/40/19
  6. #56
    IL
    2000 740i sport
    Link shows a set of 4 for $400
  7. #57
    Sep 2014
    '01 DINAN7 '03 M5
    Oh, just look closer, it showing 21" tires for some reason,
    yea you are right, that is sweet price
    I might go for 20"s now lol
  8. #58
    IL
    2000 740i sport
    Does the air box have to come out to change the pass side xenon bulb?
  9. #59
    Toronto, Canada
    2000 740iL - 07/99
    Quote Originally Posted by purplecty View Post
    It doesn't need to, but it does make it easier!
    Follow me on Instagram @SEVEN40iL
  10. #60
    IL
    2000 740i sport
    Orielly's crap?
  11. #61
    IL
    2000 740i sport
    Quote Originally Posted by SEVEN40iL View Post
    Update:
    Swapped in a known good BOSCH MAF and housing my buddy had from his 540.
  12. #62
    Nov 2003
    Lake Forest, IL
    01 740i,E93 M3,E30 325is
    How do you like the 6000k hid? Now that I put in the angel eyes my lights look so yellow. Which ones did you get?
  13. #63
    IL
    2000 740i sport
    Quote Originally Posted by Staszek View Post
    http://pages.ebay.com/link/?nav=item...062089&alt=web
    Theyre nice and only $20 for the set. I definitely need new lenses and gaskets but that will be later when I decide to put AEs in... My fogs seem to be 8000k which I am not a fan of so I purchased a set of 6000k H3 fog bulbs from the same seller who happens to be local for 11.99...
  14. #64
    IL
    2000 740i sport
    So the car has a vibration when cold started after rpms fall and is slight when warmed up but the rpms do not move with the vibration at all. Maybe motor mounts or trans mounts?
  15. #65
    Feb 2013
    Pop the hood, start the car and hold the brake pedal while you shift from park, to reverse, to drive. If you see the motor move more than a tiny little bit, its probably time for new motor mounts.
  16. #66
    IL
    2000 740i sport
    Can trans mounts be changed without removing the trans? What does thos job take? Theyre $12 a piece...
  17. #67
    Sep 2014
    '01 DINAN7 '03 M5
    I dont remember how they look like, but if not mistaken you just need to jack the tranny a little bit and undo bolts on those mount and it will came out
  18. #68
    IL
    2000 740i sport
    Weekend plans...
  19. #69
    Arizona
    2015 328i M Sport
    Yes you don't remove the transmission
  20. #70
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    You don't have to remove it but you do have to support it. You can use a jack with a foot long 2x6 or bigger piece of wood to spread he laid on the oil pan to relieve the weight.
  21. #71
    Arizona
    2015 328i M Sport
    Quote Originally Posted by kouks View Post
    Yep!
  22. #72
    IL
    2000 740i sport
    Yep!
    I am going to check the spark plugs first
  23. #73
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Weekend plans...
    There's neither beer, nor whiskey in this pic? How do you plan on a job without the tools man?
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
  24. #74
    IL
    2000 740i sport
    Quote Originally Posted by Trasportador View Post
    I knew I forgot something...
  25. #75
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Shame on you. 10 demerits.... Coming along nicely she is. .
