Page 23 of 26 FirstFirst ... 1314151617181920212223242526 LastLast
Results 551 to 575 of 631
Thread: My 2000 Royalrot sport
  1. #551
    IL
    2000 740i sport
    Another e39 eBay fan after the other one died after a year or 2... Wish I would have known FCP offers these lower priced e39 fans before i purchased this one but oh well...
    Sent from my SM-N960U using Tapatalk
  2. #552
    IL
    2000 740i sport
    Finally got the black front seat belts in. I'd like to paint the middle b pillar trim black. I need to replace the b and c pillars so will do that then. Also ordered an arm rest phone delete...
  3. #553
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Slowly converting to the "dark side?"
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
  4. #554
    IL
    2000 740i sport
    Quote Originally Posted by Ruskii View Post
    Nope kinda of digging the 2 tone. Already has black carpet and black leather dash too. May get alcantera headliner and pillars at some point but someone did the headliner before and its still perfect, plus beige sport seats seem to be more rare than black or gray...
  5. #555
    IL
    2000 740i sport
    Alignment numbers. Are these ok?
  6. #556
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Well it appears Castor in the front, and Camber, in the rear are both still out of limits. I haven’t read all the pages of the thread but if you have lowering springs then that will affect the numbers.
    Is is it ok? I have no idea, as long as it drives straight and the tires wear evenly, youre good.
  7. #557
    IL
    2000 740i sport
    Monsoon speakers... Forgot to remove the foam in the middle so I hope it sounds good. They have never worked since ive owned the car...
  8. #558
    IL
    2000 740i sport
    Got it out...
  9. #559
    IL
    2000 740i sport
    Next up is door speakers and a basslink...
  10. #560
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I don't recall removing foam from my speaker deck when swapping monsoons. Mind sharing the purpose?
  11. #561
    IL
    2000 740i sport
    Dville noted this to allow the monsoons to breathe and port into the trunk better. I'd have to hear one with the foam still in to see the difference...
  12. #562
    IL
    2000 740i sport
    Replaced / installed 88c Euro BEHR mechanical Tstat, valve cover, UTCG and vanos solenoid gaskets, aux fan sensor in lower radiator hose, Hengst fuel filter w\ pressure regulator. Power steering reservoir and suction hose.
  13. #563
    Sep 2011
    Crawfordsville, IN
    96 750il
    Good stuff. You need to let me know if something is going on in Chicago.
  14. #564
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    83k miles? Didn’t you do guides not that long ago?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  15. #565
    IL
    2000 740i sport
    Quote Originally Posted by clarkitect View Post
    Ha that's just the most recent cluster I got without matching mileage. Its closer to 250k if anything but runs like it has 80k...
  16. #566
    IL
    2000 740i sport
    Changed the Oil with castrol 0w40 and a hengst filter...
  17. #567
    IL
    2000 740i sport
    The old lady has been running like a rolex and the AC is ice cold...
  18. #568
    Rutland, Vermont
    Seriously? Man that is smooth like buttah.
  19. #569
    IL
    2000 740i sport
    The numbers on 5 dropped to like 20 after I shot the pic. Not bad for 250k...
  20. #570
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I've personally only seen one Roughness that looked that good. It was Iceman's. Very impressive.
  21. #571
    IL
    2000 740i sport
    Quote Originally Posted by Mayorchuck View Post
    I was always secretly jealous of his...
  22. #572
    Feb 2017
    Chicago
    E38 M-Sport & Jaguar XK
    Nice work (as always).
    I need to get out and see your cars. I am still driving my sport shorty. Love it. Needs some TLC (preventative maintenance) but still a great car.
  23. #573
    IL
    2000 740i sport
    Replaced the front driver door lock actuator...
  24. #574
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by purplecty View Post
    You sure the engine was running?
  25. #575
    IL
    2000 740i sport
    Well that was shortly lived... Trans went into failsafe on the way to work and the gears are not lit up or selected. I will have to limp her home. Luckily I have access to a few position switches...
