Results 1 to 18 of 18
Thread: Electric Windows & Sunroof - Fuse 29 keeps blowing - help!!
    Oct 2014
    West Yorkshire, Wakefield
    BMW 840 Ci / BMW 320 D
    Hi Folks - my first post.
    My 1996 BMW 840 Ci has developed a small but highly irritating issue. The fuse 29 keeps blowing and disables the windows and sunroof (I am not sure if this affects anything else, not that I have noticed anyway). On the reverse of the fuse cover - 29 doesn't seem to correspond to the windows/sunroof which is a bit of head scratcher....
    It is tempremental - once I replace the fuse it might last a couple of days, but then it might only last a journey!
    I am not by any means electrically minded, could it be something simple like a worn/broken wire where it goes into the drivers door perhaps or something else? It almost has the feel of a 'dry joint' situation although I am only speculating!
    Anything anyone could advise? I am in West Yorkshire and would always welcome a chat if you are nearby.
    Rob
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Fuse 29 supplies (as well as a whole bunch of relays) the General Module (ZKE), and that controls the windows and sunroof. The realys are:
    Compressor Control Relay
    Normal and High Speed relay for auxiliary fan
    Auxiliary water pump relay
    Air Conditioning relay
    My BMW Repair YouTube Channel
    Oct 2014
    Hi Timm, thanks for the note bug any ideas what I need to do? Does this mean a relay is duff or that the general module needs replacing?
    Mamy thanks
    rob
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I would start with the most likely candidate - the compressor clutch - does you A/C work? Try removing K19 (in the Front Power Distribution box) and see if the fuse doesn't blow any more.
    Oct 2014
    Hi Timm, this seems to have cured the problem! My a/c did stop working before this started happening. Is it just k19 that needs to be replaced or is there possibly something else underlying?
    thanks again
    Rob
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It will be the A/C compressor clutch itself - unfortunately they do get frizzled sometimes and the coil ends up looking like a disorganised bird's nest! The clutch is on the front of the compressor, and just like a fridge where the compressor runs for a while and then turns off in cycles, the compressor on the car does the same - using the clutch to connect and disconnect it from the ribbed belt.
    I have heard that the clutch can be replaced separately from the compressor, but I haven't done this myself. If you are not mechanically minded a good A/C company could do this (possibly), but might just replace the compressor.
    Oct 2014
    Thanks again Timm. Is the compressor the air-con radiator? As you can tell I am not mechanically minded! Will it do any harm in the meantime using without that k19 relay? Rob
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No, it looks a bit like an electric motor which is stuck on the lower RHS front of the engine:
    Leaving the relay out will cause no problems at all.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    the clutch can be replaced separately, but if your taking it to a shop to be fixed then most shops will simply replace the entire compressor.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Oct 2014
    Quote Originally Posted by legoman67 View Post
    Thanks very much for the advice! Really appreciated. Rob
    Thanks very much Timm. Guess I need to find a new compressor! Really appreciate your help here, you know your 8 series! Rob
    Jul 2017
    Redlands, California
    1970 E9, 1994 E31,E30
    Dear Timm,
    Im new in this blog, long time BMW driver and motorrad
    Jul 2017
    Dear Timm,
    Greetings. In the subject of AC compressor and power windows. My AC CLUTCH froze. Suddenly all windows and sunroof stopped operating from the inside controls. Now only work from outside . That is to open all or to close all.
    how do I fix this? I applied the instructions above, or close. I removed K9 and swapped with another thinking it had damaged the relay. No luck .
    Kindly, please share your experiençed opinion. This E31 1994 840 CI is a new project tô me.
    thanx
    I am ordering a new compressor and drier asap. After all this is SoCal. Try driving W/O AC HERE- it's a torture. Will issue be resolved automatically w new AC.
    So the AC and the power windows and sunroof have a relationship, kinda funny.. Like a Pit Bull and a cat. Hard to grasp
    Jul 2017
    Introducing myself and the user name. When in Stuttgart, I'd see this word all over the highways . But the name spelled and sounded so familiar to the result of eating too much beans.. So Just funny. I ride BMW bikes old and new, drive older BMW classic because life is too short to drive Boring new electric cars. ( Unles you are driving to Vegas, then you want a car that flies.
    Jun 2018
    Silicon Valley CA
    '95 840
    I have an '95 840 and am having the same issue. Blowing Fuse 29. I also was having no AC. Removing K19 brought back my AC but the fuse 29 blew again. I understand I may need to replace/repair the AC Compressor. What should I do about the Fuses in the interim? K19 and Fuse 29. Thanks!
    Orlando, FL USA
    Quote Originally Posted by caffeineplease View Post
    Replace fuse #29 and if K19 is not bad, reinstall it. Don't use your A/C until after you get the A/C clutch rebuilt. I had the same issue with my car when I first got it. On top of that, the auxiliary water pump valve body was stuck on so hot air was blowing on the driver's foot well all the time...especially when driving during summer time...not fun!
    Jun 2018
    Silicon Valley CA
    '95 840
    Quote Originally Posted by ChrisFuture8 View Post
    Thanks. A follow up question. I could use the name of a good BMW repair shop for this classic. I see you and I both in the South Bay. Can you recommend someone?
    Orlando, FL USA
    At Caffeineplease:
    Sent you PM.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    This happened to my 95 840. I replaced the compressor. Good to go.
