I want to replace the Bridgestone RE050As on my 135I with a non RFT tire. I'm looking for better ride comfort and all season performance. Any suggestions?
Thanks.
I'd recommend the Michelin Pilot Sport A/S 3s. I used to work in a tire shop and have sold a lot of them. They are definitely a good tire and they always seemed to wear very nice and have great reviews.
Also it looks like you have 215/40r18 front and 245/35r18 rear, not 235 rear.
The only option is the Michelin AS3. They are very good in wet and dry but they are below average in the snow. To get into other tiers you are going to have to change sizes some. If I can help with the tires let me know.
Haha that's funny. At first I typed in the 215/40 and 235/45 he had listed as the sizes and there were a bunch of all season options. How often is this thing driven in the snow?
If you run winter tires you can go with a 225/40R18 all the eay around. If not you are going to need to go with a 255/35R18 on the rear for more tire options. The only problem is the 255/35R18 is tight on the rear.
Karjim-
Made the conversion to Non RFT on my '09 135 a little over a year ago.
I went with Michelin Sport A/S Plus (believe these are the AS3). I went with 225/40ZR18 (front) and 245/40ZR18 (Rear). So far I love them! I have around 18000 miles and tread looks almost brand new (although I am due for an alignment).
These tires are much more compliant than the BS RFT that were on the car previously which is better for me as this is a daily driver. The tires are still sporty, but they do have a little more "give" than the RFT, but definitely not bad (I dont track). Only thing I might do differently is either drop from a 225 to a 215 and from a 245 to a 235 aspect ratio while maintaning the 40 sidewall height ratio or keep the wider tires and drop to a lower sidewall height (such as 35).
This wouldnt make a huge difference, but should tighten up the ride just a little.
Edit to Add- Ran these through Atlanta's snowstorms last year and they actually did pretty well although I would not want to do so all the time.
If anyone knows of a temporary spare option please let me know
A/S Plus are different than the AS3. The AS3 is basically the newer version.
The tires do have some differences as well though. One big difference to me is the A/S Plus are directional and the AS3 are not.
Good info. Yes, mine are directional. About to rotate which will mean a mount dismount. May just do the fronts and the rears are pretty even wear. Because of different sizes I cant rotate front /rear.
