Results 1 to 12 of 12
Thread: No Start after INPA use on E66!!!!!
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    My friends 2006 760LI won't start and we are getting a 2737 ews 3.3 manipulation protection. Error type:8, help please!!!!! (Did not reset adaptations because of the car having two DME)
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    It also says 1B vvt error ecu service not supported and 1E vvt2 error ecu service not supported.
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    2737 ews fault
    Sep 2014
    Ohio
    2005 E66 745Li
    My first foray into INPA with my '05 and I have 47 errors including the same 2 messages at the very top of the list-1B vvt error ecu service not supported; 1E vvt2 error ecu service not supported. The car runs fine, but the dash is all lit up. While I'm too green to help you out, would appreciate it if you would keep the thread going and let us know what you find and how fixed. Cheers.
    Sep 2014
    Ohio
    2005 E66 745Li
    So I've learned a bit to share....the 1B and 1E VVT1/2 errors are meaningless. Apparently INPA cannot read the (2) VVT modules as there is no info to read. They are apparently very simple, maybe just a data table providing output to control the VVT actuator. Point being the fact that INPA can't read them takes us both back to the ECU-EWS alignment error. My '05 745Li E66 now cranks but won't start, the error code is 2F44 EWS Manipulation Prevention/Wrong EWS telegrams received. Does yours crank ?
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Quote Originally Posted by steinec View Post
    Yes it cranks and that's the exact code I have, the manipulation prevention
    Aug 2009
    L.A. CALIFORNIA
    745LI
    Your car needs to be RE-SYNCED .
    Sep 2014
    Ohio
    2005 E66 745Li
    Yes, but it will not take using inpa for some reason. So I'm trying to get easydis44 going but 'tis a very slow learning process.
    Sep 2014
    Ohio
    2005 E66 745Li
    Got it squared away by 'aligning' the CAS module under the body section instead of using the EWS-ECU alignment under the engine/N62 section.
    Jun 2010
    Heber City, Utah
    1997 M3 2007 X3m & 328xi
    I'm trying to solve this on my car too. Hopefully I can using inpa and going to the body section.
    Jun 2017
    columbia,sc
    2005 bmw 745i
    Hey guys I had the same problem crank and no start. After the battery went dead. I used INPA to solve my problem. Under Body Section go to CAS, F6=Activate, F4=Reset ECU. I reset the ECU car started rite up. 2005 745i E65.
    May 2021
    Turkey
    E65 745
    Vvt error service not sup
    Quote Originally Posted by malt127 View Post
    How can you slove its easy and after this did you heard any problam
