Great job and congrats on a big milestone!
"Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.SaveSave
Thanks! im happy to be here as well
well i was lazy for a while but it was 60 degrees in Md this past weekend and rounded up the crew and began to attack the rear subframe job
First the rear needed to be tooted up
then i see a few troubling parts that needs replacement
started by removing the exhaust. super easy just 2 vbands.
removed the diff
stuff everywhere
dog bones are in bad shape. these had original part numbers on em
Subframe removed
views as dark start to set in
so now it is time to marshmallow some rubber but it seems this side of the subframe had a tweak so i heated it up to hammer it to be more cylindrical to fit the new bushing
the subframe bushings where easy to remove. the 3 diff bushings needed alot of heat. no problem
a whole bushing came out in one whack. placed it here out the way
So far all 5 bushings are removed and the poly bushings are now inserted. 3 diff bushings and 2 subframe bushings. the one main diff bolt is also replaced.
subframe wont go back till Saturday. so in the meant time i will clean up some of the rust on the frame paint it while its out. may paint the diff. fluid was changed back in 2016 so I don't think i will be reopening it. don't want no new leaks to happen
picks of the prep process while be up later this week. if no rain i will try to have it all done by Friday Morning. new dog bones and sway bar links should be here by Friday as well
Ok so it's been 2 years since I updated this
And you guys should know there was alot of bs after doing the subframe stuff.
I had to run new rear brakes lines,
New fuel lines since I'll be using E85 (an8 feed an6 return)
Flex fuel is setup
Launch control and anti lag setup.
Infotainment setup
Swapped my 3.64lsd for a 3.46lsd
New gast tank
Car has been street tuned.
Car has a bigger turbo
Installed a PPF Cam
Bigger throttle body and stronger intake plenum
Added oil cooler.
And have alot of pictures to add. But it looks like the pictures disappeared?
Car will be dyno tuned in August now all old car problems and engine quirks have been worked out. I'll get to the pictures when ever I get time
