Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 132
Thread: M70 mated with 5HP30
  1. #26
    May 2013
    Malibu calif
    (5) 850Ci, E9,SL65,911S
    About a two years ago while looking to buy an 850 I drove a beautiful 1991 850i 6 speed. The car with a 6 speed was a slug out of the hole! I was very unimpressed... When I questioned about the car being slow from other experienced E31 owners I was told that the E31s are heavy and that the 6 speed cars are typically slow until they get moving.
    I now own both a 1991 850i (auto) and a 96 850Ci with the M73 and 5HP30. The 850Ci is totally different to drive in EVERY respect! I know there are may differences but the 5 speed trans makes a HUGE difference in performance. I still have yet to install the 3:15 LS and that should make the car even more fun to drive...
    Just my $.02
  2. #27
    UK
    e34 540 e30 335
    I love the 5hp30 in my 540 and if it's possible to fit into my 8, then count me in as well.
    E30 1992 335 Cabriolet - Transplant nearly finished
    E31 1992 850ci - Hartge H8 6.0 conversion
    E34 1995 540A - Stock, low mileage, hi spec and soon to FI'd
    E36 1994 M3 - GM LS3 Transplant
    E38 2001 735 - Daily driver
    E46 2002 330 Cab - Stock
    M62B46 with TTV flywheel, dual plate clutch and 6 speed box sitting in a corner waiting for me to decide where to put it.
  3. #28
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by wokke View Post
    No one said the auto tranny is that much faster and above values are like fuel consumption values. All measured under top conditions with professional drivers I guess.
    And BTW, compare the standing start kilometre: 0.7sec between auto tranny and 6-speed with the M70 engine - WOW
    And the 80HP more powerful CSi in the same discipline outperformes the 850i by just 0.8 sec.
    If you drop your V2 chips in and add a 3.91LSD (for the 4-speed auto), you will most certainly be FASTER than the manual, which allows you a free hand to do more of this:
    '93 850Ci - Mineralweiss Metallic
    ALPINA B7 -Alpinweiss III
    BMWCCA E31 Chapter President
  4. #29
    Oct 2008
    Good old G. :D
    more and more Cars..
    to register your 8 @ www.8coupe.com!
    Best regards from good old Germany Harry!
  5. #30
    Cave Creek, AZ
    1993 850ci 2001 M5
    Do the M60 cars with the 5hp30 use the same can-bus interface as the later model M73/5hp30, or do they use the same interface between engine and transmission as the m70 cars with 4hp24? In other words, are the OBD-1 cars set up differently than the OBD-2 cars?
    I too, would prefer the 5hp30 to the 4hp24.
    Regards,
    Brian
    Cave Creek, AZ
  6. #31
    Mar 2012
    Auckland, New Zealand
    1991 BMW 850i
    5hp30 +M70 with Dinan EGS s/w and SMG steering wheel with paddles would suit the 8er so well!! 3.15 LSD is the perfect ratio for that gearbox IMO.
  7. #32
    Apr 2009
    Vancouver Isl, BC, Canada
    09 335, 98 Evo M3, 01 M3
    i envision you will need some for of circuit board to do the CAN bus conversions, and other various signal adjustments. IF someone designed this as a plug and play option(plug it into the M70 EGS connector, and it plugs into the 5HP30 EGS) the swap would be very straight forward.
    Where is an electrical engineer when you need one?
    Current:
    - 09 335i
    - 98 M3 Eurospec
    - 01 M3
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i
  8. #33
    Apr 2008
    Peachtree City, GA
    1996 ACS 850Ci
    You could just opt for the M73
  9. #34
    Cave Creek, AZ
    1993 850ci 2001 M5
    Long term goal would be the m70/m73 hybrid for me, aka m70b54, or s62 with 6 speed...
    I have seen that swap in person at Bimmerfest, there was a guy there that installed that combo in an e31, e46, and e38.
    Regards,
    Brian
    Cave Creek, AZ
  10. #35
    Jun 2010
    Reykjavik Iceland
    ALPINA B10 BITURBO
    This is a cool idea,, as E31/E32 have 3.15 ,, vs E38 2.81... diff ratio and the 1.st gear in 5HP30 is shorter vs 1.st in 4HP24... the accleration will be quite good,,,
    these performance numbers ..850 auto vs 850 CSI... this must be some kind of misprint.......... under 1 sec and we have 75+ ponies and 100nm
    this is a huge theft ,, from BMW to all their customers if this is true... buying a lame auto 850 vs top of the line ///M-powered car.....
    this cant be true at all
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    E34 550 V12 JML
    Contacts
    http://alpina.123.is/pictures/
  11. #36
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
  12. #37
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    I've done some reading and according to the ZF spare parts catalogue the A5S 560Z has been used in early E34-540I as well as in late E38-750iL.
    Also looking at the pins of the EGS they look identical to the pins of the 4HP24 EGS units and not like the ones on my '99-E38-750iL with Steptronic.
    I'm a bit confused now biut on the other hand have some hope that it may be possible to mate the 5HP30 from an E34-540i with the M70. I guess i have to talk to ZF at some point to find out about details.
    If anyone has any usefull knowledge please share it with us.
  13. #38
    UK
    e34 540 e30 335
    Anyone know what the differences are between the E34 and the E38 versions? Obviously the bellhousings are different but are the electronics and valveblocks the same? I would think that using the E34 trans controller would be the way to go, find out what the pins on that do and try and marry them to the E31.
  14. #39
    Quote Originally Posted by yamoda View Post
    that's exactly my idea. And 5HP30 is basically 5HP30 although they do have various codes depending upon which BMW model they are mounted to.
    CAN bus is not an issue anymore and I doubt the M60 DME delivers more data to the EGS than the M70 DME.
  15. #40
    I just learned that the CAN bus was already in use on the E34 when equipped with M60 engine. So I guess I have no choice but need to implement a CAN-bus translator. Doesn't make thing easier
  16. #41
    UK
    e34 540 e30 335
    It would help to get a pin out diagram of the E34/E32 trans controller posted up here if anyone has one.
  17. #42
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I wondered why you said that CANBUS was not an issue any more! Everywhere the M60 was used, DME 3.3 was used as well, and that was always CANBUS connected to the EGS.
    Circuit diagram of E32 740i here:
    http://www.meeknet.co.uk/E32/e32_93_etm.pdf
    Converting the CANBUS messages to something else (parallel digital I/O and analogue signals) is not trivial and would require software to emulate signals that the DME's expect - and, probably a lot harder - CANBUS messages that the EGS would expect.
  18. #43
    Yep, the issue would be to convert the DME signals to CANBUS signals as well as probably vice versa. And I can just guess what the EGS wants to see.
    I assume the DME just has to deliver rpm info but the EGS also delivers some signals back to the DME when shifiting AFAIK.
  19. #44
    Jun 2010
    FL, Sydney, Hong Kong
    1992 E31 850i
    Powertrain Control Solutions
    http://www.powertraincontrolsolution...pplication.php
    Its on my wish list......
  20. #45
    The OC, CA
    95 840Ci, 00 740i Sport
    I'm completely speaking from ignorance, but what about trying to fit the egs sensors into the hp30? Basically eliminating the CANBUS.
  21. #46
    Quote Originally Posted by IJustDrive View Post
    Only the communication between the engine control units and the EGS is CANbus based. I'm quite sure the tranny would go into trans fail safe mode right away if this communication is disturbed.
    And the 4HP24 EGS doesn't know about a 5th gear otherwise I would see a chance to adapt it.
  22. #47
    Christchurch,New Zealand
    93 fjord grey 850csi
    also note the auto M62 is out performed by the 850i by 0.1 sec after it was quicker through the 0-60 i suppose that may show the worth of an extra gear or the fact the M70 makes it's peak torque higher in the rev range
  23. #48
    The OC, CA
    The latter part is kind of where my head was at. I see your point about 5th gear. Could that be solved with a chip or flash like the Dinan?
    Current
    95 e31 840 Ci (Auto) Orient Blue
    00 e38 740 i (Auto) Titanium Silver
    Past
    94 e31 840 Ci (6 speed conv.) Avus Blau
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
  24. #49
    West Coast
    two 3's one 5 three 7's
    When a 4hp24 car swaps to a 6spd, isn't the solution to ground one of the wires to the EGS, thus circumventing a trans prog error?
    Couldn't one do this then run a standalone computer as suggested to the 5hp24?
    You might loose cruise control, ASC, etc... but who cares at that point.
  25. #50
    I never did a 4HP24 to 6-speed conversion but would have thought that you just unplug the EGS and that's it.
    Trans fail safe means that the transmission is stuck in 3rd gear but what if there isn't any 4HP24 anymore?
    And in terms of communication between EGS and engine elctronics it is basically limited to rev info from engine to tranny and all the rest is tranny info to the engine electronics (shifting mainly so the engine electronics adjust ignition timing).
    But as said above, no experience yet so just theoretical thoughts.
